    Body mounts
    Body mounts
    Post  terry cronk on Mon Oct 09, 2017 10:13 am
    Does anyone have a number for universal mounts that fit my 79 Caprice?
    JC Whitney has some but until I pull the old ones, I'm not sure which are the right ones.
    Anyone replace theirs?
    78i6belair
    Re: Body mounts
    Post  78i6belair on Tue Oct 10, 2017 8:36 am
    Hi there.
    From the information that I've gathered, There are no direct replacements available for the 1977-96 B cars and wagons. I could be wrong here.
    I'd look and see if you can locate body mounts for a 1973-77 GM midsize A body and the 1977-93 C body cars.
    Re: Body mounts
    Post  Kit1078 on Tue Oct 10, 2017 8:29 pm
    I used the Energy Suspension kit for a 91-96 B body, the light duty version. The light duty version does not have all the captured lower bushings like my '77 had, but I had enough good ones left over from the original bushings that I was ok. They did not come with washers or sleeves, tho, so if those are rusted out, you're kinda up a creek.
    Body mounts
    Post  terry cronk on Fri Oct 13, 2017 4:00 pm
    Washers and sleeves can be gotten. The good poly bushing is the issue. Even stock new would be better.
    Thanks
    alusil850
    77-79
    Post  alusil850 on Sat Nov 04, 2017 5:12 pm
    hi,
    old post but some news for it.
    after a long time without oem part available, this body mount from dorman look to do the job,
    is ref is:
    DEA/MRC A2714
    I order it for 3$ each on rockauto.
    but if anybody know the location of original bodymount, all are differents, and I don't find logic, soft, hard, with or without lateral handling...
    Gooched78Caprice
    Complete 1977-1990 B-Body Body Mount Bushings with Steel Sleeve Inserts $249
    Post  Gooched78Caprice on Sun Nov 05, 2017 1:02 pm
    https://www.thepartsplaceinc.com/home.aspx
    Part # HB10531P
    I don't see the very front radiator mounts with this kit but the rest of the Body Bushings are there.
    I did about 6 months of weighing +/- about replacing my bushings with energy suspension poly bushings since I couldnt find the a direct specific set like these anywhere and of course a few weeks after taking the plunge on Energy Suspension these came out.
    Extra Bonus* If you are also in need of the metal inserts for the body bushings with these <40 year old cars this will save you a bunch of time versus trying to amass a set out of the junk yard and none of the Energy kits supply them.
    Irene A. Rittle
    1978 Caprice Classic Landau
    body mounts
    Post  terry cronk on Thu Nov 09, 2017 4:39 pm
    Thanks for the information.
    That's $249.00 for all 22 mounts.
    Re: Body mounts
      Current date/time is Mon Feb 19, 2018 10:44 am
