    Engine Break In Mishap
    Post  HeavyChevy77 on Mon Apr 17, 2017 11:59 pm
    Ok been working on my motor swap making everything pretty painting brackets/engine/ engine bay frame/exhaust manifold was gonna post all the pics when done
    Finally found tdc since balancer mark wasn't lining up
    Got her started sounded great warmed up to break in cam @ 2k or little more varying little bit through out.
    Well 10 mins later BOOM!! Steam everywhere. ..my read end cap blew off ..panic cleaned the engine and assessed damage engine still runs fine thank god. But wondering what went wrong I filled the block then radiator BUT forgot to take of cap when initially starting up so im thinking just air in the system..
    Buying new rad tomorrow with me luck
    Re: Engine Break In Mishap
    Post  HeavyChevy77 on Tue Apr 18, 2017 12:30 am
    Fierro51
    Post  Fierro51 on Tue Apr 18, 2017 9:54 am
    HeavyChevy77 wrote:
    ouch
      "Oh"
    4.8 turbo LS TH350 swap
    2015 F250 ccsb Platinum
    Post  Kit1078 on Tue Apr 18, 2017 10:05 am
    Looks like a faulty radiator. Unless it overheated or something else that would cause too much pressure in the cooling system. I've had those aluminum/plastic radiators fail there before, but not at initial startup.
    Post  HeavyChevy77 on Tue Apr 18, 2017 10:34 am
    No overheating but maybe it cause I didn't remove the rad cap to purge air in the system?? Or a bad rad all I do know is that it scared the shit outta me when it happened.
    Post  Myloth on Wed Apr 19, 2017 1:01 am
    As rule the last thing I would do is put on the radiator cap. Usually fill then run motor then check level while engine is
    running and fill again. You def could have had lots of air in there to cause that problem. Sometime you even
    have to burp them few times to get it out.
    Fierro51
    Post  Fierro51 on Wed Apr 19, 2017 6:44 pm
    replace the cap for piece of mind as well.
      "Oh"
      Current date/time is Mon Feb 19, 2018 6:42 pm
