    1977-1990 List of Part Numbers
    Post  GM B-Body Forum on Wed Sep 18, 2013 5:39 pm
    So i have a list and diagrams of random part numbers for the 77-90 models, useful info, thats why it belongs here. this was all pulled from here:http://www.impalassforum.com/vBulletin/showthread.php?t=227215&page=4
    Re: 1977-1990 List of Part Numbers
    Post  GM B-Body Forum on Wed Sep 18, 2013 5:41 pm
    Heres the long list:
    YEARS---MODEL---- DESCRIPTION--- PART NUMBER
    77to77 ALL Temperature gage assembly 8992794
    79to79 ALL Temperature gage, with gages dash 8993350
    77to78 Impala Header panel molding, above grille 370249
    77to77 Caprice Grille 367429
    77to77 Impala GRILLE, Lower section, LH 367445
    79to79 Impala Grille, RH lower section 473700
    81to85 Caprice Grille 14015120
    86to90 Caprice Grille 14081651
    78to78 Impala GRILLE MOLDING, UPPER 463173
    77to79 Caprice Grille Emblem "Chevrolet" 466061
    79to79 Impala GRILLE EMBLEM "Chevrolet" 473692
    77to79 Valve cover rubber grommet, 3989350
    75to79 VACUUM ADVANCE UNIT, WITH 350 1973517
    77to77 Head Lamp Dimmer Switch 7829781
    74to81 Head lamp switch 1995193
    77to78 Qtr panel marker lamp lens, LH 913153
    77to78 Qtr panel marker lamp lens, RH 913154
    77to78 Impala Marker lamp lens, RH fender corner 913247
    77to78 Impala Marker lamp lens, LH fender corner 913248
    79to79 Marker lamp lens, LH, rear quarter panel 913733
    79to79 Caprice Marker lamp lens, LH, fender corner 913857
    79to79 Impala Marker lamp lens, LH, fender corner 913859
    79to79 Impala Marker lamp lens, RH, fender corner 913860
    80to90 Marker lamp lens, LH Rear qtr panel 914191
    80to90 Marker lamp lens, RH Rear qtr panel 914192
    77to78 Impala Front park lamp assembly, RH 912862
    77to78 Caprice Front park lamp assembly, LH 913209
    77to78 Caprice TAIL LAMP ORNAMENT, RR 5968466
    78to78 Caprice Tail lamp housing, LH, 5969039
    78to78 Caprice Tail lamp housing, RH, 5969040
    77to78 Impala Tail lamp bezel, LH 5968167
    78to78 Caprice Tail lamp bezel, LH 5969045
    77to77 Caprice Tail lamp lens, LH side 5968461
    78to78 Impala Tail lamp lens, RH 5969866
    77to78 Caprice Back up lamp lens 5968465
    77to80 All BACK UP LAMP SWITCH, WITH A/T 1994229
    79to79 All License lamp lens 913668
    79to79 Caprice Head Lamp bezel, LH 475739
    80to80 Impala Head lamp bezel, LH 14008327
    80to80 Impala Head lamp bezel, RH 14008328
    87to89 Caprice Head lamp bezel, RH 14090360
    75to80 All HEAD LAMP RETAINING RING, RECTANGULAR 5966170
    69to79 All Turn signal switch 1997963
    77to77 All Turn signal lever, with cruise control 6466563
    77to80 All Turn signal lever, with cruise control, (Red) 6466940
    77to80 All Turn signal lever, with cruise control, (black) 25030492
    75to79 All HEAT RISER VALVE, 305 or 350 5234825
    77to79 All PARKING BRAKE RELEASE HANDLE 1253552
    71to79 All BRAKE PEDAL PAD, WITH DISC BRAKES 3988288
    62to79 All Parking brake cable connector. Connects middle cable to rear cables 537485
    77to79 All PARKING BRAKE CABLE, REAR 1254821
    77to79 All Parking cable, Front 1260854
    77to80 All Wire Wheel cover, 15" wheel 464942
    77to80 All Wire Wheel cover, 13" wheel 465078
    77to80 All Wire Wheel cover, 14" wheel 465078
    77to79 Caprice WHEEL COVER EMBLEM, CAPRICE CREST 361379
    78to79 Impala Wheel cover insert. Black with silver bow tie 464901
    80to81 Caprice Wire Wheel Cover center insert decal 14013070
    71to79 All TIE ROD SLEEVE KIT, WITH CLAMPS & BOLTS, does both sides ES2004S
    77to79 All Front bumper guard cushion 371957
    77to79 All Rear bumper guard cushion 371981
    77to79 All Front bumper guards accessory kit 995196
    77to79 Wagon Rear bumper guards accessory kit 995230
    77to79 Wagon Rear bumper impact strip, WAGON ONLY 371926
    77to79 All Front bumper impact strip, center piece For car with bumper guards 375642
    77to88 All Hood release cable assembly 20111300
    79to79 Caprice Front fender, RH 14002330
    77to78 Caprice Front fender extension, bolts on to fender, RH 367420
    77to79 All Front wheel opening molding, LH 371995
    77to79 All Front wheel opening molding, RH 371996
    77to79 Caprice Fender molding, RH bottom in front of wheel 375720
    77to79 Caprice Fender molding, LH bottom in rear of wheel 375721
    77to79 Caprice Fender molding, RH bottom in rear of wheel 375722
    77to78 All Front fender molding, Upper, Silver-blue Vinyl and chrome. Stick on 377859
    77to79 Caprice FENDER MOLDING, LH 377895
    77to79 Station Wagon Front fender molding, RH, for Caprice Estate Wagon 377898
    77to78 Caprice PARK LAMP BEZEL, LH, FRONT 466001
    78to78 Caprice PARK LAMP BEZEL, RH, FRONT 466002
    80to90 All Front fender molding, Lower LH, Rear of front wheel 14010595
    80to89 Caprice Front wheel opening molding, LH 14013609
    80to89 Caprice Front wheel opening molding, RH 14013610
    82to90 All Front fender molding, LH lower front of front wheel 14013617
    70to79 All Compass, Circa 1970s, with GM logo on front 983335
    64to79 All BUMPER BOLT, 7/16 x 1" CHROME CAP 9425343
    64to79 All BUMPER BOLT, 3/8 x 1" CHROME CAP 9433489
    77to77 All A/C & HEATER CONTROL HEAD ASSEMBLY 7897441
    77to80 All Heater Fan Resistor, with A/C 1609776
    77to80 All A/C COMPRESSOR SWITCH, CAPILLARY TUBE 3035744
    69to79 All ANTENNA MAST, FM 370147
    77to79 All Printed Circuit, with gages dash 8989618
    77to81 All Clock, Analog Style 14001591
    65to79 All CLOCK RESET KNOB KIT 14053344
    77to79 All Rear window defogger accessory kit 995224
    77to80 All WINDSHIELD REVEAL MOLDING, RH 1708744
    62to79 All WINDOW WASHER RESERVOIR FILTER 3986821
    77to80 All WIPER SWITCH, W/O PULSE WIPERS 1994196
    77to78 All Mirror, outside LH remote control, Chrome 995366
    77to78 All Mirror, outside RH Sport style "bullet" Mirror, Paint to match 995371
    77to78 All Mirror, outside RH manual control 995456
    77to78 All Mirror, RH remote control, Sport style mirror. NOT Chrome � Paint to match 995611
    77to78 All Mirror, outside RH remote control, Chrome 995613
    77to79 All Mirror, outside, RH manual, Chrome 996254
    77to79 All MIRROR, OUTSIDE, RH, SPORT STYLE 996256
    80to85 Caprice Mirror, outside RH remote control, Chrome 996585
    71to78 All Mirror, outside, manual control. Fits either side 9826594
    77to79 All Mirror, LH outside, Manual. Standard mirror. 20000547
    77to78 All Mirror, LH remote control, Sport style mirror. NOT Chrome 20026354
    77to79 All Door edge guards set (4 door models) 995347
    80to88 All Door edge guards set (2 door models) 996587
    77to79 All Power Door lock switch assembly, Chrome 20043224
    77to80 4 door Door window scalp molding, RH vertical piece 1713370
    77to80 4 door Door window scalp molding, LH vertical piece 1713371
    77to85 All POWER WINDOW MOTOR, LH, DOOR 22048337
    77to80 All DOOR SILL PLATE, LH OR RH, 2 Door models
    1708510
    77to80 4 Door DOOR SILL PLATE, FRONT, 4-DR 1708512
    77to80 4 Door DOOR SILL PLATE, REAR, 4-DR 1708514
    79to81 All Power Seat Switch assembly, 6 way, drivers side 20004764
    77to79 4 door Roof Drip Molding, on side of windshield, LH 20061803
    77to79 4 door Roof Drip Molding, on side of windshield, RH 20061804
    77to79 Caprice Door Molding, RH side, 2 door model 9634096
    80to81 Caprice Door molding, RH Front, 4 door models 9637159
    80to80 Caprice Rear door molding, RH side, 4 door model 9637162
    77to79 Station Wagon Rear wheel opening molding, RH 9634342
    80to89 Caprice Rear wheel opening molding, RH, Station Wagon Models 9637149
    80to89 Caprice Rear wheel opening molding, LH, Station Wagon Models 9637150
    80to89 Caprice Quarter panel molding, LH side, Lower, behind rear wheel 9637494
    77to81 Station Wagon Quarter Panel or front fender emblem. "Impala" 20074949
    77to78 Caprice LICENSE PANEL POCKET MOLDING, UPPER 9634084
    77to78 Caprice LICENSE PLATE POCKET MOLDING, LOWER 9634085
    79to79 Impala License plate pocket lower molding 9636433
    78to79 Caprice Trunk lid emblem, Caprice Crest, Trunk key goes in here 20060089
    84to84 Caprice License plate pocket Chrome Housing 20562602
    80to90 All Trunk lid emblem, Caprice Crest, Trunk key goes in here 20640496
    77to79 All Automatic trunk opener, electric 995250
    77to80 Caprice Roof side panel emblem. "Caprice Classic" 20079927
    77to78 All Quarter panel extension, RH, this bolts onto the rear of the qtr panel 9634866
    77to79 Impala rocker molding - left 458495
    77to79 Impala rocker molding - right 458496
    77to79 both dash analog clock 996242
    77to85 both overflow tank 14089113
    77to79 both power antenna relay 470363
    77to79 Caprice hood ornament 463759
    77to79 both fender - left 14002329
    79to79 both R+L front fender light blue metallic trim 1155286
    77to96 both Body bushings positions 1,2,3,4,5,6 pink 457915
    77to96 both Body bushing position 7, green 457917
    77to96 both Buick harmonics brace (rear frame brace) $16 10225142
    77to79 both 1979 Chevy Caprice / Impala Emblem 14007231
    77to96 both BUMP STOP, CONTROL ARM S10 ZQ8 15956547
    77to96 both CONTROL ARMS REAR AXLE KIT 10289786
    77to96 both 9C1 front sway bar � uses stock or 1LE links 457923
    77to96 both 9C1 rear sway bar 10207649
    77to96 both WS6 front sway bar � disco�d � salvage yard 356534
    77to96 both 95-96 1LE Camaro sway bar end links 10221779
    77to96 both 4th Gen (93-up) sway bar bushings 10288551
    77to96 both OIL - COOLER 9C1 AIR-TO-OIL COOLER 10226222
    77to96 both OIL - COOLER HOSE ASSEMBLY 9C1 10260341
    77to96 both OIL - COOLER NUT 12337917
    77to96 both OIL - COOLER PIPE 9C1 AIR-TO-OIL COOLER 10225895
    77to96 both OIL - COOLER PIPE 9C1 AIR-TO-OIL COOLER 10225896
    77to96 both OIL - COOLER SCREW 20351035
    77to96 both SPRINGS 1994-96 7B3 SUSPENSION - 9C1 22076523
    78to78 Caprice RH Headlight Molding (L shaped piece) 463196
    77to79 both bumper bracket 525739
    77to77 Caprice PARK LAMP BEZEL, LH, FRONT 371965
    77to77 Caprice PARK LAMP BEZEL, RH, FRONT 371966
    77to79 both Left Rear Wheel Well Molding 9634243
    77to79 both Door Edge Guards (pair) 995337
    77to79 both rear bumper guards 371979
    77to79 both rear bumper guards 371980
    79to79 both Bumper: Rear Center Filler 371931
    77to79 both Door pull strap escutcheon's and covers 20030995
    77to78 Caprice Drivers side front marker lamp lens 379785
    77 to 81 All Power Antenna kit 22039300
    77 to 77 Impala Washer Fluid Jar Assembly 1238291
    77 to 79 Caprice Pull Strap Escutcheon�s and Covers 20030995
    77 to 79 All Turn Signal Lever, no Cruise Control 469074
    77 to 79 All Shift Indicator Assembly 25015104
    77 to 92 All Center Link Assembly, Steering 26037646
    77 to 78 Wagon Side Vent Molding w/Woodgrain Sides 377895
    77 to 77 All Front (Dark Aqua) GM Floor Mats, rubber 995257
    77 to 78 Impala Front Bumper 463186
    77 To 79 All But 4 Door Chrome & Dark Carmine Met. Trim Molding60� long. Peel and Stick-on. 1154825
    77 to 78 Impala Front Grill Header Panel ??????
    77 to 77 Impala Coat Hooks 2001081
    77 to 77 Impala Gas Gauge - A/C-GM replacement parts 6432258
    77 to 78 Impala Left Front Parking and Turn Signal Lens 912861
    77 to 77 Caprice Tail Lamp Housing. Left Hand 5968457
    79 to 88 All Dash Cluster Temperature Gauge 25034007
    79 to 79 All Caprice / Impala Emblem - CHEVROLET 14007231
    79 to 79 Impala License Plate Light Pocket Assembly 20076192
    77 to 81 All Upper Front Control Arm Bushing 371793
    77 to 77 All Ignition switch - for TILT column ONLY 1990092
    75 to 79 Impala Car radio knobs 1224055
    77 to 78 Impala Left front park lamp assemblies 912861
    77 to 78 Impala Right front park lamp assemblies 912862
    77 to 79 All Left rear rubber bumper filler 371947
    77 to 79 All Right rear rubber bumper filler 371948
    77 to 79 All Left Front rubber bumper filler 367491
    77 to 79 All Right Front rubber bumper filler 367492
    77 to 79 All Right hand seat belt guide 20040010
    76 to 79 All Pulse Wiper Control Switch w/ Relay 22010011
    77 to 84 All scalp roof drip moulding 3073622
    77 to 79 Impala rear bumper strip 375651
    73 to 76 All Rear window defogger switch 3998476
    73 to 81 All Power seat switch base 1698469
    64 to 77 All Valve Cover Grommets for the PCV and breather 3989347
    77 to 78 Impala TURN SIGNAL/ PARKING LAMP LENS 912861
    77 to 80 All left rear side marker lamp 913153
    86 to 90 Caprice EXPORT taillight lens, RH (has AMBER lens) 16504178
    77 to 79 All fender dust shield, skirt, RH 371990
    77 to 79 All rear door glass channel weatherstrip 1718438
    77 to 78 all but wagons Left rear quarter marker lens 913153
    77 to 78 All FENDER LT. BLUE STICK-ON MOULDING 377859
    77 to 78 Impala LH Headlight Bezel 377289
    77 to 84 All Shift Indicator Assembly 25015104
    77 to 79 2 door 1/4 window molding RH 20029300
    77 to 79 Caprice Dome light lens, curved-rectangular 8780507
    77 to 79 Caprice RF parking light lens - clear 5965595
    77 to 79 4 Door rear door glass channel weatherstrip - L or R 1718438
    77 to 79 All Fuel tank sending unit 25000601
    79 to 79 Impala RH tail light lens 5970014
    77 to 77 Caprice LH tail light lens 5968461
    77 to 79 Caprice woodgrain finish radio face plate cover 375412
    79 to 81 All Wiper Link 22010448
    77 to 80 All Directional lever w/cruise control, black 25030492
    77 to 78 All Master cylinder rebuild kit old #5470766 18001017
    77 to 79 All Power Door lock switch assembly, Chrome 20043224
    77 to 79 All door edge guards for 4 door & wagons 995342
    79 to 79 Impala Grill 473684
    78 to 84 All Power Seat Motor 22009172
    77 to 79 Caprice 2 door- right hand door lower moulding 9634095
    77 to 79 All Front door lower hinge, RH 4dr cars ONLY 1713996
    77 to 79 All right hand outside door handle 20001544
    77 to 79 All Front door window regulator cams 9655398
    77 to 79 Caprice LH rear door chrome & black molding 9634099
    77 to 79 All RF bumper filler 367492
    79 to 79 Caprice LF side marker molding 475745
    79 to 79 Caprice RF side marker molding 475746
    79 to 79 Impala LR taillamp housing gasket 5970012
    79 to 79 Impala RR taillamp housing gasket 5970013
    77 to 79 Caprice RF moulding kit for in front of the wheel opening 9634240
    78 to 78 Impala upper grille moulding 463173
    79 to 93 All front brake hose 19173093
    77 to 79 All rear bumper extension fillers 371946
    69 to 81 All Turbo 350 transmission output ring gear 6261275
    75 to 79 All W/S washer pump switch and relay for pulse wipers 22010011
    76 to 79 All Rochester 4bbl carb choke housing (old # 17055234) 17055546
    77 to 83 All Heater/AC blower switch, AC Delco part number 15-71069
    77 to 80 All OSRV mirror interior escutcheon 20000664
    77 to 85 Caprice door pull strap escutcheon cover 20008916
    77 to 80 All temp selector knob, for auto temp control AC system 7898053
    77 to 81 All Shift lever knob, black 458893
    77 to 79 All Window motor, LH (drivers) side (old # 20004478) 22048337
    77 to 79 All Window motor, RH (pass) side (old # 20004479) 22048338
    Post  Sweet Seventy9 on Tue Sep 09, 2014 5:02 pm
    Part numbers for 91-96.
