    frame repair
    mattlarthur
    frame repair
    Post  mattlarthur on Mon Oct 12, 2015 11:50 am
    i have found some rust holes on the rear frame rails (under trunk) on my 77 Caprice 2 dr. are there replacement parts available or is this a "weld in patch panels" project? i know El Caminos have this problems also. thanks
    Marx3
    Re: frame repair
    Post  Marx3 on Fri Nov 06, 2015 11:08 am
    I recently did extensive rust repair on the frame of an 86 caprice.
    I cut patches to exact fit, from a 3 mm thick steel sheet.
    If you are a reasonably experienced welder I would advise you to just to the "patchwork".
    Re: frame repair
    Post  solo79 on Sat Nov 07, 2015 6:07 pm
    Nice work on the frame repair!! Top notch!
    Re: frame repair
      Current date/time is Sat Feb 17, 2018 8:02 pm
