    B body engine
    1971Z28RS
    B body engine
    Post  1971Z28RS on Tue Aug 25, 2015 9:11 pm
    Hello all
    New to this forum
    I have a 1971 z28 with a 1973 chev motor
    That was apparently either in a Chevelle or Malibu ?
    It is a Canadian motor made in St Catherines
    Here is some numbers
    St. Catharines = k
    11-27 - Nov 27
    1- Chevy
    3- 1973
    Vin 137040
    Here is the back casting numbers
    3970010
    Followed by - k 10
    On the front pad it is stamped
    131137040 Followed by K 1 1 27 CKL
    A10
    D N
    2 . L . 6
    Casting clock - hand on 4 bump
    Last edited by 1971Z28RS on Tue Aug 25, 2015 9:13 pm; edited 1 time in total (Reason for editing : Spelling)
    Re: B body engine
    Post  GM B-Body Forum on Fri Aug 28, 2015 11:36 am
    Welcome to the forum, wasnt quite sure if you had a question with this post or not, but decided to reply anyways. Seems like you decoded it pretty well, but the malibu and chevelle are A bodies.
    1971Z28RS
    B body
    Post  1971Z28RS on Fri Aug 28, 2015 11:39 am
    Which b body model would start with my vin
    Thanks again
    Re: B body engine
    Post  GM B-Body Forum on Sat Aug 29, 2015 12:03 am
    Unfortunately with that number i cant come up with anything only because its the last 6 digits and that was just the sequence number of the car vin, since its a '73 the car would have had a 13 digit vin, but i dont think youll know for sure exactly what car it came out unless someone out there can decode it further, other than decoding the date, place, and time of manufacture of the block itself which is what you've done already
    Re: B body engine
    Post  GM B-Body Forum on Sat Aug 29, 2015 10:21 pm
    I decided to decode the numbers you posted just for fun, the casting number on the back 3970010 automatically means its a 350. The k1127CKL decoded to K= St. Catherines, Ontario, 11= Nov, 27= 27th, CKL= 350, with automatic tranny, but says it came in B,F, and A bodies. I decoded mine and it points to exactly what it came in, my 79 caprice. Mine was also made on the same month, day, and assembly plant in St. Catherines. But my code was K1127DRA where the DRA means 1979, 350, 4 barrel, automatic, 170hp, full size application.
    Can you take a pic of the stamped numbers on the front pad and post it so i can see exactly what you have?
    1971Z28RS
    Re: B body engine
    Post  1971Z28RS on Sat Aug 29, 2015 11:07 pm
    I tried to post pics
    Won't allow me
    Re: B body engine
    Post  GM B-Body Forum on Sat Aug 29, 2015 11:27 pm
    Its real easy, you cant use the attach file option below, but heres how:
    https://www.gmbbodyforum.com/t315-how-to-upload-pics
    1971Z28RS
    Numbers
    Post  1971Z28RS on Sat Aug 29, 2015 11:30 pm
    Tried with photo bucket ?
    Re: B body engine
    Post  GM B-Body Forum on Sat Aug 29, 2015 11:32 pm
    Yeah you can use photobucket, or any other, this forum has its own host called servimg.
    1971Z28RS
    Re: B body engine
    Post  1971Z28RS on Sat Aug 29, 2015 11:36 pm
    For some reason
    Nothing seems to work
    Can't upload pics
    It says new members can't upload
    Links ?
    Re: B body engine
    Post  GM B-Body Forum on Sat Aug 29, 2015 11:40 pm
    Really? ill have to check it out, hold on a second...
    Re: B body engine
    Post  GM B-Body Forum on Sat Aug 29, 2015 11:47 pm
    Hmm i cant find anything, all your permissions are set to allow for it, just like everyone else, but i reset it so try it again.
    1971Z28RS
    Re: B body engine
    Post  1971Z28RS on Sat Aug 29, 2015 11:53 pm
    Nope
    Funny thing is
    When I preview it , it is normal
    Hit the send button and nothing
    Page reloads but nothing
    Re: B body engine
    Post  GM B-Body Forum on Sat Aug 29, 2015 11:58 pm
    Try our image host and see if it works.
    1971Z28RS
    Re: B body engine
    Post  1971Z28RS on Sun Aug 30, 2015 12:01 am
    I wish I had a computer
    Doing everything from my iPhone
    Re: B body engine
    Post  GM B-Body Forum on Sun Aug 30, 2015 12:13 am
    Ohhh ok, so you cant post any link at all?
    1971Z28RS
    Re: B body engine
    Post  1971Z28RS on Sun Aug 30, 2015 12:16 am
    No sir
    Re: B body engine
    Post  GM B-Body Forum on Sun Aug 30, 2015 9:59 am
    Once you get to 10 posts your rank will change and you will get one star, see if it changes when that happens, i dont know why its doing that since all the permissions as a "newbie" are the same. But try it out.
    1971Z28RS
    Re: B body engine
    Post  1971Z28RS on Sun Aug 30, 2015 2:50 pm
    I will try
    Re: B body engine
      Current date/time is Mon Feb 19, 2018 6:43 pm