    Some other year/models mixed in.
    Probably some duplicates too.
    Page 1
    OEM PARTS
    ENGINE
    10105379 Stock 48mm throttle body gasket
    12524653 Intake manifold gasket set
    12552469 Exhaust manifold gasket set
    10168457 .043" head gaskets (LT4 Aluminum heads)
    12553160 .029" Head Gaskets (LT1 Cast Iron heads)
    Fel-1074 .039" head gaskets (LT1 Aluminum heads) * FelPro Part# *
    12369145 Head Gasket Kit (includes intake/heads(aluminum)/exhaust/etc)
    10128293 Front cover (timing cover) gasket
    12552428 Front cover Optispark Seal
    10128316 Front cover crank seal
    10474278 Distributor drive shaft seal
    12553792 Water pump drive seal
    10217886 Water pump front seal
    10128343 Water pump gasket (2)
    12527741 LT1 Water Pump F, Y body
    12527740 LT1 Water pump B body
    4060642 main serpentine belt
    4040372 fan belt for HDC equipped vehicles
    10046089 Centerbolt Valve Cover Gasket
    25171377 Oil Filter AC PF52(Duraguard)
    25325403 Oil Filter AC PF52(Duraguard Silver)
    25322836 Oil Filter AC PF52(Ultraguard Gold)
    10108676 Oil Pan Gasket
    12551589 Oil Filter Adapter gasket
    10244495 Oil Filter Adapter o-ring
    88893990 oil Filter Adapter Gasket & O-Ring.
    14090908 oil cooler tube seals (2)
    17113382 OEM EGR Valve
    17113381 F-Body EGR valve
    12337972 EGR Valve Gasket
    10055726 EGR Tube Gasket
    25095452 PCV VALVE
    12551389 PCV VALVE ELBOW
    10240678 PCV GROMMET
    12556257 PCV PIPE
    17113065 Evap canistor
    9438315 Evap hose
    460483 Engine valve oil seal
    10046089 iron head rocker cover
    25121978 fuel filter
    12370835 LT1/LT4 Extreme Duty Roller Timing Set
    12555885 LT1/LT4 Roller Timing Set Cam Gear (95+ LT1) or 94 + B-body
    12555886 Lt1/LT4 Roller Timing Set Crank Gear (95+ LT1) or 94 + B-body
    12555887 LT1/LT4 Roller Timing Set Roller Chain (95+ LT1) or 94 + B-body
    10128346 LT1 Link-Chain Timing Set Crank Sprocket
    10128485 LT1 Link-Chain Timing Set Link Chain
    10128349 95+ LT1 Link-Chain Timing Set Cam Sprocket or 94 + B-body
    10476885 Crank posistion sensor SEAL (96 only--OBD II)
    22146273 left motor mount (LT1)
    22146274 right motor mount (LT1)
    12555714 Rear main seal housing gasket
    17113086 Pressure regulator seal kit
    10115875 1LE AC delete pulley
    10260863 SEO Green upper radiator hose grp 1.159
    10197619 SEO Greenlower radiator hose 1.173
    10219447 SEO Green coolant rcvry reservoir hose 1.240
    10256544 SEO Green heater in/out hose assembly 8.846
    10258505 SEO Gree heater flow cont. vlv w/hoses 8.866 (also ACDelco 15-5508)
    10157988 coolant flow control valve 8.866 (also ACDelco 15-5423)
    12522867 Tee, heater water bypass 8.846
    52469251 Heater Core
    12556260 Pipe assy. from heads to coolant resvoir, includes seals and bolts
    10108689 Coolant pipe to head seals, 4 req.
    10204015 LH Export Headpipe
    10204014 RH ExportHeadpipe
    10168551 Exhaust Gasket
    10249851 10222996, Cat heat sheilds
    10279898 10279899, Muffler heat sheilds
    10191138 10203814, Fuel tank heat sheilds
    12551486 hub balancer
    9440024 hex bolt / hub balancer
    DRIVETRAIN(Tranny, 8.5" rear end)
    1234726 crush sleeve for 8.5" Axle
    26033578 Pinion Seal (Production piece)
    26064028 Pinion Seal (New design) will not work with standard yoke. Is part of the
    service kit.
    26066456 differential cover gasket, 2nd design
    24202310 S10 torque converter, 140 K factor.
    24204670 Torque converter alternate,135 K factor. 100 rpm or less difference than
    S-10 unit.
    12470387 Yoke Service Kit / Pinion flange
    26018943 3.08 reluctor B-body
    26018944 3.23 reluctor B-body
    26018945 3.42 reluctor B-body
    26018946 3.73 reluctor B-body
    12524176 Rear axle ABS sensor O-ring
    24210915 DEEP transmission pan--no drain plug
    24215535 DEEP transmission pan--with drain plug, Torx
    24213991 plug--hex head, for DEEP pan plug
    24208576 filter for deep trans pan
    BRAKES
    18022147 rear caliper guide pin
    14067559 rear guide pin bolt
    12337902 rear caliper bracket bolt
    14067552 rear caliper guide pin boot
    18021519 caliper brackets for 9C1 (cad plated)
    18021945 caliper brackets for Impala (black finish)
    18005606 front caliper bushing kit (one kit per car)
    18028256 Rear rotor Durastop 18A656
    18021049 Front rotor (non-Impala SS) ACD 177-754
    18021344 Front rotor (Impala SS) ACD 177-753
    18027999 Front rotor Durastop 18A399
    18039371 Front rotor Durastop HP 18A1030 (left)
    18039372 Front rotor Durastop HP 18A1031 (right)
    88917169 ACDelco 17 D614 C Ceramic front brake pads
    18021516 Emergency brake kit
    SUSPENSION/STEERING
    26014085 Steering shaft Assy.
    457915 body bushings, position 1,2,3,4,6 (Pink) lower mounts
    457917 body bushing, position 7 (Dk Green) lower mounts
    10221779 front swaybar endlinks
    88912214 Sway bar Link kit "performance" similar to 10221779 1LE Camaro
    88912477 Bumper,lower control arm, with self locking nut
    15989674 Bumper, lower control arm, from S10 ZQ8 suspension package. Can be
    ground down.
    88911336 Idler arm, Dana-Spicer sourced, with bonded blue poly seals
    26001594 Seal, power steering system, for metal pipe fitting connections
    Front lower control arm jounce (compression) bumpers:
    15989674 is 1st design ZQ8, urethane foam, configured like a stock rubber bumper
    15956547 is 2nd design ZQ8, urethane foam, much taller and more integrated into
    the overall spring rate--contacts frame to serve to contol the rate of suspension
    compression in conjuction with the spring & shock setup.
    This part is a possible tuning aid for autocross and road racing, and is now being
    used in current production ZQ8 & Extreme.
    10225142 Buick brace
    26055706 Power Steering New pump for 94-96 Chevy B w/N40 steering
    26060578 Power Steering Reman pump ACDelco 36-5510 (superseded by
    88985220)
    88985220 Power Steering Reman pump ACDelco 36-516309 (from Canada!)
    ELECTRICAL/COMPUTER/SENSORS
    12176639 Brass AUX Battery Post
    16188051 94-95 LT1 PCM
    10456126 Knock sensor 94-95
    10456287 Knock sensor 96
    16188309 Knock module - LT1 95 Impala SS
    16217700 Knock module - LT1 F-Body OBD-I
    16214661 Knock module - LT1 F-body OBD-II
    16214671 Knock module - LT1 Corvette
    16214681 Knock module - LT4 Corvette
    16214691 Knock module - LT1 Impala 2
    25008308 3.5" MAF sensor
    2503679 1 bar MAP sensor
    25312184 O2 Sensor
    1997223 EGR Solenoid
    1104032 Complete OptiSpark Distributor
    10457293 Optispark Cap & Rotor Kit (inc bolts/cover/o-rings)
    10455709 Starter--gear reduction, lightweight, new no core, from 92-96 LT1
    Corvette
    ACDelco EP376-- Fuel pump OE replacement
    ACDelco EP381-- Fuel pump higher output version
    1997201 Evap canister purge solenoid
    12555984 Evap canister purge switch
    10268235 Trunk light
    52455732 Blower motor resistor pack
    ITEM DESCRIPTION PART NUMBER EST COST
    12-DISC CD CHANGER CAN ONLY BE USED WITH
    CASSETTE PLAYER 12343958 $ 419.92
    12-DISC CD CHANGER HARNESS CAN ONLY BE USED WITH CASSETTE PLAYER
    12344015 $ 41.62
    350 HO CRATE MOTOR (330HP) 12486041 $ 2,166.50
    350 RAM JET MOTOR 350HP 12495515 $ 4,567.50
    502 RAM JET CRATE MOTOR 502HP 12497323 $ 8,550.00
    A.I.R. CHECK VALVE 12552898 $ 5.22
    A.I.R. PUMP CHECK VALVE 95-96 22048212 $ 11.77
    A.I.R. PUMP RELAY 14100455 $ 3.79
    A.I.R. SYSTEM DISABLE HOSE PLUG 12569122 $ 0.50
    A.I.R. SYSTEM DISABLE STICKER 12569123 $ 0.50
    A/C BLOWER MOTOR RESISTOR 52455732 $ 10.27
    A/C DELETE PULLEY 1LE 10115875 $ 34.09
    A/C VAC CHECK VALVE A/C DASHBOARD 52458911 $ 7.55
    A/C VACUUM CHECK VALVE VACUUM HOSE ON ENGINE 14056648 $ 2.73
    A/C COMPRESSOR RELAY 94 ONLY - AC #15-5671 12077866 $ 12.47
    A/C COMPRESSOR RELAY 95-96 ONLY 12088567 $ 8.64
    ABS SENSOR O-RING REAR AXLE 12524176 $ 2.23
    ACCELERATOR LINKAGE 10242904 $ 3.10
    ACCELERATOR LINKAGE BOLT 11505169 $ 4.00
    AIR BAG ASSEMBLY LIGHT GREY 16757619 $ 455.14
    AIR DEFLECTOR CENTER - 9C1 & SS 10109530 $ 5.58
    AIR DEFLECTOR SS - RIGHT 10161938 $ 3.36
    AIR DEFLECTOR SS - LEFT 10161939 $ 3.36
    AIR DEFLECTOR 9C1 - RIGHT 10220593 $ 3.36
    AIR DEFLECTOR 9C1 - LEFT 10220594 $ 3.36
    AIR DEFLECTOR BOLT FRONT AIR DAM - PK OF 10 10188889 $ 3.20
    AIR DEFLECTOR NUT-CLAMP PACK OF 10 11514407 $ 3.20
    AIR FILTER 25096932 $ 4.45
    AIR FILTER OUTLET DUCT PITCHER'S MOUND 25099478 $ 78.00
    AIR FILTER RESONATOR FRONT 25099945 $ 10.83
    AIR FILTER RESONATOR REAR 25162682 $ 48.74
    AIR INTAKE ELBOW 1LE - FOR VENTED OPTI 25147187 $ 43.82
    AIR INTAKE ELBOW 1LE - NO VENT FOR OPTI 25147210 $ 44.98
    AIR INTAKE ELBOW W/ATT 1LE 25147186 $ 42.83
    ALARM - VKE-1000 (OLD P/N 12495638) ADDS RPDL TO VEH W/PDL 12497735 $90.30
    ALARM - VSC-3100 (OLD P/N 12495644) SAME AS VKE-1000+ALARM 12497738 $128.00
    ALARM - VSC-3300 (OLD P/N 12495646) ADDS ALARM TO STOCK 12497739 $ 79.80
    ALARM - VSL-4100 (OLD P/N 12495648) COMP ALARM SYSTEM 12497741 $ 160.30
    ALARM - VSS-150 12344732 $ 107.80
    ALARM - VSS-2300 OLD P/N 12495642 12497737 $ 111.30
    ANTENNA (POWER) OLD P/N 22137934 88891017 $ 81.64
    ANTENNA CONNECTOR 12102668 $ 11.28
    ASHTRAY 10197140 $ 43.91
    AUX BATTERY POST 12176639 $ 8.16
    AXLE - 3.08 RELUCTOR B-BODY 26018943 $ 5.23
    AXLE - 3.23 RELUCTOR B-BODY 26018944 $ 6.44
    AXLE - 3.42 GEARS FACTORY RING & PINION 26029418 $ 329.52
    AXLE - 3.42 GEARS PINION SEAL 26033578 $ 9.37
    AXLE - 3.42 RELUCTOR B-BODY 26018945 $ 6.13
    AXLE - 3.73 RELUCTOR B-BODY 26018946 $ 7.06
    AXLE - 4.10 GEARS RING & PINION 26016309 $ 329.52
    AXLE - 4.10 GEARS MOTIVE GM MOT-26014585 $ -
    AXLE - CARRIER SIDE BEARINGS 3.42 GEARS 9420095 $ 20.20
    AXLE - DIFFERENTIAL COVER GASKET 2ND DESIGN 26066456 $ 3.25
    AXLE - DIFFERENTIAL COVER GASKET FELPRO RDS 55028-1 $ 14.75
    AXLE - DIFFERENTIAL LUBE 80W/90 1052271 $ 4.17
    AXLE - DIFFERENTIAL RETAINER PIN PACK OF 10 14056196 $ 8.90
    AXLE - FACTORY RING & PINION 14091497 $ 337.83
    AXLE - GEAR MARKING COMPOUND 1052351 $ 2.76
    AXLE - LIMITED SLIP ADDITIVE 1052358 $ 4.11
    AXLE - PINION CRUSH COLLAR 3.42 GEARS 1234726 $ 2.56
    AXLE - PINION FRONT BEARING 3.42 GEARS 9418356 $ 29.29
    AXLE - PINION NUT 1260823 $ 2.34
    AXLE - PINION REAR BEARING 3.42 GEARS 9413427 $ 28.78
    AXLE - PINION SEAL PRODUCTION PIECE 26033578 $ 9.28
    AXLE - PINION SEAL (NEW STYLE) WON'T WORK W/STOCK YOKE 26064028 $ 9.06
    AXLE - SEALS 554631 $ 8.86
    AXLE - YOKE SERVICE KIT CONT. NEW PINION FLANGE 12470387 $ 48.48
    BALANCER/DAMPER 93-95 12551138 $ 128.34
    BALANCER/DAMPER FLUIDAMPER 93-97 716910 $ 379.95
    BALANCER/DAMPER - LT1 GM 92-97 10128489 $ 300.51
    BALANCER/DAMPER BOLT 9440024 $ 1.35
    BALANCER/DAMPER HUB 93-95 B-BODY 10168570 $ 68.92
    BALANCER/DAMPER HUB 96 ? 12550097 $ 57.89
    BALANCER/DAMPER HUB 96-97 LT1 & LT4 12550098 $ 53.24
    BATTERY SEO HEAVY DUTY 1981590 $ 76.08
    BATTERY TRAY 10109535 $ 22.03
    BELT 9C1 W/HD COOLING 4040372 $ -
    BELT ACCESSORY 4060642 $ -
    BELT 12550149 $ 16.00
    BELT GATES 21MM X 1635MM K060637 $ -
    BELT TENSIONER 12552509 $ 26.36
    BODY BUSHING POSITION 7 - DK GREEN 457917 $ 4.66
    BODY BUSHINGS POSITION 1,2,3,4,6 - PINK 457915 $ 5.49
    BOOST GAUGE 0-10PSI/0-30"2-5/8" W/GMPP 12361397 $ 45.55
    BOOST GAUGE 0-10PSI/0-30"2-5/8" W/BOWTIE 12361405 $ 36.00
    BRAKE - BIAS VALVE 10223533 $ 50.47
    BRAKE - CALIPER LH REAR 18021517 $ 52.77
    BRAKE - CALIPER RH REAR 18021518 $ 52.77
    BRAKE - CALIPER BRACKETS 9C1 - CAD PLATED 18021519 $ 28.56
    BRAKE - CALIPER BRACKETS IMPALA - BLACK FINISH 18021945 $ 52.86
    BRAKE - EMERGENCY BRAKE KIT 18021516 $ 133.87
    BRAKE - FRONT CALIPER BUSHINGS ONE KIT PER CAR 18005606 $ 10.96
    BRAKE - FRONT PADS 18024928 $ 58.43
