    How do I make my B-body handle better?
    How do I make my B-body handle better? Empty How do I make my B-body handle better?
    Post  Sweet Seventy9 on Fri Jan 24, 2014 11:03 am
    "Borrowed" from somewhere on the web.
    First off let me say that this is directed primarily at the 77-90 cars, those without the F41 or 9c1 suspensions and is directed at the budget minded owner. This is not the ultimate handling setup for a B-body, it's how to make it much better for very little money.
    Change your front sway bar
    Most 77-90 B-bodies, that don't have the F41 suspension package, have hollow front sway bars. You can determine this by looking at the ends of the sway bar. Near the holes for the end links, on the bottom side of the sway bar, you will see a drain hole. There should be one on each side. These bars are nothing more than hollow pipe and they will rust from the inside out and break. Change that out for a 9C1 sway bar, GM P/N 457923 using the stock end links and bushing will net a big improvement in handling and a considerable drop in body roll during cornering.
    Want even better handling?
    A 2nd generation F-car('70-'81) WS6 front sway bar, GM P/N 356534. This part is no longer available new from GM. But thousands are out there in junkyards, go get dirty for once.
    Combine this with the '95-'96 1LE sway bar end links, GM P/N 10221779. You'll need two(2). And also the 4th gen. ('93-present) F-car sway bar bushing, GM P/N 10288551. You'll need two(2).
    More? You want more?? Replace your Bumpstops. Add the 2nd design S-10 ZQ8 micro-cellular progressive jounce bumper, or the foamy bumpstop GM P/N 15956547. You'll need one for each side.
    Add a rear sway bar - The sway bar mentioned below applies only to sedans. This swaybar will NOT fit wagons.
    Quite a few, perhaps most, 1977-1990 Bodies came without a rear sway bar. In this case you will need to change the rear lower control arms to be able to add the rear sway bar. The cheapest way to do this that I've found is the 9C1 Lower Control Arm Kit GM P/N 10289786. The Lower Control Arm kit is an upgraded pair of LCAs and the necessary mounting hardware from a technical service bulletin(PRODUCT SAFETY CAMPAIGN 96-C-18) for 91-96 9C1 and 9C6 equipped Caprices. These will also fit all 77-90 model b-bodies. If your car is not equipped with a factory rear sway bar, these or an aftermarket set of LCAs will be required to install a rear sway bar.
    The kit includes:
    2 Lower Control Arms
    4 LCA Attaching Bolts
    4 LCA Attaching Nuts
    4 Stabilizer Bar Attaching Bolts
    4 Stabilizer Bar Attaching Nuts
    4 Stabilizer Bar Washers
    4 Stabilizer Bar Brackets
    4 Stabilizer Bar Adapters
    The best bang for the money rear sway bar would be the 9C1 rear sway bar. It is still availble thru GM P/N 10207649.
    A great improvement over this would be the HO rear sway bar for the 1994-1996 ImpalaSS.
    Check with Summit Racing or Jegs for these.
    For you wagon owners get in touch with Bruce Allison at Malibu Performance. e-mail malibruce@earthlink.net (818) 222-6725. He should be able to set you up with an HO rear sway bar for the b-body wagon.
    For swaybars, also check with Year One. They offer Addco bars(front and rear) for sedans AND wagons.
    Add the Buick Frame Brace
    The Buick Frame Brace, GM P/N 10225142, from TSB #921046. This will help on two fronts. One - it reduces exhaust noise or "droan" by stiffening the frame. And two - Guess what else stiffening the frame does....Makes the car handle better! This is literally the cheapest and easiest handling modification that you can do. Want the same benefits of this and be able to tow something??? Installing a hitch will have the same effects. Once again the Buick Frame Brace will fit only sedans and will not fit on wagons.
    Add Airlift 1000 air bags
    The Airlift1000 air bags will do a couple of things. First, they will give you added load hauling capabilities. Second, they will give you the ability to adjust the preload on the suspension to aid the off the line traction for accleration. I recommend installing them with seperate air lines for each bag rather than using the "T" fitting included in the kit. You can drill two holes behind the license plate braket to mount the air valves. That way they are both hidden and you have easy access to them.
    Change your shock absorbers
    Even if you don't have a 9C1(Police Package) B-body, I recommend getting a set of shocks for a 9C1 in your favorite brand. I used the cheapest ones I could find, Gabriel Red Ryders, on my 1986 Caprice. This modification turned the mushy, couch driving ride into a more responsive, firmer ride.
    Change Your Springs
    Now if you want to do this on the cheap, I usually do. Get a set of used 1994-1996 ImpalaSS springs. They will lower the car an inch or so overall. If you have more $$$, get a set of lowering springs made for the 1994-1996 ImpalaSS. These will lower the car even more. Your ride will suffer though.
    How do I make my B-body handle better? Empty Re: How do I make my B-body handle better?
    Post  GM B-Body Forum on Fri Jan 24, 2014 1:29 pm
    yeah this is from b-body.org, moved to "upgrades" also
    How do I make my B-body handle better? 20150410
    Post  Sweet Seventy9 on Fri Jan 24, 2014 3:52 pm
    GM B-Body Forum wrote:yeah this is from b-body.org, moved to "upgrades" also
    Actually, no. It might be there too, but I got it from another site. Smile
    Post  solo79 on Fri Jan 24, 2014 5:09 pm
    There's another way.lol Certainly not what most would do but it's interesting to me. My first 79 Caprice had major body roll around turns when it was factory suspension even after new shocks, springs, bushings, end-link kit etc. After installing hydraulics a couple of years later with 2 ton coils in the front, 1.5 ton coils in the rear, making custom swivel shock mounts to keep rear shocks and removing the front sway bar completely, it handled like it was on rails with zero body roll at any ride height. Why? I don't know, but it handled 80% better and rode well with very little bounce.
