    12" rotors 15" wheels
    Post  Myloth on Fri Feb 13, 2015 3:22 pm
    Do the 12" rotors on the 90s B Body fit under the same B Body 15in wheels (ie 95 RM 15" wheel)
    My old Riviera had 12in drums and the 15" wheels were a special size to fit the 12 Aluminum drums
    are the B Body 15" wheels like that or as most Wagons came with 15s no? and didnt most wagons have 12"
    brakes?
    Re: 12" rotors 15" wheels
    Post  GM B-Body Forum on Fri Feb 13, 2015 7:23 pm
    Our b bodies came with either 9.5" drums or 11" drums and those fit fine behind 15's. Ive also confirmed the rear disc brakes off a 94 to 96 SS or 9c1 also fit behind a 15, and those rotors are 11.6 diameter, plus almost an inch for the caliper too, but there was only maybe 1/4" from the caliper to the rim. I would assume the 12" front rotors off of the same cars would fit also since the rotors are actually 11.8" but that i havent confirmed.
    Post  Myloth on Sat Feb 14, 2015 7:55 pm
    I see wagons listed with 12"(11.Cool front rotors and 15" wheels. Of course I was thinking about the 1le calipers from the f
    body that is iffy. I am debating going to 17s or 18s as 15in tires are hard to find in anything but narrow or truck style but
    I do have two sets of 15in rims already.
    Post  Myloth on Tue Mar 10, 2015 4:47 pm
    The Centric Rotor for the 94 RM says 11.86 and every RM for 1994 lists 15" wheels the same wheels I have a set
    of black Steel 15x7s. I am wondering if it's worth it as the 11" on my 79' are very mediocre. But I would need
    the hubs from a 94 (or any late model B) no? And if so aren't the Balljoints bigger? I don't mind swapping my
    China made BJs for better brakes but has anyone tried it or think the later brakes are better? Last time I drove
    a late model B it was an SS and that's different as it was 4wheel ABS I remember I did the brakes on it. Anybody
    try a reasonable priced alternative to this braking mediocrity.
    Post  Sweet Seventy9 on Tue Mar 10, 2015 6:39 pm
    15" 5x5 "Steelies" go right on. Most wagons from 77-96 came with the 12" front brakes.
    Someplace on here is a write-up about the swap.
    Post  Myloth on Wed Mar 11, 2015 10:58 am
    I thought I'd read something a while back but couldn't find it I'll search again.
    Post  Sweet Seventy9 on Wed Mar 11, 2015 11:32 am
    I just checked the site and cant find it either.
    Here's the info in a nut shell: swap out these parts. Laughing
    General Motors
    front spindle, left 1ea, pn. 14012589
    front spindle, right, 1 ea, pn. 14012590
    1LE 12-inch rotors, 2 ea, pn. 18016035 - (for 5x4.75 bolt pattern)
    Dustshield, left, 1 ea, pn. 344023
    Dustshield, right, 1 ea, pn. 344024
    Dustcaps, 2 ea, pn. 1400344
    Washers, 2 ea, pn. 457707
    Nuts, 2 ea, pn. 378137
    Calipar bolts, 4 ea, pn. 5463495
    Caliper, left, 1 ea, pn. 18015427
    Caliper, right, 1 ea, pn. 18015427
    Wheel bearings and seals.
    If you go used, look for these cars for donor parts:
    Buick, Pontiac, or Chevy full size 1978-1992
    Caddy Seville and Deville 1978-1992 execpt for limos
    Olds Delta 88 coupe and Sedan 1978-1992
    Buick Riveria 1977-1979
    Post  Myloth on Wed Mar 11, 2015 7:40 pm
    Thanks for the info that's great. Ah the only issue is finding the spindles I found one on ebay for 75(nb it's NOS) but
    no sign of it's sibling. Might have to hit the yards for these I know a place not too far that has a lot of full size
    Caddies for parts.
    Post  Sweet Seventy9 on Wed Mar 11, 2015 8:41 pm
    Right side $75 - http://www.northclassifieds.com/nos-factory-gm-chevy-caprice-i6210434/
    This may be the same as what you found -
    Left side $75 - http://www.ebay.com/itm/NOS-Factory-GM-CHEVY-CAPRICE-Left-FRONT-SPINDLE-P-N-14012589-/271740330898
    Post  Myloth on Thu Mar 12, 2015 11:28 am
    I'm going to do a yard hunt on the spindles the online is too pricey, thank you though.Or maybe do this conversion
    I read about this while back this guy has all parts for B Bodies in Kits.This will do a C5 Upgrade but a minimum 500+
    dollar bill plus no more 15" or 16" wheels but real world braking improvement, a thought for those of us contemplating large
    rims.
    http://customworksperformance.net/brakes.html
    Post  Sweet Seventy9 on Thu Mar 12, 2015 11:54 am
    They're plentiful, but if you have any troubles finding them near you there's still maybe a dozen or so sets near me.