    BRAKE - FRONT PADS (CERAMIC) AC 17 D614C 88917169 $ 54.24
    BRAKE - FRONT ROTOR NON-IMPALA SS ACD 177-754 18021049 $ 117.59
    BRAKE - FRONT ROTOR IMPALA SS ACD 177-753 18021344 $ 125.13
    BRAKE - FRONT ROTOR DURASTOP #18A399 18027999 $ 81.88
    BRAKE - FRONT ROTOR (L) DURASTOP HP 18A1030 18039371 $ 136.13
    BRAKE - FRONT ROTOR (R) DURASTOP HP 18A1031 18039372 $ 136.13
    BRAKE - PADS EMERGENCY BRAKE 18021515 $ 42.43
    BRAKE - PROPORTIONING VALVE 10223533 $ 52.77
    BRAKE - REAR BRACKET CALIPER BOLT 12337902 $ 1.24
    BRAKE - REAR CALIPER BOLT GUIDE PIN 14067559 $ 0.82
    BRAKE - REAR CALIPER BOOT GUIDE PIN 14067552 $ 2.19
    BRAKE - REAR CALIPER, GUIDE PIN 18022147 $ 5.29
    BRAKE - REAR PADS 18021521 $ 50.33
    BRAKE - REAR ROTOR DURASTOP #18A656 18028256 $ 54.70
    BRAKE - UPPER LAMP ASSEMBLY 5976306 $ 34.80
    BUICK HARMONICS BRACE 10225142 $ 16.38
    BUMP STOP, CONTROL ARM S10 ZQ8 SUSPENSION 15989674 $ 7.42
    BUMPER COVER FRONT 10214403 $ 173.04
    BUMPER COVER REAR 10214405 $ 176.10
    BUMPER COVER RETAINER 10214402 $ 2.16
    BUMPER MOLDING FRONT - BLACK 10249326 $ 29.52
    BUMPER MOLDING REAR - BLACK RH 10249328 $ 13.26
    BUMPER MOLDING REAR - BLACK LH 10249329 $ 13.26
    BUMPER MOLDING FRONT - DGGM 10267871 $ 29.52
    BUMPER MOLDING FRONT - DCM 10267872 $ 29.52
    BUMPER REINFORCEMENT REAR 10161976 $ 118.86
    BUMPER REINFORCEMENT FRONT 10186281 $ 102.24
    CAMSHAFT CAMARO ZZ3 HO 350 CAM 10185071 $ 165.30
    CAMSHAFT LT1 10243779 $ 139.32
    CARPET GREY? 12528553 $ 287.13
    CARPET / MATS BLACK MAT SET FRONT 12370406 $ 32.90
    CARPET / MATS BLACK MAT SET REAR 12370411 $ 24.50
    CARPET / MATS GRAY REAR 12343594 $ 24.50
    CARPET / MATS GRAY FRONT 12343624 $ 24.50
    CARPET / MATS GREY CARPET 12528553 $ 272.71
    CARPET / MATS RETAINER LF DOOR 10253509 $ 14.52
    CARPET / MATS RETAINER LR DOOR 10222523 $ 4.68
    CARPET / MATS RETAINER RF DOOR 10253508 $ 14.52
    CARPET / MATS RETAINER RR DOOR 10222524 $ 4.68
    CAT HEAT SHEILD (1 OF 2) 10249851 $ -
    CAT HEAT SHEILD (2 OF 2) 10222996 $ -
    CD CHANGER 12-DISC 12462981 $ -
    CIGARETTE LIGHTER 11516141 $ 4.15
    CIGARETTE LIGHTER ASSEMBLY SOCKET & LIGHTER 11516142 $ 5.05
    CIGARETTE LIGHTER BEZEL RIGHT SIDE OF RADIO 10248599 $ 2.17
    CLIP - RETAINER ACC & CRUISE CABLES 20038997 $ 0.34
    CLOCK GAUGE 2-5/8" W/WHITE FACE/BOWTIE 12371180 $ 52.01
    COIN HOLDER LEFT OF STEERING WHEEL 10260084 $ 6.41
    CONNECTING RODS GM STOCK 5.7" - SET OF 8 12495071 $ 205.68
    CONNECTING RODS - STROKER EAGLE 5.7" 650G EAG-CRS5700B3D $ 495.95
    CONSOLE HINGE 22555614 $ 7.40
    CONSOLE LID 12531192 $ 74.74
    CONSOLE SHIFTER ASSEMBLY 10282773 $ 292.09
    CONSOLE SHIFTER PLATE TOP COVER - 96 10271069 $ 37.52
    CONTROL ARM - BUMP STOP NEW S10 ZQ8 DESIGN 15956547 $ 7.42
    CONTROL ARM - BUMP STOP W/SELF LOCKING NUT 88912477 $ 3.81
    CONTROL ARM - LOWER FRONT HEAVY DUTY 5/8" - LEFT 10282171 $ 108.77
    CONTROL ARM - LOWER FRONT HEAVY DUTY 5/8" - RIGHT 10282172 $ 108.77
    CONTROL ARM - REAR AXLE NUT 9C1 10255857 $ 5.65
    CONTROL ARM (HD) STEERING KNUCKLE LH - 5/8" 18021377 $ 165.93
    CONTROL ARM (HD) STEERING KNUCKLE RH - 5/8" 18021378 $ 165.93
    CONTROL ARM BOLT 9C1 REAR AXLE 11508196 $ 2.10
    CONTROL ARMS REAR AXLE KIT 10289786 $ 30.89
    COOLANT - DEXCOOL NOTICE STICKER 10283878 $ 5.49
    COOLANT - DEXCOOL RADIATOR CAP 10285918 $ 3.18
    COOLANT - FLOW CONT VALVE W/HOSES SEO GREEN - AC #15-5508 10258505 $ 61.37
    COOLANT - LEVEL SENS (8-WIRE) 12135027 $ 18.54
    COOLANT - RADIATOR HOSE SEO LOWER 10197619 $ 82.02
    COOLANT - RADIATOR HOSE UPPER SEO GREEN 10260863 $ 47.81
    COOLANT - RADIATOR HOSE KIT (?) SEO GREEN - 94 ONLY? 12522853 $ 7.60
    COOLANT - RADIATOR INSULATOR UPPER 10246557 $ 2.16
    COOLANT - RADIATOR OVERFLOW TANK 12528777 $ 34.85
    COOLANT - RADIATOR RECOVERY HOSE SEO GREEN 10219447 $ 55.36
    COOLANT - RADIATOR SUPPORT BRACE 12522746 $ 345.00
    COOLANT - RADIATOR TEE HEATER WATER BYPASS 12522867 $ 5.39
    COOLANT - STEAM PIPE ASSEMBLY 93-94-INCL SEALS & HOSE 10108635 $ 31.14
    COOLANT - STEAM PIPE CROSSOVER 95/96-INCL SEALS/HOSE/BOLTS 12556260 $ 24.91
    COOLANT - STEAM PIPE SEALS 93-96 10108689 $ 3.00
    COOLANT - TEMP GAUGE 140-250 2-5/8" W/WHITE FACE/BOWTIE 12371176 $ 40.37
    COOLANT - TEMP GAUGE140-240 2-5/8" W/GMPP ON FACE 12361394 $ 71.99
    COOLANT - TEMP GAUGE140-280 2-5/8" W/BOWTIE ON FACE 12361402 $ 47.93
    COOLANT - TEMP SENDING UNIT 10096181 $ 10.95
    COOLANT - TEMP SENSOR (GAUGE) AC #213-77 25037332 $ 10.30
    COOLANT - TEMP SENSOR (PCM) NEW P/N 15326386 12146312 $ 10.95
    COOLANT - TEMP SENSOR (PCM) AC# 213-310 15326386 $ 10.95
    COOLANT - TEMP SENSOR CONNECTOR 12102748 $ 12.26
    COOLANT FLOW CONTROL VALVE AC #15-5423 10157988 $ 7.47
    COOLANT LEVEL SENSOR 2-WIRE 10096163 $ 23.35
    COOLANT STEAM PIPE BOLTS 93-96 12552974 $ 3.07
    COOLING FAN RELAY 94-96 - AC #15-8733 12193604 $ 14.29
    Corvette Fuel - Rail Cover (lh) 10208795 $ 7.58
    Corvette Fuel - Rail Cover (rh) 10208794 $ 7.58
    Corvette Fuel - Rail Cover (rh) Steel Velve Covers 1022493692 $ 22.40
    Corvette Fuel Rail Cover Hose Brake Vacuum Booster 10214035 $ 6.16
    Crank Position Sensor Seal 96 Only--obd Ii 10476885 $ 0.86
    Crankcase Vent Hose 93-96 - Fm V/c To T/b 10128365 $ 5.24
    Crankchaft - Rear Main Seal Housing 93-96 14088556 $ 26.83
    Crankshaft Lt1 - Old P/n 12551485 12556307 $ 605.00
    Crankshaft Rear Main Hsg Gasket 93-96 12555771 $ 2.23
    Crankshaft Rear Main Seal 93-96 10088158 $ 14.01
    Crankshaft Rear Main Seal Rev Gm Lt4 Double Lip 12554314 $ 14.64
    Crankshaft Seal - Front 93-96 10128316 $ 5.74
    Cruise Control Module 25140793 $ 212.32
    Cup Holder Console Insert 10261527 $ 2.24
    Cylinder Block Ls6 12561166 $ 1,155.00
    Cylinder Head Lt1 Aluminum 10207643 $ -
    Cylinder Head Stock Lt4-complete 12363287 $ 615.30
    Cylinder Head Hp Lt1 Iron 12480092 $ 300.41
    Cylinder Head Lt1 12529741 $ 363.76
    Cylinder Head Hp Lt4 - Hot Cam 12556463 $ 463.83
    Cylinder Head Dowel Pin 93-97 585927 $ 0.23
    Cylinder Head Gasket Lt1 Aluminum - .049" Comp 10168457 $ 20.63
    Cylinder Head Gasket Lt1 Iron - .029" Comp 12553160 $ 18.67
    Cylinder Head Gasket Felpro - Lt1 Aluminum .039" Fel-1074 $ 34.99
    Cylinder Head Gasket Kit For Aluminum Heads 12369145 $ 167.06
    Cylinder Head Ls6 12560801 $ 620.78
    Cylinder Head Studs Arp P/n Arp-11-235-4103 $ -
    Dash Pad (gray) 10248200 $ 218.49
    Dash Plate Impala Ss 10250947 $ 3.84
    Dash Plate Caprice Ss 10268239 $ 9.22
    Detail Kit In A Case With Bowtie Logo 12344998 $ 10.94
    Dexcool Gallons 12346290 $ 8.99
    Door Courtesy Lamp 16671511 $ 11.63
    Door Handle Black 16627914 $ 32.44
    Door Handle Primed(?) 10273578 $ 7.32
    Door Lock Module 6n1 - Police 166300597 $ 5.83
    Door Panel - Outer Shell Lr 10190343 $ 117.48
    Door Panel - Outer Shell Rr 10190342 $ 117.48
    Door Panel Inner Shell Lh 10250953 $ 469.39
    Door Panel Inner Shell Rh 10250952 $ 469.39
    Door Panel Outer Shell Lf 12521582 $ 253.38
    Door Panel Outer Shell Rf 12521583 $ 243.54
    Door Panel Retainers (20) 15600382 $ 7.20
    Door Pull Black 16671421 $ 89.61
    Door Sill Plate Front Drivers 10111989 $ 12.54
    Door Swicth Lamp Blue Pontiac 10031004 $ 0.99
    Door Trim - Wood Grain Bezel 16671169 $ 26.30
    Driving Light Lamp Assy Switch 20669667 $ 23.79
    Egr - Block-off Plate 10054880 $ 4.44
    Egr - Pipe Gask 94-96 10055726 $ 2.12
    Egr - Solenoid Valve 1997223 $ 12.67
    Egr - Valve B-body 17113382 $ 39.32
    Egr - Valve F-body 17113381 $ 39.32
    Egr & Egr Block-off Plate Gasket Ac #219-21 12337972 $ 0.46
    Electrical Recall Parts Nut&stud Assembly 11516161 $ 0.20
    Electrical Recall Parts Busbar Cavity 12129481 $ 3.18
    Electrical Recall Parts Busbarcavity 12146182 $ 3.92
    Electrical Recall Parts Center Stud 12146183 $ 0.90
    Electrical Recall Parts Stud Assembly 12161130 $ 8.49
    Electrochromic Mirror With Compass 12344614 $ 201.23
    Emblem - C Pillar New P/n 10424490 10253594 $ 3.99
    Emblem - C Pillar New P/n 10424491 10253595 $ 3.99
    Emblem - C Pillar Right - Old P/n 10253594 10424490 $ 4.85
    Emblem - C Pillar Left - Old P/n 10253595 10424491 $ 4.85
    Evap - Bracket Fuel Tank Evap - Cont 10229207 $ 2.45
    Evap - Bracket Bolt 11516061 $ 0.66
    Evap - Canister Bracket 12553048 $ 8.21
    Evap - Canister Bracket Bolt 12551177 $ -
    Evap - Canister Bracket Nut 11514596 $ 2.84
    Evap - Canister Bracket Retainer Pack Of 10 10009923 $ 3.30
    Evap - Canister Bracket Screw Pack Of 10 11509509 $ 6.80
    Evap - Canister Check Valve Vacuum 12124134 $ 2.17
    Evap - Canister Purge Solenoid 1997201 $ 14.89
    Evap - Canister Purge Switch 12555984 $ 9.45
    Evap - Canistor 17113065 $ 35.31
    Evap - Hose 9438315 $ 33.29
    Evap - Solenoid Hose From Throttle Body 10105324 $ 4.47
    Exhaust - Manifold Lh 10168494 $ 144.13
    Exhaust - Manifold Rh 12524289 $ 83.59
    Exhaust - Manifold Lh 12552896 $ 146.04
    Exhaust - Manifold Rh 12556731 $ 137.77
    Exhaust - Manifold Gasket Felpro - Reg Square Fel-1404 $ 18.95
    Exhaust - Manifold Gasket Felpro - Big Square Fel-1405 $ 18.95
    Exhaust - Manifold Gasket Felpro - Big "d"-port Fel-1406 $ 18.95
    Exhaust - Manifold Gasket 93-96 12552469 $ 6.02
    Exhaust - System Insulator Large 10243316 $ 2.34
    Exhaust - System Insulator Small 10217783 $ 2.34
    Exhaust - Export Emissions Sticker - 94 12551376 $ 6.15
    Exhaust - Export Emissions Sticker - 95 10243955 $ 6.15
    Exhaust - Export Emissions Sticker - 96 12553939 $ 6.15
    Exhaust - Export Pipe Lh 10204015 $ 59.30
    Exhaust - Export Pipe Rh 10204014 $ 59.30
    Exhaust - Export Pipe Stud 10 Per Pack 10220453 $ 10.80
    Exhaust - Export Pipe Gasket 10168551 $ 4.41
    Factory Service Manuals 2-volume Set Gmp96b $ 110.00
    Fan - Blower Motor Relay 12193601 $ 15.76
    Fan - Thermostatic Switch 30531901 $ 8.63
    Fan Shroud 10281083 $ 22.84
    Fender Left Front 12501861 $ 184.50
    Fender Right Front 12501860 $ 184.50
    Fender Liner Left Front 12522388 $ 276.78
    Fender Liner Right Front 12522387 $ 276.78
    Flywheel 14088765 $ 62.40
    Fuel - Filter Ac #gf578 25121293 $ 9.09
    Fuel - Filter 25121978 $ 14.32
    Fuel - Injector 93-96 17124248 $ 61.28
    Fuel - Injector O-ring Seal Kit Ac #217-1379 17113544 $ 9.92
    Fuel - Line Retainers On Side Of T/b 12048089 $ 2.21
    Fuel - Ppress Gauge 0-15 2-5/8" W/bowtie 12371178 $ 34.93
    Fuel - Press Reg Vacuum Hose 10216948 $ 2.10
    Fuel - Psi Gauge 0-15 2-5/8" W/bowtie 12361404 $ 104.32
    Fuel - Psi Gauge 0-15 2-5/8" W/gmpp 12361396 $ 119.75
    Fuel - Psi Gauge Tubing Kit Braded S/s 12361398 $ 51.98
    Fuel - Pump High Output Acdelco Ep381 $ -
    Fuel - Pump Stock Acdelco Ep376 $ -
    Fuel - Pump Relay 94-96 - Ac #15-5671 12077866 $ 12.47
    Fuel - Pump Relay 93-96 12193601 $ 15.76
    Fuel - Rail 94-96 Rh 17113251 $ 194.69
    Fuel - Rail Cover Corvett - Rh Side 10224936 $ 17.80
    Fuel - Rail Cover Stud Vett 10108672 $ 1.02
    Fuel - Rail Kit Parts For Return Line 17113095 $ 20.52
    Fuel - Tank Heat Sheild (1 Of 2) 10191138 $ 2.27
    Fuel - Tank Heat Sheild (2 Of 2) 10203814 $ 2.27
    Fuel - Tank Level Sending Unit 25028955 $ 171.10
    Glove Box Latch 12527729 $ 9.32
    Grille Black 10269614 $ 56.82
    Grille Dggm 10269615 $ 63.42
    Grille Dcm 10269616 $ 63.42
    Grille Bowtie Chrome 10249082 $ 7.96
    Grille Emblem Blue Bowtie 22591876 $ 5.40
    Grille Emblem Red Bowtie 22591877 $ 4.56
    Grille Emblem Red "ss" 15970086 $ 8.58
    Headlight - Capsule Left 16519235 $ 104.76
    Headlight - Capsule Right 16519236 $ 104.76
    Headlight - Connector Export T84 Capsule 6288471 $ 0.63
    Headlight - Export T84 Capsule Left 16519237 $ 197.28
    Headlight - Export T84 Capsule Right 16519238 $ 197.28
    Headlight - Mounting Bracket Left 16511961 $ 28.32
    Headlight - Mounting Bracket Right 16511962 $ 28.32
