    A/C Evaporator Condensed Water Drain
    paulboncz
    Post  paulboncz on Thu Jun 22, 2017 2:41 am
    Would someone please tell me where to look for the A/C evaporator drain opening on my '78 Impala 305. The drain is apparently plugged since i get decent cooling but zero water seeping to the ground. Thanks.
    Re: A/C Evaporator Condensed Water Drain
    Post  GM B-Body Forum on Fri Jun 23, 2017 9:10 pm
    Its kinda hard to get to, you'll have to loosen the inner fender wheel well to reach it, but its on the bottom left hand side if your facing the front of the car. Its a rubber flap and its a decent size so must have a lot of debris built up in there!
    Post  GM B-Body Forum on Fri Jun 23, 2017 9:28 pm
    The second picture down there's a long flap right under where the blower motor sits https://www.gmbbodyforum.com/t46-leaking-heater-box-disassembly?highlight=Heater+box
      Current date/time is Tue Feb 20, 2018 10:14 pm