    Post  GM B-Body Forum on Fri Jan 24, 2014 11:00 pm
    Sweet Seventy9 wrote:Actually, no. It might be there too, but I got it from another site.
    Haha well its on at least three sites now lol
    JusSko77
    JusSko77
    Post  JusSko77 on Thu Jun 30, 2016 11:32 am
    Anyone know of what cars we can use tubular upper and lower control arms from?
    How do I make my B-body handle better? 56016810
    Post  Myloth on Thu Jun 30, 2016 12:26 pm
    http://www.streettrendsinc.com
    This place has lot of stuff for B bodies.
    The later B body arms works the arms they are all pretty much
    the same arms you may have to play with shims and get it aligned that's about it.
    If you read forums many say they have used the 70-81 Camaro arms upper and lower
    to replace stock arms on B bodies. Even the brakes are the same parts, that's GM for you.
    A lot of parts manufacturers and retailers don't know or bother to find this out.
    Post  Sweet Seventy9 on Thu Jun 30, 2016 12:42 pm
    JusSko77 wrote:Anyone know of what cars we can use tubular upper and lower control arms from?
    2nd Gen F body are exactly the same. Some aftermarket companies make ones specific to B bodys and charge more but the specs are identical.
    JusSko77
    JusSko77
    Post  JusSko77 on Thu Jun 30, 2016 6:08 pm
    You two have not only made my day better, namely cause down with the sickness.
    But, you have given me more hope than the entire 8 years of the Obama administration.
    Thanks for throwing me into a direction and reminding me to get off my lazy ass and start cross referencing things.
    Post  Sweet Seventy9 on Thu Jun 30, 2016 6:48 pm
    Glad to help.
    Post  terry cronk on Thu Jul 07, 2016 10:22 am
    And where does this go?  Is it across the back of the rear bumper as if having a hitch?
    That's added weight at the rear.
    What about behind the crossmember? There's a lot of open frame there. And its at least 18-20 inches (est.) long.
    That seems to be a weak point at best. Any answers to that?
    Post  Sweet Seventy9 on Thu Jul 07, 2016 3:10 pm
    terry cronk wrote:And where does this go?  Is it across the back of the rear bumper as if having a hitch?
    Huh? What are you talking about?
    Gooched78Caprice
    Gooched78Caprice
    Post  Gooched78Caprice on Thu Jul 07, 2016 3:43 pm
    I'll give this a shot!
    And where does this go?  Next to that, right over there.
    Is it across the back of the rear bumper as if having a hitch?  Nope, but getting warmer.
    That's added weight at the rear.  What's wrong with a little junk in the trunk.
    What about behind the crossmember?   What ever you're into, Im not here to judge.
    There's a lot of open frame there.  Yup
    And its at least 18-20 inches (est.) long.   No need to brag
    That seems to be a weak point at best.   That depends on who's view you're coming from.
    Am I anywhere close Terry? Even with my limited mechanical abilities I feel like I did a damn good job answering these ones. Normally I'd leave the hard questions to those more in the know. lol!
    Irene A. Rittle
    1978 Caprice Classic Landau
    Post  terry cronk on Thu Jul 07, 2016 4:19 pm
    You probably should leave the technical answers to someone who knows.
    Try not being a wise cracker to a question posted.
    I did order the part only to have it not available.
    My question was about the Buick Frame stiffener.
    GM P/N 10225142, from TSB #921046 (where is this place)
    PS; Technical Service Bulletin -- OK!
    Gooched78Caprice
    Gooched78Caprice
    Post  Gooched78Caprice on Thu Jul 07, 2016 4:36 pm
    Who you calling a Cracker?
    I am sure most of us who read the question knew exactly what you were speaking in regards to. Even with my limited technical abilities I knew you were referncing the Buick brace mod.
    The responses you receive are normally based on a way you form a question. Questions from out of left field... will tend to get answers from a similar location.
    Now on to answer your questions. A quick search shows that there's a great pic right at the bottom of this Buick Frame Brace thread that SS9 posted.
    https://www.gmbbodyforum.com/t21-buick-frame-brace?highlight=buick+brace
    Post  Sweet Seventy9 on Thu Jul 07, 2016 6:43 pm
    LMAO !!!!!!!
    I'm still laughing!!
    Dude, that killed me!
    Post  Sweet Seventy9 on Thu Jul 07, 2016 6:48 pm
    terry cronk wrote:You probably should leave the technical answers to someone who knows.
    C'mon Bro, relax.  He was only kidding.
    BTW, you can make a frame brace for like $1.75. I did.
    Cut a piece of tubing to the proper length. Compress the ends in a bench vice. Drill 4 holes. Mount. Done. Very Happy
    Post  terry cronk on Thu Jul 07, 2016 8:48 pm
    Thank you Sweet Sevent9. I think I can easily make one of those. Thanks again.
    For the "WISE CRACKER", there wasn't a picture posted initially. But thanks anyway.
    Gooched78Caprice
    Gooched78Caprice
    Post  Gooched78Caprice on Fri Jul 08, 2016 9:35 am
    No prob and always glad to help TC. I'll remember that you take yourself more seriously on here when I see your post.
    Don't forget the search engine on this site works very well. It can be found in the upper left corner of the web page and has helped  me save hours of time and frustration with all the info you can find on here.
    JusSko77
    JusSko77
    Post  JusSko77 on Sat Jul 09, 2016 8:46 pm
    How do I make my B-body handle better? 050d9ad2b86bc19795216a269ea819af2691e3-wm
      Current date/time is Sun Jan 19, 2020 9:55 pm