    Headlight - Opening Filler Right 10161998 $ 8.64
    Headlight - Opening Filler Left 10161999 $ 8.64
    Headlight - Terminal Export T84 Capsule 6294068 $ 0.34
    Headliner 10279131 $ 178.15
    Heater Core 52469251 $ 94.00
    Heater Core Hose In/out Assembly Seo Green 10256544 $ 44.84
    Heater Distributor Rear Floor Ducts 10164972 $ 7.72
    Heater Outlet Rh Rear Floor Ducts 10164974 $ 9.34
    Heater Outlet Lh Rear Floor Ducts 10164975 $ 9.34
    Heater Retainer Rear Duct 20030401 $ 2.16
    Hood 10248301 $ 381.96
    Hood Hinge 10109664 $ 13.15
    Hood Hinge 10109665 $ 13.15
    Hood Insulation S&h Is About $40! 10196123 $ 50.64
    Hood Insulator Retainer 20064875 $ 0.78
    Hood Lamp - Discontinued 10203566 $ -
    Hood Lamp Connector New P/n 15306195 12101899 $ 9.49
    Hood Lamp Connector 15306195 $ 9.49
    Horn Cadillac Horn D Note 1892162 $ 21.37
    Horn Cadillac Horn C Note 1892246 $ 21.93
    Hose Clamp Vett Plastic Vlv Cover 10128361 $ 2.34
    Hub, Balancer/damper 93-95 ? 12553250 $ 48.40
    Hydraulic Lifter 93-95 5234890 $ 21.05
    Hydraulic Lifter 96 17120735 $ 21.05
    Hydraulic Lifter Kit 16-17120735 Lifters, 8-12550002 Guides, 16-14101116 Retainer,
    4-24501365 Bolts, 4-120386 Washers. 12371042 $ 174.66
    Hydraulic Lifters Cc High Energy Cca-850-16 $ -
    Ignition - Coil 93/ac #d535 1115315 $ 28.16
    Ignition - Coil - 94-95 Ac #d573 10477208 $ 27.64
    Ignition - Coil - 96 Ac #d577 10489421 $ 25.40
    Ignition - Coil - Wire - 93-95 Ac Part # 340r 12096466 $ 11.61
    Ignition - Coil - Wire - 96 Ac Part # 346u 12173578 $ 11.24
    Ignition - Control Module - 93 Ac #d1971a 10483131 $ 68.76
    Ignition - Control Module - 94-95 Ac #d1986a 10483139 $ 53.10
    Ignition - Control Module - 96 Ac #579 10482803 $ 61.41
    Inlet - Air Temp Sensor (iat) New P/n 12160244 12110319 $ 8.36
    Instrument Cluster Lens 16164576 $ 9.93
    Instrument Cluster Trim Beze 10250238 $ 16.18
    Intake - Air Temp (iat) Sensor 12160244 $ 8.36
    Intake Bellows Thunder Racing 20-25147187 $ -
    Intake Gaskets Felpro Fel-1284 $ 26.39
    Intake Manifold Lt1 12552137 $ 423.14
    Intake Manifold Gasket Gm Lt4 - Raised Ports 12367777 $ 13.58
    Intake Manifold Gasket Set Lt1 12524653 $ 17.85
    Jack 10231273 $ 35.44
    Keyless Entry Fob 10239647 $ 50.40
    Keyless Entry Receiver 12499735 $ 90.30
    Keyless Entry Transmitter 94-95 15725423 $ 33.60
    Keyless Entry Transmitter 96-02 16245100 $ 31.66
    Knock Module 94/95 Ss 16188309 $ 29.82
    Knock Module F-body Obd-ii 16214661 $ 29.07
    Knock Module Vett 16214671 $ 28.92
    Knock Module Lt4 16214681 $ 29.92
    Knock Module 96ss 16214691 $ 25.88
    Knock Module F-body Obd-i 16217700 $ -
    Knock Sensor - Lt1 93-95 - Ac #213-96 10456126 $ 17.32
    Knock Sensor - Lt1 96 - Ac #213-325 10456287 $ 25.42
    Ls1 Engine Crate Motor-320hp 25534322 $ 5,666.50
    Ls1 Engine 97-98 Vett 12455109 $ 5,125.61
    Ls1 Engine 98 F-car - Old P/n 12455110 88894086 $ 4,831.84
    Ls1 Engine 98 F-car - New P/n 88894086 12455110 $ 4,831.84
    Ls1 Engine 98 F-car - Old P/n 88894086 88894386 $ 4,831.84
    Ls1 Engine 98 F-car - New P/n 88894386 88894086 $ 4,831.84
    Ls1 Engine 99-00 F-car - Old P/n 12457659 88890545 $ 5,125.61
    Ls1 Engine 99-00 F-car - New P/n 88890545 12457659 $ 5,125.61
    Ls1 Engine 99-00 F-car - Old P/n 88893287 88890545 $ 5,125.61
    Ls1 Engine 99-00 F-car - New P/n 88890545 88893287 $ 5,125.61
    Ls1 Engine 99 Vett - New P/n 88890543 12457660 $ 5,171.75
    Ls1 Engine 99 Vett - Old P/n 12457660 88890543 $ 5,171.75
    Ls1 Engine 00 Vett - New P/n 88890544 88893286 $ 5,125.61
    Ls1 Engine 00 Vett - Old P/n 88893286 88890544 $ 5,125.61
    Ls1 Engine 01-04 Vett - New P/n 89017548 89017348 $ 4,875.33
    Ls1 Engine 01-04 Vett - Old P/n 89017548 89017548 $ 4,875.33
    Ls1 Engine 01-04 Vett - New P/n 89017548 89017384 $ 4,875.33
    Ls1 Engine 01-04 Vett - Old P/n 89017384 89017548 $ 4,875.33
    Ls1 Engine 01-04 Vett - New P/n 89017548 89017275 $ 4,875.33
    Ls1 Engine 01-04 Vett - Old P/n 89017275 89017548 $ 4,875.33
    Ls1 Engine 01-04 Vett - New P/n 89017548 88984271 $ 4,875.33
    Ls1 Engine 01-04 Vett - Old P/n 88984271 89017548 $ 4,875.33
    Ls2 Engine - Longblock 05 Vett 89017654 $ 5,299.23
    Ls6 Engine 01 Vett - New P/n 88894384 88894057 $ 5,125.61
    Ls6 Engine 01 Vett - Old P/n 88894057 88894384 $ 5,125.61
    Ls6 Engine 03-04 Vett - New P/n 89017349 88984272 $ 5,125.61
    Ls6 Engine 03-04 Vett - Old P/n 88984272 89017349 $ 5,125.61
    Ls6 Engine 03-04 Vett - New P/n 89017349 88894254 $ 5,517.75
    Ls6 Engine 03-04 Vett - Old P/n 88894254 89017349 $ 5,517.75
    Ls6 Engine 05 Caddy - New P/n 89017653 89017350 $ 5,517.75
    Ls6 Engine 05 Caddy - Old P/n 89017350 89017653 $ 5,125.61
    Lt1 Engine - 94-95 B-body New P/n 88894193 12513026 $ 4,815.98
    Lt1 Engine - 94-95 B-body Old P/n 12513026 88894193 $ 4,815.98
    Lt1 Engine - 96 B-body New P/n 88894194 12533599 $ 4,815.98
    Lt1 Engine - 96 B-body Old P/n 12533599 88894194 $ 4,815.98
    Lt1 Engine - 95 F-fody New P/n 88894195 12524896 $ 5,090.80
    Lt1 Engine - 95 F-fody Old P/n 12524896 88894195 $ 5,090.80
    Lt1 Engine - 96-97 F-fody New P/n 88894197 12533597 $ 5,042.83
    Lt1 Engine - 96-97 F-fody Old P/n 12533597 88894197 $ 5,042.83
    Lt1/lt4 Nitrous Kit (complete) Clear Image Automotive Irs-nxpkg4 $ 925.00
    Lt4 - Accelerator Linkage Cover 10260166 $ 4.16
    Lt4 - Balancer/damper F&y-body Lt4 Only 12551486 $ 305.32
    Lt4 - Camshaft Hot Cam Kit 12480002 $ 475.30
    Lt4 - Camshaft Hot Cam 24502586 $ 171.85
    Lt4 - Cylinder Head Gasket Stock Lt4 - .050" Comp 12551488 $ 20.63
    Lt4 - Cylinder Head Gasket Lt4 - .051" Comp Thick 12557236 $ 11.80
    Lt4 - Cylinder Head Stud Lt4 12552126 $ 3.13
    Lt4 - Engine (discontinued) New P/n 88894198 12551183 $ 6,253.42
    Lt4 - Engine (carb - Not Efi) Old P/n 12551183 88894198 $ 6,253.42
    Lt4 - Exhaust Valve 12551313 $ 30.63
    Lt4 - Head Bolt Kit 12495499 $ 18.62
    Lt4 - Intake Valve 12555331 $ 26.52
    Lt4 - Timing Chain - Extreme Duty 12370835 $ 202.14
    Lt4 - Valve Cover Bolt Lt4 Plastic Cover 12338092 $ 0.75
    Lt4 - Valve Cover Washer 14094717 $ 2.19
    Lt4 - Valve Lock Set Of 32 12495503 $ 5.83
    Lt4 - Valve Retainer Set Of 16 12495492 $ 11.26
    Lt4 - Valve Spring Max .525" Lift - Set Of 16 12495494 $ 26.01
    Lt4 - Valve Spring 12551483 $ 5.16
    Lt4 - Valve Stem Key Pack Of 10 24503856 $ 6.30
    Lug Nuts Set Of 5 12337955 $ 12.15
    Maf Sensor F-body 25008308 $ 210.35
    Maf Sensor - Extension Cable 12529241 $ 37.61
    Map Sensor New P/n 12569240 16137039 $ 30.65
    Map Sensor (old P/n 16137039) 94-96/ac #213-185 12569240 $ 30.65
    Map Sensor Seal 94-96 1635948 $ 2.12
    Metri-pak Terminals (10pk) 12047767 $ 4.70
    Mirror - Inside Rearview With Compass 12371585 $ 167.00
    Mirror Lh Outside 95/96 10231121 $ 114.00
    Mirror Lh Outside 93/94 10231161 $ 72.00
    Mirror Rh Outside 95/96 10231120 $ 114.00
    Mirror Rh Outside 93/94 10231160 $ 72.00
    Mirror, Inside Auto Dim W/map Lights 10263981 $ -
    Molding - Rear Side (?) New P/n 12482046 12522932 $ 31.69
    Molding - Rear Side (?) 12522934 $ 5.10
    Molding - Rear Side (?) 12522935 $ 5.10
    Molding - Wheel Well Front Black Lh 12522931 $ 25.50
    Molding - Wheel Well Rear Black Lh 12522937 $ 25.83
    Molding - Wheel Well Front Dggm Rh 12524186 $ 29.10
    Molding - Wheel Well Front Dggm Lh 12524187 $ 29.10
    Molding - Wheel Well Front Dcm Rh 12524188 $ 29.10
    Molding - Wheel Well Front Dcm Lh 12524189 $ 29.10
    Molding - Wheel Well Rear Dggm Rh 12524194 $ 24.12
    Molding - Wheel Well Rear Dggm Lh 12524195 $ 24.12
    Molding - Wheel Well Rear Dcm Rh 12524196 $ 24.12
    Molding - Wheel Well Rear Dcm Lh 12524197 $ 24.12
    Molding - Wheel Well Front Black Rh 12522930 $ 25.50
    Molding - Wheel Well Rear Black Rh 12522936 $ 25.83
    Molding Kit Frt S/d Lwr (left) 12516867 $ 59.70
    Molding Rear Side (?) 12482045 $ 31.69
    Molding Rear Side (?) 12482046 $ 31.69
    Motor Mount Lt1-left 22146273 $ -
    Motor Mount Lt1-right 22146274 $ -
    Muffler Heat Sheild (1 0f 2) 10279898 $ 5.80
    Muffler Heat Sheild (2 0f 2) 10279899 $ 5.80
    Net Cargo Package 12343477 $ 21.00
    Nut 12337917 $ 0.70
    Nut Clip Sheet Metal 15966491 $ 1.00
    Oil - Cooler 9c1 Air-to-oil Cooler 10226222 $ 56.10
    Oil - Cooler Hose Assembly 9c1 Air-to-oil Cooler 10260341 $ 33.58
    Oil - Cooler Nut 12337917 $ 0.70
    Oil - Cooler Pipe 9c1 Air-to-oil Cooler 10225895 $ 8.61
    Oil - Cooler Pipe 9c1 Air-to-oil Cooler 10225896 $ 8.61
    Oil - Cooler Screw 20351035 $ 0.55
    Oil - Cooler Tube Seal 2 Required 14090908 $ 0.75
    Oil - Drain Plug Gm Magneticplug 23011420 $ 9.13
    Oil - Fill Cap Vett Plastic Valve Cover 10108694 $ 1.54
    Oil - Fill Cap Steel Valve Covers 10229162 $ 2.65
    Oil - Fill Cap Valve Cover Magnesium 12558300 $ -
    Oil - Fill Cap Lt4 - Mobil 1 12554955 $ 2.04
    Oil - Fill Sticker Lt4 - Mobil 1 10236268 $ 6.15
    Oil - Filter Ac #pf52 - Duraguard 25171377 $ 3.23
    Oil - Filter Ac #pf52 - Ultraguard Gold 25322836 $ 6.09
    Oil - Filter Adapter Gasket 12551589 $ -
    Oil - Filter Adapter Kit Includes Gasket & O-rings 88893990 $ 2.04
    Oil - Filter Adapter O-ring 10244495 $ -
    Oil - Level Sensor (low) 24507190 $ 18.45
    Oil - Pan Gasket 10108676 $ 27.00
    Oil - Pan Rail Lh 14088501 $ -
    Oil - Pan Rail Rh 14088502 $ -
    Oil - Pan Windage Tray Gm 12554816 $ 3.13
    Oil - Pressure Sensor Impala Ss 24507190 $ 26.44
    Oil - Psi Gauge 0-100 Psi 2-5/8" W/gmpp On Face 12361392 $ 42.42
    Oil - Psi Gauge 0-100 Psi 2-5/8" W/bowtie On Face 12361400 $ 30.30
    Oil - Psi Gauge 0-100 Psi 2-1/16" White Face/bowtie 12371175 $ 49.30
    Oil - Psi Sender Seo Police 10201491 $ 16.91
    Oil - Psi Sensor 90 Fitting 10137636 $ 6.04
    Oil - Pump W/o Pick-up 12555884 $ 54.20
    Oil - Temp Gauge 140-280 2-5/8" W/gmpp On Face 12361393 $ 67.22
    Oil - Temp Gauge 140-280 2-5/8" W/bowtie On Face 12361401 $ 47.93
    Oil - Temp Sending Unit 10096181 $ 10.95
    Oil - Temp Sendsor Connector 12102748 $ 12.26
    Optispark - Elect Harness 93-94 - Non-vented 12106559 $ 55.19
    Optispark - Electrical Harness 95-96 - Vented 12130319 $ 67.70
    Optispark - Fitting Gm Vac 14082470 $ 2.32
    Optispark - Non-vented 93-94 10457702 $ 326.00
    Optispark - Rebuild Kit 95-96 - Ac #d8301 10457293 $ 106.85
    Optispark - Shaft O-ring Pack Of 10 10474278 $ 7.60
    Optispark - Shaft Seal 93-94 10128317 $ 2.22
    Optispark - Shaft Seal 95-96 12552428 $ 3.68
    Optispark - Vent & Vac Harness 95-1997 12555323 $ 11.58
    Optispark - Vented 95-1997 1104032 $ 234.00
    Oxygen Sensor Ac #afs75 25312184 $ 35.63
    Pcm 96ss - $200 Core 16214399 $ 115.00
    Pcm (new P/n 88961150) 94-95ss - $300 Core 16188051 $ 114.29
    Pcm (old P/n 16188051) 94-95ss - $300 Core 88961150 $ 114.29
    Pcm Calibration - 94 Initial 9416200341 $ -
    Pcm Calibration - 94 Update Improve Air Performance 9416202491 $ -
    Pcm Calibration - 94 Update Fix Shift Clunk/cold Surge 9416207221 $ -
    Pcm Calibration - 94 Update Fix For Chuggle And Surge 9416232021 $ -
    Pcm Calibration - 95 Initial 9516206641 $ -
    Pcm Calibration - 95 Update Improve Driveability 9516209351 $ -
    Pcm Calibration - 95 Update Correct Chuggle & Surge 9516232011 $ -
    Pcm Calibration - 96 Initial 9616229981 $ -
    Pcm Connectors (5pk) 12084913 $ 5.75
    Pcv Grommet - Intake Manifold Vett Plastic Valve Cover 10240678 $ 2.14
    Pcv Pipe 12556257 $ 5.33
    Pcv Valve 93-96/ac #cv895c 25095452 $ 4.10
    Pcv Valve Elbow 12551389 $ 2.12
    Piston Srp-4.030, 16cc, 5.7" Rod 139628 $ -
    Piston Ring Speedpro 4.030 R-9401 35 $ -
    Power Antenna New P/n 88891017 22137934 $ 54.43
    Power Antenna Old P/n 22137934 88891017 $ 54.43
    Power Antenna Relay 22535475 $ 6.44
    Power Seat Switch 6-way 10099012 $ 26.00
    Power Window Switch Rear 10188907 $ 18.99
    Pressure Regulator Seal Kit 17113086 $ 4.20
