*For the 77-79's*
TopicsRepliesAuthorViewsLast Posts
No new posts   Sbc 350 knocking issue 3HeavyChevy7767View latest post on Sun Feb 11, 2018 9:08 pm
by HeavyChevy77
No new posts   1977-79 Sport mirror swap  078i6belair42View latest post on Sun Feb 04, 2018 9:29 am
by 78i6belair
No new posts   305 dies in gear.  577LandauCoupe81View latest post on Mon Jan 29, 2018 11:42 am
by 77LandauCoupe
No new posts   Electric fan conversion 478i6belair94View latest post on Sun Jan 21, 2018 5:09 am
by 78i6belair
No new posts   Wet floorboard 9Sean Donica242View latest post on Mon Dec 25, 2017 11:14 am
by JusSko77
No new posts   2nd gen F body steering box swap 378i6belair139View latest post on Fri Dec 08, 2017 12:08 pm
by Z77impala
No new posts   1977-79 4dr sedan RF door window run channel rubber 278i6belair175View latest post on Wed Dec 06, 2017 6:51 pm
by 78i6belair
No new posts   Top dead center. 6terry cronk174View latest post on Mon Dec 04, 2017 12:20 pm
by Z77impala
No new posts   Dual exhaust pre-made 14terry cronk416View latest post on Mon Dec 04, 2017 11:54 am
by Z77impala
No new posts   Coil spring question 21scy135795View latest post on Mon Dec 04, 2017 10:39 am
by Z77impala
No new posts   Setting up a holley stock 350 5HeavyChevy77201View latest post on Sun Dec 03, 2017 5:14 pm
by HeavyChevy77
No new posts   Body mounts 6terry cronk272View latest post on Thu Nov 09, 2017 4:39 pm
by terry cronk
No new posts   automatic column adjustment 2terry cronk99View latest post on Fri Oct 27, 2017 5:43 pm
by BrokenBlazerDave
No new posts   12" rotors 15" wheels 21Myloth1553View latest post on Mon Sep 11, 2017 3:02 pm
by Fierro51
No new posts   PCV valve? 5terry cronk106View latest post on Fri Sep 08, 2017 11:11 am
by Fierro51
No new posts   Shortened driveshaft. 2terry cronk101View latest post on Wed Aug 16, 2017 7:18 am
by terry cronk
No new posts   Led Flash Issue 2HeavyChevy77125View latest post on Thu Aug 03, 2017 6:02 pm
by HeavyChevy77
No new posts   sbc headers 3terry cronk180View latest post on Sat Jul 22, 2017 6:49 pm
by Myloth
No new posts   Interior Screw Guide 1sosa95View latest post on Sat Jul 22, 2017 9:20 am
by Sweet Seventy9
No new posts   Power steering bracket 2terry cronk87View latest post on Mon Jul 17, 2017 10:35 am
by terry cronk
No new posts   Motor Mount bolts 12terry cronk153View latest post on Fri Jul 07, 2017 9:26 am
by terry cronk
No new posts   A/C Evaporator Condensed Water Drain 2paulboncz119View latest post on Fri Jun 23, 2017 9:28 pm
by GM B-Body Forum
No new posts   Quarters 2 door 3Myloth187View latest post on Mon May 29, 2017 3:07 pm
by Myloth
No new posts   1978 Bel Air 4dr sedan rear coil spring replacment. 278i6belair166View latest post on Fri Apr 28, 2017 7:25 am
by 78i6belair
No new posts   4dr sedan front door window run channel rubber. 478i6belair183View latest post on Sat Apr 22, 2017 7:10 pm
by Myloth
No new posts   Engine Break In Mishap 6HeavyChevy77184View latest post on Wed Apr 19, 2017 6:44 pm
by Fierro51
No new posts   Mechanical engine question 1HeavyChevy77159View latest post on Sat Mar 25, 2017 12:10 am
by GM B-Body Forum
No new posts   Need to move/tow this... ideas? 3DanR1245164View latest post on Wed Mar 22, 2017 9:59 pm
by Kit1078
No new posts   1979 Caprice wiring harness 9terry cronk246View latest post on Sun Mar 12, 2017 11:58 am
by GM B-Body Forum
No new posts   Brake Booster 79 Delta 88 479delta88223View latest post on Mon Mar 06, 2017 3:21 pm
by 79delta88
No new posts   7.5 diff. Will it hold up? 15trilightosaurus78354View latest post on Mon Feb 13, 2017 6:38 pm
by terry cronk
No new posts   Engine Racing at Cold Start 6paulboncz302View latest post on Mon Dec 19, 2016 9:09 pm
by paulboncz
No new posts   AFB Carburetor 2paulboncz223View latest post on Wed Dec 07, 2016 9:14 pm
