    89 Caprice Cooling Problems
    Toliver843
    Post  Toliver843 on Tue Sep 12, 2017 12:39 pm
    I have a 89 caprice with a 350 sbc bored 60 over carb. Cant keep it cool gotta 165 thermostat and if you crank it and let it idle it still runs up to 200 but if you drive it it never cools it steady rises. I put an electric fan on it and when its on it doesnt even bring temp down. If it gets to 210 and i put it in park i never cools back down just maintains temp. I have a one row brand new radiator could that be the problem or is it something the man that built the motor didnt do right?
    Re: 89 Caprice Cooling Problems
    Post  Kit1078 on Tue Sep 12, 2017 10:19 pm
    I'd check the thermostat first. it sounds like it's not opening properly.
    Toliver843
    Post  Toliver843 on Tue Sep 12, 2017 10:22 pm
    Brand new thermostat. Bought a 180 and them bought a 165 still didnt do it
    89 cooling
    Post  terry cronk on Wed Sep 13, 2017 11:11 am
    I purchase a 4 core radiator from California. Its a Champion. I run a 160 thermostat plus an electric fan.
    My 383 engine has 11 to 1 compression and a 700R4 w/3.73 gears.
    When cruising the highway its right at 160 with no fan on. In town I flip it on and it stays cool. Otherwise it will go to 180.
    http://www.ebay.com/usr/super-radiator?_trksid=p2053788.m1543.l2754
    This is the link.
    terry cronk wrote:I purchased a 4 core radiator from California.   Its a Champion.  I run a 160 thermostat plus an electric fan.
    This is the link.
    Post  Myloth on Wed Sep 13, 2017 3:25 pm
    Hi
    Check the small stuff first save a few. Did you flush and burp the system? How about you water pump is it heavy duty , heavy heavy duty or plain cast iron ? If it's just cast iron get an aluminum Impeller Heavy duty at least if not the all aluminum Hvy Heavy duty.
    Is your heat working (Possible problems with heater core)? Is your pressure cap holding pressure?
    Toliver843
    Post  Toliver843 on Wed Sep 13, 2017 11:45 pm
    Yes burp the system water pump is the stock water pump. I bought a stock 3 row radiator from Napa today it cooled better but still runs arpund 205-215
    oldsbuickhybrid
    Post  oldsbuickhybrid on Sat Sep 23, 2017 4:04 am
    What kind of E- fans are you running? If they are undersized, like a lot of aftermarket fans, they may be your culprit.
    When I first fixed up my engine, I was running small, puny fans that I bought on Amazon, and my car would overheat. After that, I switched them out for 2005 Chrysler 300 fans, and problem solved.
    -Mike-
    1985 Delta 88 (Project)
    cooling
    Post  terry cronk on Sun Sep 24, 2017 11:30 am
    I run the 4 core aluminum radiator as I mentioned.  The fan is a 16" 2400cfm fan that I can turn on as needed.
    I have the air flow coming from front to back.
      Current date/time is Tue Feb 20, 2018 10:17 pm