    Pushrod Kit Contains 16 12371041 $ 20.92
    Pushrods Cc Hardened Cc-7940-16 $ -
    Racks & Carriers ??? 10041121 $ 49.70
    Radio Cassette Player 15757172 $ 302.95
    Radio Cd Player 15071233 $ 401.68
    Rearview Mirror Adhesive 1052369 $ 3.12
    Rocker Arms Stamped Steel 1.5 12495490 $ 43.40
    Rocker Arms Cc Pro Mag 1.6 W/ 7/16" Stud Cca-1305-16 $ -
    Roller Rockers 1.6 Ratio Gm Spec Crane R/r 12370839 $ 261.33
    Page 2
    Seat 16726726 $ 80.82
    Seat 16731968 $ 140.49
    Seat Belt Kit Front Lh 12513339 $ 62.51
    Seat Belt Kit Front Rh 12513338 $ 62.51
    Seat Cover Front Lower Cushion 16780068 $ 215.24
    Shock - Air 22003254 $ 74.05
    Shock Absorbers Front 22064600 $ 122.68
    Shock Absorbers Rear 22064499 $ 95.29
    Side Script Impala Ss Black 10248742 $ 17.04
    Side Script Impala Ss Dggm 10262808 $ 17.04
    Side Script Impala Ss Dcm 10262809 $ 17.04
    Side Script Caprice Ss - Black 10267037 $ 31.85
    Side Script Caprice Ss - Dggm 10267038 $ 31.85
    Side Script Caprice Ss - Dcm 10267039 $ 31.85
    Spark Plug 25166821 $ 4.16
    Spark Plug Wire Set 12096437 $ 58.07
    Spark Plug Wire Set 12173568 $ 96.07
    Spoiler 12524697 $ 262.06
    Spoiler - Bolts 12337977 $ 0.63
    Springs 1995 Rear - 18.0 N/mm Rc 22076517 $ 44.29
    Springs 1994-96 7b3 Suspension - 9c1 22076523 $ 41.72
    Springs 1995 Rear - 27.0 N/mm Rx 22076526 $ 44.29
    Springs Highest Load Rate-95 Front 22078017 $ 61.85
    Springs 1995 Rear - Stock 22132375 $ 44.29
    Starter Lt4 - No Core Charge!!! 10455709 $ 144.77
    Starter 25.00 Core Charge 10465143 $ 176.74
    Starter 45.00 Core Charge 10465293 $ 140.16
    Steering - Connection Seal Pack Of 10 26001594 $ 16.60
    Steering - Cooler Bolt 11509363 $ 3.80
    Steering - Cooler Clamp 2091638 $ 2.02
    Steering - Cooler Nut 11518121 $ 0.94
    Steering - Cooler Pipe 26036034 $ 20.14
    Steering - Damper Buick Style 4993536 $ 225.36
    Steering - Damper Bolt 454947 $ 3.79
    Steering - Damper Bracket 10245794 $ 18.40
    Steering - Damper Nut Sold In Pack Of 10 9442937 $ 3.20
    Steering - Damper Rod Kit 26059109 $ 122.21
    Steering - Fluid Sold In Pack Of 12 1050017 $ 42.00
    Steering - Gear Box 26048653 $ 474.75
    Steering - Idler Arm (dana-spicer) W/bonded Blue Poly Seals 88911336 $ 22.53
    Steering - Idler Arm (stock) 26041013 $ 55.53
    Steering - Pump (new Style) 94-96 W/n40 Steering 26055706 $ 214.30
    Steering - Pump (reman) New P/n 88985220 26060578 $ 53.93
    Steering - Pump (reman) Ac 36-516309 - $25 Core 88985220 $ 53.93
    Steering - Shaft Assembly 26014085 $ 131.96
    Steering - Stop Larger Than Stock - Lh 10225365 $ 6.47
    Steering - Stop Larger Than Stock - Rh 10225366 $ 6.47
    Steering - Wheel Grey W/air Bag 16757633 $ 271.57
    Swaybar - (ha) Front Mor-86015 $ -
    Swaybar - (ha) Rear Mor-86516 $ -
    Swaybar - Bushings 32mm For Ha Swaybar 26039956 $ -
    Swaybar - Bushings 34mm For Ha Swaybar 14094388 $ 9.89
    Swaybar - Endlinks F-body Style 10221779 $ 7.05
    Swaybar - Front 457923 $ 64.58
    Swaybar - Front End Link Kit 88912162 $ 7.69
    Swaybar - Link Kit Similar To P/n 10221779 88912214 $ 15.21
    Swaybar - Rear 10207649 $ 61.35
    Switch - Seo 6h6 Rh Seo 6h6 1-button/trunk 10188966 $ 19.69
    Switch - Seo 6h6 Rh 1-button/lights Off 10225157 $ 19.62
    Switch - Seo 6h6 Rh 2-button Switch 10225158 $ 18.41
    Switch - Wagon Right Side Of Radio 10203772 $ 22.16
    Taillight - Assembly Left - Complete 5977447 $ 142.63
    Taillight - Assembly Right - Complete 5977448 $ 142.63
    Taillight - Lens Only Caprice - Left 16521719 $ 49.94
    Taillight - Lens Only Caprice - Right 16521720 $ 49.94
    Taillight - Lens Only Ss - Left 16522451 $ 103.30
    Taillight - Lens Only Ss - Right 16522452 $ 103.30
    Thermostat 12555290 $ 11.16
    Thermostat Housing Gasket 12553106 $ 2.00
    Throttle Body Holley 58mm 112-504 $ 450.00
    Throttle Body - Gasket 48mm 10105379 $ 3.22
    Throttle Body - Gasket Kit Complete 17113178 $ 13.97
    Throttle Body - Gaskets Top & Bot - Ac #40-743 17113074 $ 4.87
    Throttle Body - Iac Valve 94-95 - Ac #217-429 17113099 $ 49.50
    Throttle Body - Iac Valve 96 - Ac #217-433 17113188 $ 49.50
    Throttle Body - Tps Sensor 94-96 W/screws 17106680 $ 23.84
    Throttle Body - Tps Sensor 93 W/screws 17106682 $ 35.25
    Timing Chain 93-96 10128485 $ 20.75
    Timing Chain Felpro Tcs45956 $ 13.99
    Timing Chain - Cam Gear 94-96 Lt1 10128349 $ 25.20
    Timing Chain - Cam Gear Lt1/lt4 Extreme Duty 12555885 $ 96.23
    Timing Chain - Cam Sprocket 95-96 10206039 $ 23.87
    Timing Chain - Cover 93-94 - Incl Round Seals 12551636 $ 46.96
    Timing Chain - Cover 95 - Incl Round Seals 12552426 $ 60.00
    Timing Chain - Cover 96 - Incl Round Seals 12552427 $ 40.00
    Timing Chain - Cover Dowel Pin 93-97 12554553 $ 2.14
    Timing Chain - Cover Gasket 93-96 10128293 $ 2.09
    Timing Chain - Crank Gear 94-96 Lt1 10128346 $ 18.10
    Timing Chain - Crank Gear Lt1/lt4 Extreme Duty 12555886 $ 33.41
    Timing Chain - Crank Sprocket Key 92-95 Engines Only 10128303 $ 3.13
    Timing Chain - Roller Chain 94-96 B-body 12555887 $ 42.05
    TRANS - COOLER PIPE RADIATOR-TO-COOLER 10269707 $ 12.35
    TRANS - COOLER PIPE AIR-TO-TRANS HOSE ASSY 10269710 $ 13.36
    TRANS - DEEP PAN 8679994 $ 40.00
    TRANS - DEEP PAN NO DRAIN PLUG 24209295 $ 20.00
    TRANS - DEEP PAN - TRUCK STYLE MUST USE FILTER KIT 24208576 24215535 $ 50.00
    TRANS - DEEP PAN FILTER BOLT 8633208 $ 2.72
    TRANS - DEEP PAN FILTER KIT INCLUDES SEAL & GASKET 24208576 $ 30.00
    TRANS - DEEP PAN FILTER SPACER 8629523 $ 2.72
    TRANS - DEEP PAN OIL - INTAKE PIPE 8629526 $ 3.00
    TRANS - DOWL PIN REAR OF BLOCK 12338119 $ 2.09
    TRANS - FILTER KIT INCL SEAL & GASKET 24200796 $ 20.00
    TRANS - FILTER KIT EXTRA DEP PAN 12337210 $ 20.00
    TRANS - PAN STOCK 8667545 $ 12.00
    TRANS - PAN PLUG HEX HEAD, FOR P/N 24215535 24213991 $ 2.88
    TRANS - TORQUE CONVERTER 86 VETT - $35 CORE 24201203 $ 171.00
    TRANS - TORQUE CONVERTER 95 S10-140K FACTOR - $35 CORE 24202310 $ 174.20
    TRANS - TORQUE CONVERTER 96 S10-135K FACTOR - $35 CORE 24204670 $ 174.20
    TRANS - TORQUE CONVERTER BOLT 85/86 VETT 1261968 $ 1.28
    TRANSMISSION 4L60E GMPP TAHOE MOD/370LB-FT 12497318 $ 1,445.38
    TRANSMISSION 4L60E NUSSER MOTORS 800-344-2641 4L60E $ 1,069.00
    TRUNK EMBLEM BLACK 12523079 $ 20.40
    TRUNK EMBLEM DGGM 12524202 $ 20.40
    TRUNK EMBLEM DCM 12524203 $ 20.40
    TRUNK LAMP ASSEMBLY 2ND DESIGN LATE 95 10268235 $ 7.25
    TRUNK MAT SEO B48 - B42? 10211580 $ 59.67
    TURN SIGNAL LEFT FRONT 5976555 $ 33.72
    TURN SIGNAL RIGHT FRONT 5976556 $ 33.72
    TURN SIGNAL LEFT FRONT 5976557 $ 38.04
    TURN SIGNAL RIGHT FRONT 5976558 $ 38.72
    TURN SIGNAL LEVER W/CRUISE CONTROL 25140743 $ 62.98
    USE OVERDRIVE DURING… STICKER 10220597 $ 6.15
    VACUUM GAUGE 0-30"/0-10PSI 2-5/8" W/GMPP ON FACE 12361397 $ 45.55
    VACUUM GAUGE 0-30"/0-10PSI 2-5/8" W/BOWTIE ON FACE 12361405 $ 36.00
    VALVE - EXHAUST SEAL LT4 12564852 $ 2.03
    VALVE - INTAKE SEAL LT4 10212810 $ 1.08
    VALVE - OIL SEAL LT1 INTAKE & EXHAUST 460483 $ 2.10
    VALVE - SPRING CAP LT4 10212808 $ 1.08
    VALVE - SPRING SHIM LT4 - PACK OF 10 10212809 $ 5.20
    VALVE - STEM TIRE - SOLD IN SETS OF 5 274288 $ 5.10
    VALVE COVER - BOLT GASKETS BAG OF 10 - MAGNESIUM V/C 14088793 $ 2.70
    VALVE COVER - BOLTS MAGNESIUM V/C 10088165 $ 1.38
    VALVE COVER - BOLTS - CHROME 12356818 $ 2.09
    VALVE COVER - CHROME W/RED BOWTIE - SET 12355350 $ 103.00
    VALVE COVER - CORVETTE NEW P/N 12552321 10108605 $ 74.57
    VALVE COVER - CORVETTE NEW P/N 12552322 10108606 $ 79.89
    VALVE COVER - CORVETTE PLASTIC OLD P/N 10108605 12552321 $ 74.57
    VALVE COVER - CORVETTE PLASTIC OLD P/N 10108606 12552322 $ 79.89
    VALVE COVER - GASKET VETT PLASTIC 10108625 $ 7.80
    VALVE COVER - GASKET NEOPRENE - MAGNESIUM V/C 14088564 $ 7.44
    VALVE COVER - GASKETS IRON CYLINDER HEAD 10046089 $ 9.50
    VALVE COVER - MAGNESIUM LH 10055781 $ 90.00
    VALVE COVER - MAGNESIUM RH 10055782 $ 64.27
    VALVE COVER - NUT (PACK OF 10) FOR COMPOSITE V/C 10108675 $ 8.40
    VALVE COVER - STUD FOR COMPOSITE V/C 10108674 $ 2.81
    VEHICLE SPEED SENS (VSS) O-RING AUTO TRANS 15552872 $ 1.00
    VOLT GAUGE 8-18 VOLTS 2-5/8" W/GMPP ON FACE 12361392 $ 42.42
    VOLT GAUGE 8-18 VOLTS 2-5/8" W/BOWTIE ON FACE 12361406 $ 27.18
    VOLT GAUGE 8-18 VOLTS 2-5/8" W/WHITE FACE/BOWTIE 123701176 $ 34.16
    WARRANTY & OWNER'S BOOKLET 10261164 $ 19.96
    WATER PUMP B-BODY 12527740 $ 128.12
    WATER PUMP - DOWEL PIN 93-96 10128487 $ 6.74
    WATER PUMP - DRIVE O-RING 93-96 12553792 $ 0.31
    WATER PUMP - DRIVE SHAFT 93-96 10219554 $ 38.77
    WATER PUMP - GASKET 93-96 10128343 $ 0.30
    WATER PUMP - SHAFT SEAL TIMING CHAIN COVER 10217886 $ 4.02
    WHEEL - 17" X 8.5" EACH 12360496 $ 304.62
    WHEEL - 17X8.5 (SET OF 4) EST $125 SHIPPING 12495438 $ 583.20
    WHEEL - HUB CAP RED BOWTIE 15988450 $ 22.44
    WHEEL - HUB CAPS STOCK IMPALA 9592229 $ 22.74
    WHEEL - HUB CAPS BLACK BOWTIE 9592426 $ 15.36
    WHEEL - SPARE TIRE WHEEL 16X4 - DOESN'T INCLUDE TIRE 9591766 $ 48.18
    WINDOW - REGULATOR MOTOR? 16631405 $ 161.28
    WINDOW ROLLER FIX RIVETS PACK OF 5 9442468 $ 3.20
    WINDOW ROLLERS PACK OF 5 9666748 $ 7.25
    WINDSHIELD WASHER CONTAINER 22144138 $ 7.11
    WINDSHIELD WIPER ARM 9C1 10283602 $ 14.84
    WINDSHIELD WIPER BLADE 9C1 102836022 $ 4.84
    WINSHIELD WASHER PUMP 96 22127653 $ 20.57
    WOOD GRAIN BEZEL TRIM FASTENERS PACK OF 20 10161510 $ 3.40
    WOOD GRAIN DOOR BEZEL INSERT (LF) 10242034 $ 48.67
    WOOD GRAIN DOOR BEZEL INSERT (LR) 10242040 $ 21.11
    WOOD GRAIN DOOR BEZEL INSERT (RF) 10242035 $ 26.30
    WOOD GRAIN DOOR BEZEL INSERT (RR) 10242039 $ 21.11
    WOOD GRAIN LOWER DASH PLATE 10256065 $ 109.70
    WOOD GRAIN SWITCH PANEL (DRIVER) 10240921 $ 90.00
    WOOD GRAIN SWITCH PANEL (PASS) 10240920 $ 45.00
    ZZ502 BLOCK (4-BOLT MBC) 10237292 $ 1,396.50
    ZZ502 CRATE MOTOR - UNASSEMBLED 502HP 12371171 $ 6,615.00
    ZZ502 ENGINE LONG BLOCK KIT 12371204 $ 5,687.50
    ZZ502 MOTOR-COMPLETE 502HP 12496962 $ 6,895.00
    ZZ502 MOTOR-LESS INTAKE 502HP 12496963 $ 5,967.50
    B car with 8.5 inch diff as follows:
    3.08---26018943
    3.23---26018944
    3.42---26018945
    3.73---26018946
    12176639--Brass AUX Battery Post
    25095452 PCV VALVE
    12556257 PCV PIPE
    18021516-Emergency brake kit
    Air Dam / Deflector,Air Deflector (SEO 9C1),10220593,Front Lh Air Deflector (SEO 9C1)
    Air Dam / Deflector,Air Deflector (SEO 9C1),10220594,Front RH Air Deflector (SEO 9C1)
    Alarm,Remote Control Transmitter,10239647,Remote Control Transmitter
    Ash tray,Ash tray asm,10197140,Ash tray asm
    Belt,Belt,12550149,Belt
    Belt,Belt,K060637,Belt
    Belt,Belt Tensioner,10238703,Belt Tensioner
    Belt,TENSIONER,12552509,Drive Belt Tensioners
    Bolt,Emissions Bracket Bolt,11516061,Emissions Bracket Bolt
    Brake,Brake Master Cylinder,,Brake Master Cylinder Gasket
    Brakes,Brake Pad,6144,PF brake hiway front
    Brakes,Brake Pad,614Z,PF brake z-rated front
    Brakes,Brake Pad,6284,PF brake hiway rear
    Brakes,Brake Pad,628Z,PF brake z-rated rear
    Brakes,Brakes,10223533,BrakeProportioning Valve
    Brakes,Caliper,18021517,LH rear caliper
    Brakes,Caliper,18021518,RH rear caliper
    Brakes,Parking brake pads,18021515,Parking brake pads
    Camshaft,Cam,10185071,ZZ3 HO 350 Cam
    Camshaft,Cam,12370845,GM High Performance Cam
    Camshaft,Cam,12370846,GM Street / Strip Cam
    Camshaft,Cam,12370847,GM Competition Cam
    Carpet,Carpet,10276338,Black Cadillac Fleetwood Carpet
    Carpet,Carpet,12528553,Carpet
    Carpet,Carpet / Mats,12343594,Mat Pkg Rear
    Carpet,Carpet / Mats,12343624,Mat Pkg Front
    Cassette,95? Cassette,10256913,95? Impala SS Cassette
    Console,Console,10261527,Console Cup Holder Insert
    Console,Console Hinge,22555614,Console Hinge
    Console,Console Shifter Frame (Assm?),10282773,Console Shifter Frame (Assm?)
