    Anyone put a manual Transmission in a Caprice/Impala?
    Marx3
    Post  Marx3 on Tue Sep 08, 2015 3:43 pm
    I have always wanted a V8 with a manual transmission. Up until recently, I had a 78 Trans Am with a th350, that would have been an obvious manual car. Never found a manual to put in it, though.
    Now I am back in a good old Caprice and now I found a Borg Warner Super T-10 for very cheap, everything is included and all I will beed is a pilot bearing for the crank, a Z-bar/linkage and ofcourse the pedals.
    Has anyone ever seen, driven or had a 77-90 with a manual transmission?
    I know a Firebird uses the same transmission crossmember and the possible the same lenght driveshaft. Other than that, I thin kI will on need the open up the transmission tunnel and cut a nice clean hole in the carpet, that can be closed again, should I regret it one day.
    Boogie1468
    Manual transmission in later B bodies
    Post  Boogie1468 on Wed Sep 09, 2015 11:06 pm
    I think the transmission crossmember and driveshaft issues are simple. Where you will have the most difficulty is the clutch pedal mounting and linkage. I have sen it done one time, but I suspect it's. Big job.
    Boogie1468
    Manual trans in later B body
    Post  Boogie1468 on Wed Sep 09, 2015 11:44 pm
    I spoke too soon. There is a highly detailed description of installing a manual in a later model B body. Look in the Forum Topics and you'll find "Old Scool Manual Transmission....". Lots of work, but I bet it's a satisfying ride.
    Marx3
    Re: Anyone put a manual Transmission in a Caprice/Impala?
    Post  Marx3 on Thu Sep 10, 2015 2:19 am
    Yes it's right there! Oh man that's great :-)
    Osborn F. Enready
    Post  Osborn F. Enready on Sat Sep 12, 2015 9:19 am
    I have an "ex" drinkin buddy that had installed a muncie 4-speed in a bone stock mid-eighties Impala. The car was a blast to drive with the exception that he put in RIDICULOUSLY stiff clutch springs.
    I only checked out the install once, many years ago, but it was fairly simple using all chevy parts except the Z bar. He did have to craft his own Z bar, but it functioned well. He also did some support plates on the firewall to ensure rigidity with the heavy springs and abuse.
    Wish I had some pics to share, but I do not.
    This post has been approved by Osborn F. Enready study
    Osborn F. Enready
    Post  Osborn F. Enready on Sat Sep 12, 2015 9:58 am
    Also...
    If anyone is interested, I have a cherry T-56 6-speed transmission, complete with bellhousing, clutch, pressure plate, hydraulic reservoir.. low miles from a collectors f-body that got rolled over.
    Was going to install it in my own car, but will cost me megabucks to install with a external balance 400 chevy engine which is what I have.
    I got it for a steal and will pass the savings on to you @ only $1950.00
    Will post pics soon, feel free to inquire or email if interested.
    Marx3
    Post  Marx3 on Sat Sep 19, 2015 3:50 pm
    dang, I would have loved to see pictures of that installation. Do you remember why he had to fabricate his own Z-bar? Why wouldnt a Z-bar from, say a Camaro or Trans Am work?
    Osborn F. Enready
    Post  Osborn F. Enready on Sat Sep 19, 2015 7:45 pm
    I don't think he "had to"... I think he just wanted to get it going instead of hunting the salvage yards.
    I want to say he got most of the parts from a g-body... monte carlo I think, and the z-bar wouldn't work, so he just fabbed one using the measurements he needed.
    Post  Kit1078 on Tue Feb 23, 2016 11:05 pm
    I did a manual swap using parts from a junked '71 camaro (6cyl 3 speed car, I think it's original color was rust). The only real modification I had to make was adjusting the 'z bar' to line up, and had to have a machine shop put an s bend in my stock brake pedal. Oh, and cut a hole in the floor. Did most of the work over one weekend (my step mother's mom was in town, and I hated her, so I needed something to do.)
    I'm doing another swap in my current project Impala, but I want to do a hydraulic one this time. I had issues with the clutch not releasing all the way under full throttle and had to tie the left side of the motor down.
    Nice thing about Chevy is that an old school 4 speed with bell housing is the same length as a TH350 and most muncies and saginaws use the same yoke.
    Also, if you can find it, there is the elusive "New Process A833" for an early eighties half ton chevy truck, it's a standard 4 speed with the same gear ratios as a 4L60E, making it a 4 speed with overdrive. It's actually a Chrysler transmission that was adapted to fit chevy trucks.
      Current date/time is Sun Feb 25, 2018 2:37 am