by paulboncz
No new posts   Front Sway Bar Upgrade Bolt In 17HeavyChevy77473View latest post on Tue Dec 06, 2016 7:34 am
by terry cronk
No new posts   RPO codes for a 9c1 car 7phil.fen861080View latest post on Wed Sep 14, 2016 6:14 am
by TMCKERROW
No new posts   Bumper Filler 1paulboncz420View latest post on Wed Aug 24, 2016 6:07 pm
by Boogie1468
No new posts   How to convert 79 delta 88 to 5x5 front bolt circle 2jboehm365View latest post on Wed Aug 24, 2016 5:55 pm
by Boogie1468
No new posts   Another rear end swap question 7radioguy558View latest post on Wed Aug 10, 2016 7:44 pm
by radioguy
No new posts   Trying to figure out an LS swap 6kansasboy1053View latest post on Wed Jul 27, 2016 4:48 am
by gear_grinder
No new posts   Fuel delivery  2GEOLANG1283View latest post on Mon Jul 25, 2016 5:32 pm
by HeavyChevy77
No new posts   rear end swap 7Bill "elvis"590View latest post on Tue Jul 05, 2016 4:21 pm
by terry cronk
No new posts   Front rotor Lug pattern 2JusSko77272View latest post on Mon Jul 04, 2016 11:46 am
by JusSko77
No new posts   big block swap in a 79 impala 10Bill "elvis"789View latest post on Thu Jun 16, 2016 5:28 pm
by terry cronk
No new posts   speedo correction? 1terry cronk280View latest post on Thu Jun 16, 2016 9:39 am
by terry cronk
No new posts   Edelbrock 1400 Problem 1, 225HeavyChevy77862View latest post on Mon Jun 06, 2016 12:27 pm
by HeavyChevy77
No new posts   Front Seat Belt swap 178i6belair424View latest post on Mon Jun 06, 2016 1:18 am
by JusSko77
No new posts   78 caprice sun roof repair/replacment in southern Cali 1, 228spearwarrior1979View latest post on Wed Jun 01, 2016 11:10 am
by spearwarrior
No new posts   Sunroof to hard top 0kansasboy287View latest post on Wed May 18, 2016 5:52 am
by kansasboy
No new posts   Trying to find a crossmember 5kansasboy516View latest post on Wed May 18, 2016 4:10 am
by kansasboy
No new posts   79 impala Intake Manifold 2paulboncz388View latest post on Sun May 15, 2016 8:25 pm
by paulboncz
*For the 77-79's*
ForumTopicsPosts
No new posts
415Dual plane intak...
Mon Jan 16, 2017 7:58 pm
GM B-Body Forum View latest post
No new posts
36THM350 72'
Fri Jun 13, 2014 2:41 pm
Myloth View latest post
No new posts
5508.5" 10 Bolt out...
Fri Feb 10, 2017 8:16 am
No new posts
442the dreaded Comf...
Sat May 21, 2016 3:13 am
cruiser_dirk View latest post
No new posts
214Rear Disc Brake ...
Tue May 02, 2017 9:52 pm
Boogie1468 View latest post
No new posts
531Ideal backspacin...
Sat Jan 02, 2016 7:35 pm
No new posts
12strange options ...
Tue Jun 25, 2013 11:22 pm
No new posts
11Magazine article...
Tue May 27, 2014 2:45 pm
Buick_FIN View latest post
No new posts
29Back seat panels...
Fri Sep 05, 2014 1:24 pm
Sweet Seventy9 View latest post
No new posts
4181979 Catalina Sa...
Mon Jun 27, 2016 9:39 am
1kcfan! View latest post
No new posts
827suspension upgra...
Mon Jan 16, 2017 5:27 pm
Z77impala View latest post
No new posts
114Floor Pans
Sat Apr 09, 2016 3:48 pm
Gooched78Caprice View latest post
No new posts
535Matching the pai...
Wed Oct 15, 2014 9:40 pm
No new posts
324dimming lights...
Mon Feb 08, 2016 4:00 pm
scy135 View latest post
No new posts
29Weather strippin...
Thu Feb 27, 2014 9:45 pm
Permissions in this forum:
You cannot post new topics in this forum
You cannot reply to topics in this forum
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
  • New posts New posts
  • No new posts No new posts
  • New posts [ Popular ] New posts [ Popular ]
  • No new posts [ Popular ] No new posts [ Popular ]
  • New posts [ Locked ] New posts [ Locked ]
  • No new posts [ Locked ] No new posts [ Locked ]
  • Announcement Announcement
  • Sticky Sticky
  • Global announcement Global announcement
Current date/time is Tue Feb 20, 2018 10:05 pm