    Console,Console Shifter Top,10271069,Console Shifter Top
    Control Arms,Rear Lower Control Arms,10289786,New Design 9C1 Lower Rear Control Arms
    Coolers,SEO 7L9 Power Steering Fluid Cooler,12091638,CLAMP -L
    Coolers,SEO 7L9 Power Steering Fluid Cooler,2091638,Clamp -Lo
    Coolers,SEO 7L9 Power Steering Fluid Cooler,26036034,Pipe Asm-
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-air),10219157,Bracket-e
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-air),10225895,Pipe Asm-
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-air),10225896,Pipe Asm-
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-air),10226222,Cooler As
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-air),10260341,Hose Asm-
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-Air),12337917,NUT RR BP
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-air),15966491,Clip
    Coolers,SEO 7P8 Engine Oil Cooler (Oil-to-Air),20351035,SCREW
    Cooling,96 Fan Shroud,10281082,96 Fan Shroud
    Cooling,PUMP KIT,12527740,Waterpumps
    Covers,Accelerator Linkage,10242904,Bracket - Accellerator Linkage Cover
    Covers,Accelerator Linkage,10260166,Accel Cover
    Covers,Accelerator Linkage,11505169,Bolt (Screw?) - Accellerator Linkage Cover
    Covers,Accelerator Linkage,11508083,Bolt Accelerator Linkage Cover
    Covers,Corvette Injector Cover,10208794,Corvette LT1 Fuel Rail Cover Left
    Covers,Corvette Injector Cover,10208795,Corvette LT1 Fuel Rail Cover Right
    Covers,Corvette Plastic Valve Covers,10128361,Corvette Plastic Valve Covers
    Covers,Heat Shields,12132232,Spark Plug Heat Shields
    Decals / Trim,Carpet Retainer,10222523,RH Rear Door Floor Carpet Retainer
    Decals / Trim,Carpet Retainer,10222524,LH Rear Door Floor Carpet Retainer
    Decals / Trim,Carpet Retainer,10253508,RH Front Door Floor Carpet Retainer
    Decals / Trim,Carpet Retainer,10253509,LH Front Door Floor Carpet Retainer
    Decals / Trim,Console Lid,12531192,Console Lid
    Decals / Trim,Decals / Trim,10121580,TrimR/cm -
    Decals / Trim,Decals / Trim,10248742,Impala SS Black Body Script
    Decals / Trim,Decals / Trim,10249082,Front Bowtie Emblem
    Decals / Trim,Decals / Trim,10253594,Impala SS Emblem Rear Qtr RH
    Decals / Trim,Decals / Trim,10253595,Impala SS Emblem Rear Qtr LH
    Decals / Trim,Decals / Trim,10262808,Impala SS emblem Rear QTR Green
    Decals / Trim,Decals / Trim,10262809,Dark Cherry Met. Body Script
    Decals / Trim,Decals / Trim,10267037,Caprice SS Black Body Script
    Decals / Trim,Decals / Trim,10267038,Caprice SS Script in Grey Green
    Decals / Trim,Decals / Trim,10267039,Caprice SS Script in Dark Cherry
    Decals / Trim,Decals / Trim,10268239,Caprice SS Dash Script above Radio
    Decals / Trim,Decals / Trim,10283878,Dex-cool 'Notice' Sticker
    Decals / Trim,Decals / Trim,10285918,Dexcool Radiator Cap
    Decals / Trim,Decals / Trim,12523079,Impala SS Trunk Emblem Black
    Decals / Trim,Decals / Trim,12524202,Impala SS Trunk Emblem Grey Green
    Decals / Trim,Decals / Trim,12524203,Impala SS Trunk Emblem Kit Dark Cherry
    Decals / Trim,Decals / Trim,22591877,Cavalier Red Bow Tie
    Decals / Trim,Door Panels,10153057,door panel retainers
    Decals / Trim,Door Panels,10161510,Plastic Retainer Clip for Door Panels
    Decals / Trim,Door Panels,10250952,Door Panel (side unknown)
    Decals / Trim,Door Panels,10250953,Door Panel (side unknown)
    Decals / Trim,Front Air Dam,10109530,Front Air Dam Center Section
    Decals / Trim,Fuel Bib,10186225,Fuel Bib
    Decals / Trim,Glovebox Latch,12527729,Glovebox Latch
    Decals / Trim,Instrument Panel,10250238,Instrument bezel
    Decals / Trim,Instrument Panel,10250947,Impala SS Dash Plate
    Decals / Trim,Instrument Panel,16164576,Clear Plastic Instrument Cover
    Decals / Trim,Mobil-1 Oil Fill Cap (96 Vette),12554955,Mobil-1 Oil Fill Cap (96 Vette)
    Decals / Trim,Mobil-1 Plate (92-95 Vette),10236268,Mobil-1 Plate (92-95 Vette)
    Decals / Trim,Molding,12516867,moulding kit FRT S/D LWR (left)
    Decals / Trim,Molding,12522932,Mldg RH Rear Door Blk
    Decals / Trim,Molding,12522933,Mldg LH Rear Door Blk
    Decals / Trim,Molding,12522938,Mldg RH Fender Blk
    Decals / Trim,Molding,12522939,Mldg LH Fender Blk
    Decals / Trim,Molding,12526866,Mldg RH Frnt Door Blk
    Decals / Trim,Molding,12526867,Mldg LH Frnt Door Blk
    Decals / Trim,Red Bow Tie with SS Emblem,15970086,Red Bow Tie with SS Emblem
    Decals / Trim,Sill plate,10111989,Sill plate - front drivers (left)
    Decals / Trim,Sticker,10220597,For Pursuit Use Overdrive Sticker
    Decals / Trim,Woodgrain Door Inserts,10188965,Panel ASM left armrest
    Decals / Trim,Woodgrain Door Inserts,10240920,Panel ASM right armrest
    Decals / Trim,Woodgrain Door Inserts,10256066,Plate ASM dash
    Decals / Trim,Woodgrain Door Inserts,16671169,Bezel ASM door
    Decals / Trim,Woodgrain Door Inserts,16671421,Bezel ASM door
    Distributor,Distributor Cap,10457293,Distributor Caps
    Drivetrain,Seal,12471523,Seal - new (Caprice only)
    Drivetrain,Yoke,12471517,Yoke (new) for all GM 7.5 rearends
    Electrical,Battery,1981590,SEO Heavy Duty Battery
    Electrical,BULB HDLP,9441731,Bulbs fog
    Electrical,Connector,12102748,connector for 10096181 Grn=dash Yel=PCM Blk=PCM grnd
    Electrical,Electrical Recall Parts,12129481,Busbar Cavity L1 and L3
    Electrical,Electrical Recall Parts,12146182,Busbar Cavity L2 and L4
    Electrical,Electrical Recall Parts,12146183,Cover Electrical Center Stud
    Electrical,Electrical Recall Parts,12161130,Stud Assembly
    Electrical,Electrical Recall Parts,12164416,Battery to Starter Cable
    Electrical,Plug Wires,12096437,Spark Plug Wire Set
    Electrical,Pontiac WS6 MAF extension,12529241,Pontiac WS6 MAF extension
    Electrical,Relay,12167644,Relocation kit
    Electrical,Relay,12193604,Cooling fan relay
    Electrical,SEO Heavy Duty Battery,11981590,BATTERY
    Electrical,WIRE KIT,12173568,Spark Plug Wire Set
    Emissions,Air Pump,12554580,electric secondary air injection pump
    Emissions,Air tube,12550779,Air tube connector - right
    Emissions,emissions bracket,10229207,Emissions Bracket Z28 LT1 (n/a '96)
    Emissions,Exhaust,22048212,Exhaust check valve
    Emissions,PCV VALVE,25095452,PCV Valve
    Engine,96 Corvette LT1 Engine,10210312,96 Corvette LT1 Engine
    Engine,96 Corvette LT4 Engine,12551183,96 Corvette LT4 Engine
    Engine,Long Block,10185072,HO 350 Long Block
    Exhaust,Exhaust Manifold,12524289,Exhaust Manifold (94 and early 95)
    Exhaust,Exhaust Manifold,12553037,Exhaust Manifold LH (new Style)
    Exhaust,Exhaust Manifold,12556731,Exhaust Manifold (late 95 and 96)
    Exhaust,Exhaust Manifold Nuts,11516072,Exhaust Manifold Nuts
    Exhaust,Exhaust Manifold Studs,10220453,Exhaust Manifold Studs
    Exhaust,Export Leaded Fuel Only Front Exhaust Pipe,10204014,Pipe Asm-
    Exhaust,Export Leaded Fuel Only Front Exhaust Pipe,10204015,Pipe Asm-
    Exhaust,Export Leaded Fuel Only Front Exhaust Pipe,12550283,Gasket-ex
    Exhaust,Export Leaded Fuel Only Front Exhaust Pipes,10168551,GASKET-EX
    Exhaust,O2 Bungs for Export Pipes,LN0055-B,O2 Bungs for Export Pipes
    Filter,AIR FLTR,25096932,Air Filters
    Filter,Fuel Filter,25121978,FILTER
    Filter,Oil Filter,25171377,FILTER
    Filter,Transmission Filter Kit,24200796,FILTER KI
    Fluids,Dexcool Gallons,12346290,Dexcool Gallons
    Fluids,Fluids,12345867,Low Temperature Power Steering Fluid 32 oz
    Flywheel,FLYWHEEL,14088765,Engine Flywheel
    Front Suspension,Moog Front End Rebuild Parts,DS899,Center Link
    Front Suspension,Moog Front End Rebuild Parts,ES2019RLT,Tie Rod - Outer
    Front Suspension,Moog Front End Rebuild Parts,ES2020RLT,Tie Rod - Inner
    Front Suspension,Moog Front End Rebuild Parts,K5208T,Upper Balljoint
    Front Suspension,Moog Front End Rebuild Parts,K6145T,Lower Balljoint
    Front Suspension,Moog Front End Rebuild Parts,K6187T,Idler Arm
    Front Suspension,Moog Front End Rebuild Parts,K6210,Upper Cross Shaft
    Front Suspension,Moog Front End Rebuild Parts,K6409,Upper Control Arm Bushings
    Front Suspension,Moog Front End Rebuild Parts,K6419,Lower Control Arm Bushings
    Fuel Rail Covers,Corvette Fuel Rail Covers,10108672,Stud-Fuel Rail Attachment
    Fuel Rail Covers,Corvette Fuel Rail Covers,10214035,Hose - Corvette Brake Vacuum Booster
    Fuel Rail Covers,Corvette Fuel Rail Covers,10224936,92 Vette Fuel Rail Cover - RH
    Gasket,1996 Exhaust Manifold Stainless Gaskets,12552469,1996 Exhaust Manifold Stainless Gaskets (New in 96
    Gasket,Correct (Older) Design Gm Rear End Gasket,3993593,Correct (Older) Design Gm Rear End Gasket
    Gasket,Correct Fel-Pro Rear End,RDS 55028-1,Correct Fel-Pro Rear End Gasket
    Gasket,Crank,10128316,Crank seal
    Gasket,Cylinder Head,10108689,Cylinder Head to Coolant Gaskets
    Gasket,EGR,12337972,EGR gasket
    Gasket,Gaskets,10046089,Valve Cover Gasket (Iron Head)
    Gasket,Head Gasket,12553160,Head Gaskets
    Gasket,Head Gaskets,10168457,Stock Head Gaskets
    Gasket,Intake Manifold,12524653,Intake Manifold Gasket Set
    Gasket,Oil adapter gasket,12551289,Oil adapter gasket
    Gasket,Oil Pan,10108676,Oil Pan Gasket
    Gasket,OptiSpark,10474278,OptiSpark O-rings
    Gasket,OptiSpark,12552428,OptiSpark Drive Seal
    Gasket,Plate,10054480,EGR block off plate
    Gasket,SEAL-ENG,12553106,Thermostat & Gaskets
    Gasket,Seals/Gaskets,460483,Exhaust Valve Stem Oil Seals
    Gasket,Throttle Body,10105379,Throttle Body Gasket
    Gasket,Timing Cover,10128293,Timing Cover Gasket
    Gasket,Water Pump,10128343,Water Pump Gaskets
    Gasket,Water Pump,10217886,Water Pump Drive Seal
    Gasket,Water Pump,12553792,Water Pump Drive O-rings
    Gears,3.42 Gears,1052358,Gm Limited Slip Additive
    Gears,3.42 Gears,1234726,Pinion Spacer (Crush Collar)
    Gears,3.42 Gears,1260823,Pinion Nut
    Gears,3.42 Gears,26018945,20-tooth Abs Reluctor
    Gears,3.42 Gears,26033578,Pinion Seal
    Gears,3.42 Gears,26041514,Gu6 Factory 3.42 Gear Set
    Gears,3.42 Gears,26053758,Pinion Front Bearing 3.42 or 3.73 Gears
    Gears,3.42 Gears,554631,Axle Seals (2 Reqd)
    Gears,3.42 Gears,9413427,Pinion Rear Bearing
    Gears,3.42 Gears,9418356,Pinion Front Bearing (old???)
