    GM B Body Swap
    oldsbuickhybrid
    GM B Body Swap
    Post  oldsbuickhybrid on Thu Nov 12, 2015 5:57 am
    I really love my olds.  Unfortunately it is very very very rusty.  If it were not repairable, would a body swap be possible?  Should all year and model b bodies swap directly to my frame?  Just weighing my options.
    Last edited by oldsbuickhybrid on Thu Nov 12, 2015 1:58 pm; edited 1 time in total
    -Mike-
    1985 Delta 88 (Project)
    Re: GM B Body Swap
    Post  Myloth on Thu Nov 12, 2015 1:02 pm
    I believe you could even swap 68 GTO if you wanted to it might even be a bolt-on lol. Our
    frame has been used by GM since the 60s with little changes til 90 and even then only a few
    mods were done. The big changes to Caprice \Impala \Olds\Buick in 1977 for ie was the body,
    frame is almost the same one used on GTOs. They made almost no changes from 77 thru 90 so
    anything except Cadillac (that uses a longer version frame)will be a bolt-on for the most part.
    As far as the 91-96 maybe someone could answer that one my knowledge there is limited.
    oldsbuickhybrid
    Re: GM B Body Swap
    Post  oldsbuickhybrid on Thu Nov 12, 2015 2:01 pm
    Myloth wrote:I believe you could even swap 68 GTO if you wanted to it might even be a bolt-on lol. Our
    That is great to hear. Honestly, my car's rusted body is what scared me the most about my project. I am glad to see I do have options.
    -Mike-
    Re: GM B Body Swap
    Post  Myloth on Thu Nov 12, 2015 8:42 pm
    That's the best thing about b bodies really is you have a lot of interchange so whether it's parts
    or swaps like in your case there are a lot of options . The only problem I have has so far is the
    little parts that were original like finding a wiper switch. But that goes for any vintage auto so
    it should without saying but oops too late I said it.
    oldsbuickhybrid
    Re: GM B Body Swap
    Post  oldsbuickhybrid on Mon Nov 16, 2015 2:55 am
    Myloth wrote:That's the best thing about b bodies really is you have a lot of interchange so whether it's parts
    I couldn't agree with you more. Finding parts has got to be the hardest part of owning an older car. If you don't mind losing the car's originality, perhaps parts from newer cars can be made to work? For example, later on, I want to convert to automatic headlights on the Delta. First thing I need to do first, is get a job Laughing
    -Mike-
    Boogie1468
    Frames
    Post  Boogie1468 on Sun Apr 10, 2016 3:51 pm
    If you are talking about your 85 Delta 88, the frame is exactly the same as the Caprice from 1977 to 1990. The bumper shock absorbers might be different, but the basic frame is identical. in 1991 to 1996 the frame got three changes, but still all the body mount locations are the same. The three chnages from the 77-90 to th3 91-96 are:
    1. cross member mounting brackets are different (the 94-96 is best for this since the factory dual exhaust stamped cross member makes a great dual exhaust set up without having to hack/weld the tubular cross member.
    2. The bolt-on frame supports at the front near the LCA pivots became weld- on - and this makes no difference to a swap
    3. The engone cross-member got a big bash on the front right side to clear the AC compress wheich was moved to the lower right front of the engine.
    In fact, I used a 96 9C1 frame on my 78 coupe - and it was an easy swap - and now I have a great dual exhaust and an LT1 from the 96 in it.
    mobilemowers
    Re: GM B Body Swap
    Post  mobilemowers on Sun Apr 10, 2016 5:14 pm
    Interesting post. Sorry you have all the rust issues. Can that newer cross member work on the 77 and up body's? I upgraded my trans to a 200R4 for the gas and since car is less then 200hp will hold up fine. Even Grand Nationals came with them. Just had to get a 90 or so cross member.
    Re: GM B Body Swap
      Current date/time is Mon Feb 19, 2018 6:39 pm
