    295 tire on a 10 inch wheel
    bossbox
    Post  bossbox on Mon May 02, 2016 7:47 am
    Anybody have a caprice with a 295 tire on the rear? If so post some pics. Thanks
    Re: 295 tire on a 10 inch wheel
    Post  Sweet Seventy9 on Mon May 02, 2016 11:30 am
    bossbox wrote:Anybody have a caprice with a 295 tire on the rear? If so post some pics. Thanks
    15x10 wheels, 295-50/15 tires on the rear.
    bossbox
    Post  bossbox on Mon May 02, 2016 11:51 am
    Nice! Whats the back spacing on those wheels?
    bossbox
    Post  bossbox on Mon May 02, 2016 12:36 pm
    Thats a very clean car bro! I see our cars fit those 295s with ease.
    Post  Myloth on Mon May 02, 2016 12:44 pm
    I believe 4.5" this pic here has a 1" spacer on it do to the rearend being 5x5 bolt pattern
    so they stick out a tad more. I'd measure them but it's raining right now.
    It's a good fit either way I bet you could fit 15x11 with 305s on these B Bodies
    Post  Sweet Seventy9 on Mon May 02, 2016 12:54 pm
    bossbox wrote:Nice! Whats the back spacing on those wheels?
    5" back spacing, zero offset. They're made by Wheel Vintiques. I wanted to use Rally wheels, only wider.
    http://www.jegs.com/i/Wheel+Vintiques/939/30-503405/10002/-1
    For a little more $$, Paulsons Wheels makes them with a dual lug pattern, 5x5 and 5x4.75.
    bossbox
    Post  bossbox on Mon May 02, 2016 12:59 pm
    Cool! I have 15x10 billet specialties street lites with 5.5 backspace. Im trying to tuck them in under the body as much as possible with a 295 50 15 tire.
    bossbox
    Post  bossbox on Mon May 02, 2016 1:00 pm
    15x11 with a 305 would be nasty!
    Post  Sweet Seventy9 on Mon May 02, 2016 1:02 pm
    315s fit too
    bossbox
    Post  bossbox on Mon May 02, 2016 1:08 pm
    I would love to see a 315 on there.
    bossbox
    Post  bossbox on Mon May 02, 2016 1:10 pm
    Did you have a spacer on in the first set of pics you sent?
    Post  Sweet Seventy9 on Mon May 02, 2016 2:11 pm
    bossbox wrote:Did you have a spacer on in the first set of pics you sent?
    No spacers.  Myloth is using adapters to convert from 5x5 (axle) to 5x4.75 (wheel)
    bossbox
    Post  bossbox on Mon May 02, 2016 2:25 pm
    The adapter makes the wheel poke out slightly right?
    Post  Myloth on Mon May 02, 2016 3:53 pm
    I like the look with the spacer, it's just in from the wheel well flare by 1/2 click
    if you had 315s with no spacer it would look like that I suspect.
    Also given the width of these cars 295s don't even look all that big.
    I had 245s on an 05' Impala and they looked about the same as
    the 295s on the 79'.
    Post  terry cronk on Fri May 13, 2016 10:09 pm
    I am putting 275-60x15 on 8 inch rims. I have some concern. Maybe no need be.
    bossbox
    Post  bossbox on Fri May 13, 2016 10:54 pm
    275 on an 8 inch wheel shouldn't be a problem at all.
    bossbox
    Post  bossbox on Fri May 13, 2016 10:58 pm
    How do you post pics on here? Lol
    Post  Myloth on Sat May 14, 2016 8:36 am
    Use the host image then copy the link it gives you for your picture into the post
    Greyghost
    Post  Greyghost on Thu Jun 09, 2016 1:03 pm
    315's dont look all to bad, ill post a picture either tonight or tomorrow, they dont seem to poke out as far as his 295's either
      Current date/time is Mon Feb 19, 2018 6:44 pm