    Gears,3.42 Gears,9420095,Carrier Side Bearings
    Gears,3.73 Gears,26018946,3.73 ABS Reluctor
    Gears,3.73 Gears,26041513,3.73 Gearset - Ring and Pinion
    Grill,Grill,10269614,Impala SS Grill Black
    Grill,Grill,10269615,Impala SS Grill Grey Green
    Grill,Grill,10269616,Impala SS Grill Dark Cherry
    Head,Aluminum LT1 Head,10207643,Aluminum LT1 Head
    Head,LT4 Heads,12363287,LT4 Heads
    Headers,parts for SLP Headers for 94,10217106,Connector
    Headers,parts for SLP Headers for 94,12552898,Emissions Pipe
    Headers,parts for SLP Headers for 94,12552899,Emissions Pipe
    Headers,Union,10215680,Exhaust manifold to air tube union
    Horn,Horn,12368063,Horn
    Horn,Horn,12368064,Low note
    Horn,Horn,12368065,Horn
    Horn,Horn,1892164,High 'A' note
    Horn,Horns,1892162,Cadillac Horn D Note
    Horn,Horns,1892246,Cadillac Horn C Note
    Hoses,3 1/2 hose (Gates),24256,3 1/2 hose (Gates)
    Hoses,Hoses,10108667,Water Inlet Assembly-94-96 LT1
    Hoses,Hoses,10239698,Engine Oil Cooler Inlet Hose
    Hoses,SEO 1T1 Silicone Rubber Hose Kit,10197619,Hose Asm
    Hoses,SEO 1T1 Silicone Rubber Hose Kit,10219447,Hose-cool
    Hoses,SEO 1T1 Silicone Rubber Hose Kit,10256544,Hose Asm
    Hoses,SEO 1T1 Silicone Rubber Hose Kit,10258505,Valve Asm
    Hoses,SEO 1T1 Silicone Rubber Hose Kit,10260863,Hose Asm
    Hoses,SEO 1T1 Silicone Rubber Hose Kit,10260864,Hose Rad Upper
    Hoses,SEO 1T1 Silicone Rubber Hose Kit,12522853,Hose
    Insulation,Hood Insulation Blanket,10196123,Hood Insulation Blanket
    Intake,1LE Elbow w/ATT,25147186,1LE Elbow w/ATT
    Intake,Intake,25147187,95 1LE F-car Duct with Distributor Vent Nipple
    Intake,Intake,25147210,94 1LE F-car Duct W/O Distributor Vent Nipple
    Intake,MAF,25008308,96 Corvette MAF
    Intake,SSRI Intake,1059-33,Fernco adapter
    Interior,Knob,16182704,Temp Control Knob
    Keyless Entry,BATTERY,12537045,Keyless Entry Fobs Batteries
    Lighter,KNOB & EL,11516141,Lighter Element
    Lighting,Bulb,10031004,Bulb with the Blue 'Condom' Pontiac #158 Bulb
    Lighting,Driving Light Lamp Assembly,16511879,Driving Lights
    Lighting,Driving Light Lamp Assembly,20669667,Switch
    Lighting,Export T84 Capsule Headlamps,16519237,Capsule a (Left)
    Lighting,Export T84 Capsule Headlamps,16519238,Capsule a (Right)
    Lighting,Export T84 Capsule Headlamps,6288471,Connector
    Lighting,Export T84 Capsule Headlamps,6294068,Terminal
    Lighting,Flash to Pass,26035237,Flash-To-Pass Dimmer Switch
    Lighting,Lighting,10203566,Underhood Light
    Lighting,T84 Capsule Headlamps,26288471,CONNECTOR
    Lighting / Switches,Switch,10203772,Panel Asm (Rear Door / Window Switch)
    Locks,6N1 Lock Module,16630059,6N1 Lock Module
    Manuals,1996 Warranty and Owner Assistance Booklet,10261164,1996 Warranty and Owner Assistance Booklet
    Manuals,94? Impala SS CD,10260282,94? Impala SS CD
    Manuals,95? Impala SS CD,10256924,95? Impala SS CD
    Manuals,95? Owners Booklet,10256922,95? Owners Booklet w/ cassette
    Manuals,HELMS Owners Manual Portfolio,10256914,HELMS Owners Manual Portfolio
    Mats,SEO B48 (B42?) Trunk Mat,10211580,Heavy Duty Trunk Mat SEO B42
    mirrors,Electrochromic Mirror with Digital Compass,12344614,Mirror Pk
    Oil,Dipstick,12551144,95 Oil Dipstick
    Oil,Oil Adapter,10244495,Oil adapter O ring
    Oil,Oil cooler,10260341,Oil cooler line to radiator adapter - Caprice
    Oil,Oil Cooler,10269713,oil cooler adapter to radiator - Impala SS
    Oil,Oil Filler,12554925,Vette Oil Filler Cap
    Oil,Oil pump bolt,10046007,oil pump bolt
    PCM,PCM Calibration - 94,16200341,PCM Control Module Calibration - initial 94
    PCM,PCM Calibration - 94,16202491,PCM Control Module Calibration - update 94
    PCM,PCM Calibration - 94,16207221,PCM Control Module Calibration - update 94
    PCM,PCM Calibration - 94,16232021,PCM Control Module Calibration - update 94
    PCM,PCM Calibration - 95,16206641,PCM Control Module Calibration - initial 95
    PCM,PCM Calibration - 95,16209351,PCM Control Module Calibration - update 95
    PCM,PCM Calibration - 95,16232011,PCM Control Module Calibration - update 95
    PCM,PCM Calibration - 96,16229981,PCM Control Module Calibration - initial 96
    PCM,Replacement PCM,16188051,94-5 Powertrain Control Module
    PCM,Replacement PCM,16214399,96 Powertrain Control Module
    Plastic Tubing,Tubing,8919356,3/4' ID convoluted Plastic Tubing
    Plug,Plug,20363491,Plug to fill front license plate holes
    Polishes / Waxes,Car Car Kit in a Case with Bowtie Logo,12344998,Car Car Kit in a Case with Bowtie Logo
    Pulley,A/C Pulley,2724717,A/C Pulley
    Rack & Carriers,RACK,10041121,Racks and Carriers
    radio,RadioUL0,12370249,Radio
    Recall,Electrical Recall Parts,11516161,Nut Stud Assembly
    Seat,Power Seat Assembly (ADJ ASM-P),16731968,Power Seat Assembly (ADJ ASM-P)
    Seat,Power Seat Assembly (ADJ SA-D),16726726,Power Seat Assembly (ADJ SA-D)
    Sensors,LT1 Knock sensor,16188309,LT1 knock sensor
    Sensors,LT4 Knock sensor,16214681,LT4 knock sensor
    Sensors,O2 Sensors,25165313,O2 Sensors
    Sensors,Sensor,10096181,Temp Gauge Sender - 3 connector replacement
    Sensors,Sensor,25036979,Temperature Sensor - Front of Block for PCM
    Sensors,Sensor,25037332,Temperature Sensor - Side of Block for Temp Gauge
    Sensors,SEO Police Oil Pressure Sender,10201491,SEO Police Oil Pressure Sender
    Sensors,Thermostat & Gaskets,12555290,Thermostat
    Sensors,Thermostatic Switch,3053190,Thermostatic Switch
    Shocks,Air Shocks,22003254,Air Shocks with Separate Lines
    Shocks,Shock Absorbers,22064499,SEO 8X3 Bilstein Heavy Duty Shock Absorbers
    Shocks,Shock Absorbers,22064600,SEO 8X3 Bilstein Heavy Duty Shock Absorbers
    Sound,12 disc CD Changer,12343958,12 disc CD changer for UL0 radio
    Sound,12 disc CD Changer Cable,12344015,12 disc CD Changer Cable
    Spark Plug,SPARK PLG,5614244,Spark plugs
    Spark Plug,Spark Plugs,25166821,96 Impala AC 41-943 Double Platinum Plugs
    Splash Guards,GUARD PKG,12371092,Splash Guards
    Spoiler,Spoiler,10266588,94-6 Impala SS Rear Spoiler
    Spoiler,Spoiler,11508388,94-6 Impala SS Rear Spoiler Bolts
    Spoiler,Spoiler,12337977,Impala SS Rear Spoiler Bolts
    Spoiler,Spoiler,12524697,Impala SS Rear Spoiler
    Springs,Rear Spring,482086,9C1 Rear Coil Spring
    Springs,Springs,22076517,1995 Rear Springs 18.0 N/mm 'RC'
    Springs,Springs,22076523,1994 7B3 Suspension 'Rx'
    Springs,Springs,22076526,1995 Rear Springs 27.0 N/mm 'RX'
    Springs,Springs,22078017,Highest Load Rate 1995 Front Springs
    Springs,Springs,22132375,1995 Rear Springs (Stock)
    Starter,Starter,10455709,Vette 94 LT1 Starter
    Starter,Starter,10465143,Starter motor
    Starter,Starter,10465293,Starter motor
    Steering Wheel,Sir Module AssyLight Grey,16757619,Sir Module Assy
    Steering Wheel,Steering Wheel Switch Pod (Firebird),16191162,LH Switch Pod
    Steering Wheel,Steering Wheel Switch Pod (Firebird),16191172,RH Switch Pod
    Steering Wheel,Wheel Assembly Steering (Leather Light Grey),16757633,Light Grey)
    Sway Bars,End Link Bushings,10221801,End Link Bushings from F-Body
    Sway Bars,Swaybar,356534,Swaybar from 2nd Gen F-Body (32mm)
    Sway Bars,Swaybar Bushings (32mm),10288551,Sway Bar Bushings from F-Body (new number ???)
    Sway Bars,Swaybar Bushings (32mm),26039956,Swaybar Bushings (32mm) (F-Body) (old number ???)
    Sway Bars,Swaybar Bushings (34mm),14094388,Swaybar Bushings (34mm)
    Switches / Fuses,Switch,10188966,RH SEO 6H6 single button/trunk
    Switches / Fuses,Switch,10225157,RH SEO 6H6 single button/lights off
    Switches / Fuses,Switch,10225158,RH SEO 6H6 two button switch
    Switches / Fuses,Switch,12064862,Connector for 10225158 switch (???) 8 way F m/p
    Switches / Fuses,Switch,12126438,Connector for 10225158 switch (???)
    Torque Convertor,1985/86 Corvette Torque Converter,24201203,TORQUE CON
    Torque Convertor,1985/86 Corvette Torque Converter,31261968,BOLT
    Torque Convertor,Torque Convertor,24202310,1995 4.3L (RPO l35) S10 Truck V6 Application
    Transmission,Transmission filter,24208576,Suburban Transmission Filter for deep pan
    Transmission,Transmission pan,24210915,Suburban Deep Transmission Pan
    Transmission,Transmission pan,24213275,Suburban Deep Transmission Pan
    Transmission,Transmission pan,24215535,Suburban Deep Transmission Pan
    Trunk,Spare Tire Cover,10281334,Space Saver Spare Cover
    Trunk,Spare Tire Wheel,9591766,Space Saver Spare Wheel
    Trunk,Trunk Lamp Assembly,10268235,2nd Design (Late 95) Trunk Lamp Assembly
    Valve Cover,clip,20038997,Clip Accellerator and Cruise Cables
    Valve Cover,Corvette (87-92) Magnesium Valve Cover,10055782,Corvette (87-92) Magnesium Valve Cover RH
    Valve Cover,Corvette (87-92) Magnesium Valve Cover,10088165,Valve Cover Bolt with washer
    Valve Cover,Corvette (87-92) Magnesium Valve Cover,10108590,Corvette (87-92) Magnesium Valve Cover LH
    Valve Cover,Corvette (87-92) Magnesium Valve Cover,10108650,Screw in Oil Filler Cap (for '94 replacement only)
    Valve Cover,Corvette (87-92) Magnesium Valve Cover,14088564,Neoprene Valve Cover Gaskets
    Valve Cover,Corvette Plastic Valve Covers,10108605,Cover-vlv - LH (replaced by 12552321)
    Valve Cover,Corvette Plastic Valve Covers,10108606,Cover-vlv - RH (replaced by 12552322)
    Valve Cover,Corvette Plastic Valve Covers,10108625,Gasket-valve
    Valve Cover,Corvette Plastic Valve Covers,10108674,Stud - Valve
    Valve Cover,Corvette Plastic Valve Covers,10108675,Bolt - Valve
    Valve Cover,Corvette Plastic Valve Covers,10108694,Cap Asm-o
    Valve Cover,Corvette Plastic Valve Covers,10240678,Grommet
    Valve Cover,Corvette Plastic Valve Covers,12552321,Valve Cover LH (replaces 10108605)
    Valve Cover,Corvette Plastic Valve Covers,12552322,Valve Cover RH (replaces 10108606)
    Ventvisor,Ventvisor,94152,Ventvisor
    Wheels,Hub Caps,10194305,Hub Cap Inserts
    Wheels,Hub Caps,952426,Original center cap
    Wheels,Hub Caps,9592229,Hub Caps
    Wheels,Hub Caps,9592426,S10 wheel center caps
    Wheels,Wheel,12360396,Impala SS Wheel
    Windshield,SEO 9C1 High-speed Windshield Wiper Blades,5049730,Blade Asm (May Be Old Part Number)
    wipers,9C1 Wiper (Deflector) and Blade,10283602,9C1 Deflector and Blade
    Misc. Impala Specific Replacement Parts. You might want to stock
    up on these now while they are still readily available:
    Part                          Number      List  Net   Date
    Instrument Lens               16164576    15.30 11.48 4/96
    Hub Cap                       9592229     30.50 22.88 4/96
    Impala SS Dash Plate          10250947 4.85 3.88  4/96
    Caprice SS Black Body Script  10267037                3/96
    Impala SS Black Body Script   10248742                3/96
    Dark Cherry Met. Body Script  10262809    23.10       4/1
    Impala SS Emblem Rear Qtr RH  10253594                3/96
    Impala SS Emblem Rear Qtr LH  10253595                3/96
    Impala SS Emblem Trunk Black  12523079                3/96
    Hub Cap Inserts               10194305
    Front Bowtie incl.w/ grille)  10249082
    Grille Assembly               10269614
    Rear Spoiler                  12524697
    Console Shifter Top           10271069
    Nameplate (above the radio)   10250947
    Mat Pkg. Front                12343594
    Mat Pkg. Rear                 12343624
    Glovebox Latch                12527729
    Console Lid                   12531192
    Heavy Duy Trunk Mat (SEO B42) 10211580
    Console, Cup Holder Insert    10261527     2.00
    Mobil 1 Oil Fill Sticker      10236268
    Mobil 1 Oil Fill Cap          12554955
    Here's another list that may include some other part numbers you may need:
    CLASSIFICATION, PART NUMBER, ASSEMBLY, LIST, COST, COMMENTS
    12 disc CD Changer,12344015,12 disc CD Changer Cable
    1LE Elbow w/ATT,25147186,1LE Elbow w/ATT,May not be usable for intake upgrades
    61 Impala SS Cross Flag (smaller),NAIS041,61 Impala SS Cross Flag (smaller) - originally on radio ,24
    61 Impala SS Cross Flag Kit - Complete,NAIS040,49.95
    62 Impala SS Trunk Emblem,NAIS042,32
    94 Impala CD,10260282
    94? Impala Cassette,10256922
    95 Impala SS CD,10256924
    Aluminum rivets,9442468,0.24
    Arlington 1 Video,NAIS054,25
    Backissue Newsletters,NAIS056,2
    Bra / Covers,NAIS035,Impala SS 2 piece Bra - specify front plate yes/no,110
    Bra / Covers,NAIS036,Impala SS Sport Bra - covers hood only,59
    Bra / Covers,NAIS037,Impala SS Mirror Covers, 95-6 Only - 95-6 Only,29.95
    Bra / Covers,NAIS038,Impala SS Headlight Covers - Smoke or Clear,42
    Bra / Covers,NAIS039,Impala SS Dashcover - Grey Velour, improved design,42.95
    C-post Impala Deer Emblems - L & R pair,NAIS044,11
    Chevrolet S-10 SS Emblem,NAIS043,11
    Decals / Trim,NAIS018,Dale Earnhardts Chevrolet Dealership Emblem,5.95
    Decals / Trim,NAIS019,Red Bowtie Decal for Impala SS Grill,6
    Decals / Trim,NAIS020,Cavalier Red Bowtie,8
    Decals / Trim,NAIS021,Impala Deer Decal Large - Red or Silver,5
    Decals / Trim,NAIS022,Impala Deer Decal, Small - Red or Silver,3
    Decals / Trim,NAIS023,Bowtie Outline Decals - Black,3.25
    Decals / Trim,NAIS024,GM Use Overdrive During Pursuit Decal - OEM GM,7
    Fastlane Footwear Bowtie Sneakers - white,NAIS049,49.95
    Fastlane NASCAR Sneakers - white,NAIS050,49.95
    Fastlane NHRA Sneakers - white,NAIS051,49.95
    Hat,NAIS004,Impala SS Embroidered Hat - Black or Dark Cherry,8.95
    Hat,NAIS006,Bowtie Racing Hat - w/red Bowtie & Racing,8.95
    Hat,NAIS008,Bowtie Straw Hats - Black or Natural with Red Bowt,26
    HELMS Owners Manual Portfolio,10256914,15,HELMS
    Impala SS CD Rom Digests - 1-700 plus more,NAIS055,25
    Impala SS Rear Trunk Emblem - specify color ,NAIS045,27.75
    Jacket,NAIS003,Impala SS Embroidered Satin Jacket - Black or Dark Cherry,45.95
    Kool Tote,NAIS016,Impala SS Embroidered Kool Tote - Black or Dark Cherry,39.95
    Leather Scent Air Freshener - quart sprayer,NAIS047,11.95
    Leather Travel Bag,NAIS017,Premium Embroidered Leather Travel Bag (with
    Logos,125
    License Plate,NAIS009,Impala Deer License Plate - Black w/ Silver Deer,4.95