    I was reading somewhere that the 2 piston (or is it 4 piston??) F-body 1LE calipers bolt right on with the 12" rotor upgrade.
    They will NOT fit behind a 15" wheel though. 16" is the minimum.
    Post  Myloth on Thu Mar 12, 2015 1:38 pm
    That I read too I believe you just need a different plate for the dual piston aluminum which what I'd like at the minimum.
    Yes you are right the parts are around although I'm not sure where,  there is a place about 30mi across the river.
    That place seems to pop up with a lot of RWD Fleetwood parts on Car Part but I haven't checked them out yet. Locally
    nobody seems to have any B Bodies of any vintage from 77-96 for parts. Quite few older folks still rolling in them though
    and mainly they are the older variety 77-90 4 doors except few late wagons .
    Just to be sure I would like to grab both sides of everything (rotors,calipers,spindles) easier that way
    then upgrade from there.
    Post  Sweet Seventy9 on Thu Mar 12, 2015 1:54 pm
    lmk how you make out. The ones near me are all complete and even have the original wheels on 'em still.
    Post  HeavyChevy77 on Tue Mar 31, 2015 1:59 am
    yo sweet i was looking to swap the fronts to 5x5 bolt pattern to match the rear axle and might as well upgrade from 11" -> 12" rotors the was this car for parts its a 92 olds98 sedan bubble body.
    If compatible do i grab the spindle/rotor wHub/caliper & brackets and thats all i was gonna replace hoses and rebuild calipers
    Post  Sweet Seventy9 on Tue Mar 31, 2015 10:04 am
    Yup, swap over the spindles and everything mounted to them. The 12" front brakes use what are referred to as the "Tall" spindles. There's a write-up on here someplace with fairly detailed instructions, even part numbers. If you want to go crazy, Belltech makes dropped spindles. Very Happy
    Post  HeavyChevy77 on Tue Mar 31, 2015 10:48 am
    i seen that but i got 205/70r15 tires and have about 4" off the ground if i lower it more ima get stuck on speed bumps LOL
    Post  HeavyChevy77 on Thu Jan 12, 2017 11:24 pm
    Sweet Seventy9 wrote:I just checked the site and cant find it either.
    General Motors
    Hey need some clarification
    I got new wheels and going 4.75 all around instead of 5x5
    Im drilling the new pattern in the rear with a jig I ordered
    The front pattern is correct but want to upgrade rotor size
    So with using 1le gen 3. 92 camaro rotors what spindle is required? Is it the spindle that came with 11" or the 12" rotors
    Reason is ordered timken bearings and inners (set6)are good but the outers are too small (set2) I needed the set3 . I assumed I would just use the 77 caprice bearings (set6/set2) but now I think I need the 12"rotor spindle also what bout the ones with 5/8" ball joint is that only 95+
    Please anyone with advice or has done this mod let me kno thanks
    Post  Sweet Seventy9 on Fri Jan 13, 2017 9:51 am
    It's been a long time since I did the swap but I do remember you have to use the "Tall" spindles from a wagon or 9C1. The 1LE rotors were used on those spindles. I don't remember the bearing sizes.
    Try googling "GM B body 12" brake upgrade" for more info.
    Post  Myloth on Sat Jan 14, 2017 11:54 pm
    The spindle is the problem (Finding them). You can use either the Camaro 12"
    5x4.75" rotor or the B Body 12" 5x5". I think you'd have to either go on a bug hunt to
    find the late 9c1 B Body tall spindles (Yard or Ebay?) or get the 2" drop spindles for the
    late B Bodies. You could also use the Impala SS brakes but you need 17" wheels minimum.
    http://www.streettrendsinc.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=BBODY&Product_Code=15811&Category_Code=VARSUS
    Post  HeavyChevy77 on Sun Jan 15, 2017 4:27 pm
    Yea I. Quickly found out when test fitting bearings on new rotor so Im gonna hit the yard Tuesday there's a 92 &95 caprice just need to check that they are 9/16" ball joints on the lower and not the 5/8" also that they have 12" rotors too
    Also I thought the impala front calipers were the same size as reg caprices
    I got impala so brakes in the rear that clear 15" steelies
    Post  GM B-Body Forum on Sun Jan 15, 2017 5:08 pm
    I believe 1996 was the only year that gm finally upgraded to 5/8 lowers on the 9c1 only, i read this somewhere but i cant remember if its correct.
    Fierro51
    Post  Fierro51 on Mon Sep 11, 2017 3:02 pm
    holy crap i just seen this thread ive been missing out ! myloth did you get the custom works diy kit?
      "Oh"
    4.8 turbo LS TH350 swap
    2015 F250 ccsb Platinum
      Current date/time is Mon Feb 19, 2018 10:47 am