    License Plate,NAIS010,Limited Edition Impala Plate  - Autographed by Jon Moss,14.95
    License Plate,NAIS011,Limited Edition Black License Plate - w/red Bowtie,7.5
    Mug,NAIS014,Chevrolet Racing Insulated Mug - 22 oz.,6.5
    NAISSO Cup Coozies - Black, DCM or GGM,NAIS052,4
    NAISSO Regional Director Business Cards,NAIS061,25
    Oxygen Sensor Bungs for Export Pipes - pair,NAIS046,7
    Pins,NAIS025,Round Impala Deer Pin - Round Impala Deer Pin,3.5
    Pins,NAIS026,Round Impala Deer Pin - w/Red SS,3.5
    Pins,NAIS027,Gold Bowtie Pin,3.95
    Pins,NAIS028,Red Bowtie Pin,3.95
    Pins,NAIS029,SS 350 Pin,3.5
    Pins,NAIS030,Impala Super Sport Pin,3.5
    Pins,NAIS031,Small Cross Flags Pin,3.5
    Pins,NAIS032,Chevrolet Special Equipment Pin,3.5
    Pins,NAIS033,Impala SS pin - old style similar to trunk emblem,3.5
    Pins,NAIS034,Chevrolet Bowtie Pin - 94, 95 or 96 specify year,3.5
    Plates,NAIS057,Engraved NAISSO nameplate - for shows,10
    Plates,NAIS058,Member or Life Member engraved plate,5
    Plates,NAIS059,Jon Moss Signature Series engraved plate,5
    Remote Control Transmitter,10239647,70
    Shirt,NAIS001,Impala SS Airbrushed T-shirts White Only; M - 2X, ,12
    Shirt,NAIS002,Impala SS Premium Embroidered Polo - Black or Dark,35
    Shirt,NAIS007,Bowtie Polo Shirts - Black with Red Embroidered Bo,26.95
    Sign,NAIS012,Impala Court Street Sign,18.95
    Sign,NAIS013,Impala Parking Only Street Sign,18.95
    Switch,10188966,RH SEO 6H6, single button/trunk,27
    Switch,10225157,RH SEO 6H6 single button/lights off,36.5,27.38
    Switch,10225158,RH SEO 6H6 two button switch,34.25,27
    The TREATMENT Carnuba Wax,NAIS060,12
    Transgo 4L60E Performance Shift Kit,NAIS048,88.95
    Wall Clock,NAIS015,Impala SS Wall Clock - Beveled Edge Glass w/Impala,35
    1985/86 Corvette Higher-stall Torque Converter,1261968,Bolt,1.7,1.28,3,GM
    1985/86 Corvette Higher-stall Torque Converter,24201203,Torque Con,195,142.74,1,GM
    1996 Exhaust Manifold Stainless Gaskets (New in 96,12552469,1996 Exhaust Manifold Stainless Gaskets (New in 96,67.15,5.23,GM
    3 1/2 hose (Gates),24256,3 1/2 hose (Gates),GM
    3.42 Gears,1052358,Gm Limited Slip Additive,5.9,4.32,GM
    3.42 Gears,1234726,Pinion Spacer (Crush Collar),3.5,2.56,GM
    3.42 Gears,1260823,Pinion Nut,3.2,2.34,GM
    3.42 Gears,26018945,20-tooth Abs Reluctor,7.56,5.65,GM
    3.42 Gears,26033578,Pinion Seal,13.82,9.37,GM
    3.42 Gears,26041514,Gu6 Factory 3.42 Gear Set,422,308.9,GM
    3.42 Gears,554631,Axle Seals (2 Reqd),8.86,6,GM
    3.42 Gears,9413427,Pinion Rear Bearing,50.5,28.78,GM
    3.42 Gears,9418356,Pinion Front Bearing,43.22,29.29,GM
    3.42 Gears,9420095,Carrier Side Bearings,35.5,20.2,GM
    3.73 Gears,26018946,3.73 ABS Reluctor,6.72,GM
    6N1 Lock Module,16630059,6N1 Lock Module,57.5,45.6,GM
    96 Corvette LT1 Engine,10210312,96 Corvette LT1 Engine,GM
    96 Corvette LT4 Engine,12551183,96 Corvette LT4 Engine,GM
    9C1 Wiper (Deflector) and Blade,10283602,9C1 Deflector and Blade,25.5,15.52,GM
    A/C Pulley,2724717,A/C Pulley,GM
    Accelerator Linkage,10242904,Bracket,3.8,2.78,1,GM
    Accelerator Linkage,10260166,Accel Cover,5.45,3.99,1,GM
    Accelerator Linkage,11505169,Bolt,.34,.24,1,GM
    Air Deflector (SEO 9C1),10220593,Front Lh Air Deflector (SEO 9C1),4.05,2.96,GM
    Air Deflector (SEO 9C1),10220594,Front RH Air Deflector (SEO 9C1),4.05,2.96,GM
    Ash tray asm,10197140,Ash tray asm,56.75,GM
    Belt Tensioner,10238703,Belt Tensioner,GM
    Belt,12550149,Belt,GM
    Belt,K060637,Belt,Gates,21mm x 1635mm
    Bracket Screw,11514607,Bracket Screw,.32,.23,GM
    Bulb with the Blue Condom Pontiac #158 Bulb,10031004,Bulb with the Blue Condom
    Pontiac #158 Bulb,1.35,.99,GM
    Cam,10185071,ZZ3 HO 350 Cam,GM
    Car Car Kit in a Case with Bowtie Logo,12344998,Car Car Kit in a Case with Bowtie Logo,14.95,10.94,GM
    Carpet / Mats,12343594,Mat Pkg, Rear,26.19,24.5,2,GM
    Carpet / Mats,12343624,Mat Pkg, Front,26.19,24.5,2,GM
    Carpet / Mats,12528553,Carpet,361,1,GM
    Console Hinge,22555614,Console Hinge,7.4,GM
    Console Lid,12531192,Console Lid,48,38.06,GM
    Console Shifter Frame (Assm?),10282773,Console Shifter Frame (Assm?),377.8,GM
    Console Shifter Top,10271069,Console Shifter Top,48.5,38.47,GM
    End Gasket,GM
    Correct Fel-Pro Rear End Gasket,RDS 55028-1,Correct Fel-Pro Rear End
    Gasket,Fel-Pro
    Corvette Fuel Rail Covers,10108672,Stud-f/in,1.4,1.02,4,GM
    Corvette Fuel Rail Covers,10208794,Cover Asm - RH,10.35,7.58,1,GM,Use when also installing Corvette Valve Covers
    Corvette Fuel Rail Covers,10208795,Cover Asm - LH,10.35,7.58,1,GM,Use for all Corvette Fuel Rail Covers,10214035,Hose-p/b,7.25,5.31,1,GM,Included for Clearance Problems
    Corvette Fuel Rail Covers,10224936,92 Vette Fuel Rail Cover - RH,22.4,GM,Use when keeping stock valve Covers
    Corvette Plastic Valve Covers,10108605,Cover-vlv,108,79.06,1,GM
    Corvette Plastic Valve Covers,10108606,Cover-vlv,108,79.06,1,GM
    Corvette Plastic Valve Covers,10108625,Gasket-vl,10.65,7.8,2,GM
    Corvette Plastic Valve Covers,10108674,Stud-vlv,2.6,1.9,8,GM
    Corvette Plastic Valve Covers,10108675,Bolt/scre,1,.73,8,GM
    Corvette Plastic Valve Covers,10108694,Cap Asm-o,3.15,1.54,1,GM
    Corvette Plastic Valve Covers,10128361,Hose-c/ca,3.2,2.34,1,GM
    Corvette Plastic Valve Covers,10240678,Grommet,2.3,1.68,1,GM
    Decals / Trim,10111989,Sill plate - front drivers (left),17.25,GM
    Decals / Trim,10161510,Plastic Retainer Clip for Door Panels,.21,.17,GM
    Decals / Trim,10186225,Fuel Bib,12.15,8.89,GM
    Decals / Trim,10220597,For Pursuit Use Overdrive Sticker,GM
    Decals / Trim,10229207,Emissions Bracket,3.35,2.45,GM
    Decals / Trim,10248742,Impala SS Black Body Script,23.1,16.91,GM
    Decals / Trim,10249082,Front Bowtie Emblem,9.9,7.25,GM
    Decals / Trim,10250947,Impala SS Dash Plate,4.85,3.84,GM
    Decals / Trim,10253594,Impala SS Emblem Rear Qtr Rh,5.45,3.99,GM
    Decals / Trim,10253595,Impala SS Emblem Rear Qtr Lh,5.45,3.99,GM
    Decals / Trim,10261527,Console, Cup Holder Insert,2.1,1.67,GM
    Decals / Trim,10262808,Impala SS emblem Rear QTR Green,GM
    Decals / Trim,10262809,Dark Cherry Metallic Impala SS Script,23.1,16.91,GM
    Decals / Trim,10267037,Caprice SS Black Body Script,40,29.28,GM
    Decals / Trim,10267038,Caprice SS Script in Grey Green,40,29.28,GM
    Decals / Trim,10267039,Caprice SS Script in Dark Cherry,40,29.28,GM
    Decals / Trim,10268239,Caprice SS, Dash Script above Radio,12.6,9.22,GM
    Decals / Trim,10283878,Dex-cool Notice Sticker,8.1,5.49,GM
    Decals / Trim,10285918,Dexcool Radiator Cap,4.35,3.18,GM
    Decals / Trim,11516061,Emissions Bracket Bolt,.9,.66,GM
    Decals / Trim,12516867,moulding kit FRT S/D LWR (left),80.5,GM
    Decals / Trim,12523079,Impala SS Trunk Emblem Black,27.75,20.31,GM
    Decals / Trim,12524202,Impala SS Trunk Emblem Grey Green,27.75,20.31,GM
    Decals / Trim,12524203,Impala SS Trunk Emblem Kit Dark Cherry,27.75,20.31,GM
    Decals / Trim,16164576,Clear Plastic Instrument Cover,15.3,11.2,GM
    Dexcool Gallons,12346290,Dexcool Gallons,13.25,9.7,GM
    Driving Light Lamp Assembly,12121021,Wiring Harness,193,141.28,GM
    Driving Light Lamp Assembly,12511563,Brackets,75.5,55.27,GM
    Driving Light Lamp Assembly,16511879,Driving Lights,116,84.91,GM
    Driving Light Lamp Assembly,20669667,Switch,32.5,23.79,GM,Can somebody help me with this one?
    Dual stainless steel muffler,IMP116B,Dual stainless steel muffler system?,695,ATR (864) 972-3800,2 1/2  and T-304
    Electrical Recall Parts,11516161,Nut, Stud Assembly,.27,.2,GM
    Electrical Recall Parts,12129481,Busbar, Cavity L1 and L3,4.35,3.18,GM
    Electrical Recall Parts,12146182,Busbar, Cavity L2 and L4,5.35,3.92,GM
    Electrical Recall Parts,12146183,Cover, Electrical Center Stud,1.3,.95,GM
    Electrical Recall Parts,12161130,Stud Assembly,11.6,8.49,GM
    Electrochromic Mirror with Digital Compass,12344614,Mirror Pk,274.9,201.23,1,GM
    Export Leaded Fuel Only Front Exhaust Pipe,10168551,Gasket-ex,5.65,4.14,1,GM
    Export Leaded Fuel Only Front Exhaust Pipe,10204014,Pipe Asm-,73.5,53.8,1,GM
    Export Leaded Fuel Only Front Exhaust Pipe,10204015,Pipe Asm-,73.5,53.8,1,GM
    Export Leaded Fuel Only Front Exhaust Pipe,12550283,Gasket-ex,5.65,4.14,1,GM
    Export T84 Capsule Headlamps,16519237,Capsule a (Left),256,187.39,1,GM
    Export T84 Capsule Headlamps,16519238,Capsule a (Right),256,187.39,1,GM
    Export T84 Capsule Headlamps,6288471,Connector,.86,.63,2,GM
    Export T84 Capsule Headlamps,6294068,Terminal,.47,.34,6,GM
    Front Air Dam,10109530,Front Air Dam Center Section,GM
    Glovebox Latch,12527729,Glovebox Latch,11.7,9.28,GM
    Grill,10269614,Impala SS Grill Black,82,60.02,GM
    Grill,10269615,Impala SS Grill Grey Green,91.25,66.8,GM
    Grill,10269616,Impala SS Grill Dark Cherry,91.25,66.8,GM
    Hub Caps,9592229,Hub Caps,20,GM
    Instrument bezel,10250238,Instrument bezel,GM
    Intake,25147187,95 1LE F-car Duct with Distributor Vent Nipple,112.5,82.35,GM
    Intake,25147210,94 1LE F-car Duct W/O Distributor Vent Nipple,93.5,70,GM
    Long Block,10185072,HO 350 Long Block,GM
    LT4 Heads,12363287,LT4 Heads,499,456.59,GM
    Mobil-1 Oil Fill Cap (96 Vette),12554955,Mobil-1 Oil Fill Cap (96 Vette),3.5,1.71,GM
    Mobil-1 Plate (92-95 Vette),10236268,Mobil-1 Plate (92-95 Vette),8.1,5.49,GM
    O2 Bungs for Export Pipes,LN0055-B,O2 Bungs for Export Pipes,Lingenfelter,1/4 thick steel 1.25 by 1.25 centered 21/32 hole tapped 18MM x 1.5
    PCM Calibration - 94,16200341,PCM Control Module Calibration - initial 94,GM,Initial 94 calibration
    PCM Calibration - 94,16202491,PCM Control Module Calibration - update 94,GM,Improve AIR system performance
    PCM Calibration - 94,16207221,PCM Control Module Calibration - update 94,GM,Fix for clunk when shifting gears and cold engine surge
    PCM Calibration - 94,16232021,PCM Control Module Calibration - update 94,GM,Fix for chuggle and surge
    PCM Calibration - 95,16206641,PCM Control Module Calibration - initial 95,GM,Initial 95 calibration
    PCM Calibration - 95,16209351,PCM Control Module Calibration - update 95,GM,New calibration to improve driveability
    PCM Calibration - 95,16232011,PCM Control Module Calibration - update 95,GM,Correct chuggle and surge
    PCM Calibration - 96,16229981,PCM Control Module Calibration - initial 96,GM,Initial 96 calibration
    PCM,16188051,Replacement PCM,1,GM
    Quad stainless steel muffler,IMP116A,Quad stainless steel muffler system?,895,ATR (864) 972-3800,2 1/2  and T-304
    Rear Lower Control Arms,10289786,New Design 9C1 Lower Rear Control Arms,44.75,32.76,GM
    Seat,16726726,Power Seat Assembly (ADJ SA-D),GM
    Seat,16731968,Power Seat Assembly (ADJ ASM-P),GM
    SEO 1T1 Silicone Rubber Hose Kit,10197619,Hose Asm,57.75,35.14,1,GM
    SEO 1T1 Silicone Rubber Hose Kit,10219447,Hose-cool,9.15,5.56,1,GM
    SEO 1T1 Silicone Rubber Hose Kit,10256544,Hose Asm,58.5,42.46,1,GM
    SEO 1T1 Silicone Rubber Hose Kit,10258505,Valve Asm,92.67,70.21,1,GM
    SEO 1T1 Silicone Rubber Hose Kit,10260863,Hose Asm,37.5,22.81,1,GM
    SEO 1T1 Silicone Rubber Hose Kit,12522853,Hose,cool,12.9,7.84,1,GM,Not Needed for 95 and 96
    SEO 7L9 Power Steering Fluid Cooler,2091638,Clamp -Lo,1.35,.99,1,GM
    SEO 7L9 Power Steering Fluid Cooler,26036034,Pipe Asm-,27,19.76,1,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),10219157,Bracket-e,1,.73,1,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),10225895,Pipe Asm-,11.1,8.13,1,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),10225896,Pipe Asm-,11.1,8.13,1,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),10226222,Cooler As,75.25,60.94,1,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),10260341,Hose Asm-,43.25,31.66,1,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),12337917,Nut,rr Bp,.92,.67,3,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),15966491,Clip,1.85,1.35,2,GM
    SEO 7P8 Engine Oil Cooler (Oil-to-air),20351035,Screw,.73,.54,3,GM
    SEO 9C1 High-speed Windshield Wiper Blades,5049730,Blade Asm (May Be Old Part Number),25.5,15.52,2,GM
    SEO B48 (B42?) Trunk Mat,10211580,Heavy Duty Trunk Mat SEO B42,75.25,59.67,1,GM
    SEO Heavy Duty Battery,1981590,Battery,86.62,76.08,1,GM
    Sender,24.95,16.91,GM
    Shift Kit (Art Carr),17050,Shift Kit (Art Carr),Art Carr
    Shock Absorbers,22064499,SEO 8X3 Bilstein Heavy Duty Shock Absorbers,159.36,100.85,2,GM
    Shock Absorbers,22064600,SEO 8X3 Bilstein Heavy Duty Shock Absorbers,193.87,122.68,2,GM
    Sir Module Assy, Light Grey,16757619,Sir Module Assy, Light Grey,606,517.52,GM
    Spoiler,12337977,Impala SS Rear Spoiler Bolts,.63,.46,GM
    Spoiler,12524697,Impala SS Rear Spoiler,358,262.06,GM
    Springs,22076517,1995 Rear Springs 18.0 N/mm RC,60.5,44.29,GM
    Springs,22076523,1994 7B3 Suspension Rx,57,41.72,GM
    Springs,22076526,1995 Rear Springs 27.0 N/mm RX,60.5,44.29,GM
    Springs,22078017,Highest Load Rate 1995 Front Springs,84.5,61.85,GM
    Springs,22132375,1995 Rear Springs (Stock),60.5,44.29,GM
    Swaybar (Herb Adams),MOR-86015,Front Swaybar(Herb Adams),Herb Adams
    Swaybar (Herb Adams),MOR-86516,Rear Swaybar (Herb Adams),Herb Adams
    Swaybar Bushings (32mm),26039956,Swaybar Bushings (32mm),Herb Adams
    Swaybar Bushings (34mm),14094388,Swaybar Bushings (34mm),Herb Adams
    Switch,10203772,Panel Asm (Rear Door / Window Switch),28.75,22.8,GM
    Thermostatic Switch,3053190,Thermostatic Switch,GM
    Trim - R/cm,10121580,Trim - R/cm,GM
    Trunk Lamp Assembly,10268235,2nd Design (Late 95) Trunk Lamp Assembly,9.3,6.81,GM
    Wheel Assembly, Steering (Leather, Light Grey),16757633,Wheel Assembly, Steering (Leather, Light Grey),371,271.57,GM
    16671169, woodgrain door bezel, list 34.50, net 27.60, each, 4 required
    10242034, woodgrain door bezel insert (driver), list 64.25, net 51.40
    10242035, woodgrain door bezel insert (pass), list 34.50, net 27.60
    10242040, woodgrain door bezel insert (driver rear), list 28.00, net 22.40
    10242039, woodgrain door bezel insert (pass rear), list 28.00, net 22.40
    25121978, stainless fuel filter (AC #GF624K), list 37.85, net 16.31
    Re: 1977-1990 List of Part Numbers
      Current date/time is Tue Feb 20, 2018 10:07 pm
