    Cluster Connector
    Cluster Connector Empty Cluster Connector
    Post  Myloth on Sat Oct 25, 2014 11:13 am
    Anyone have a diagram of the Cluster Connector next to the Speedometer? Or know the pinouts?
    The connector is 18 pins and has the following wires.
    10 Lt blue   ----------  1 Brown
    11 Dark Blue  -------    2 Dark Green
    12  empty    ---------  3 Light Green
    13 empty  ---------     4 Black
    14 Pink white stripe- -- 5 Gray
    15 2 Brown White Stripe-6 Black
    16 Dark brown ---------7 Pink Black stripe
    17 Black white Stripe ---8 Pink
    18 Yellow -----------    9 Empty
    The only thing I have line on so far is the Directional Indicators which maybe the LT and Dk Blues
    Any ideas? I tried Several diagrams not helpful the Fisher Manual just has color codes
    for the whole car without specifying where. And the Regal-Monte diagram isn't even close.
    Cluster Connector Empty Re: Cluster Connector
    Post  GM B-Body Forum on Sat Oct 25, 2014 9:35 pm
    Yes light and dark blue are the front turn signals, ive got the wiring diagram posted on here, but if you need me to email it to you to see it better i can.
    https://www.gmbbodyforum.com/t54-1977-1978-1979-caprice-impala-wiring-diagram
    DO you have the optional gauge pack? or just the standard cluster? They both use the same wiring, just the gauge pack has an extra wire for the temp gauge.
    But to answer your post:
    10 Lt Blue- Front LH turn sig
    11 Dk Blue- Front RH turn sig
    12---
    13---
    14 i only see pink, with no white stripe- fuel gauge from the tank
    15 2 brown(tan) w/white- brake light, one comes from the ignition switch to light up when starting and the other is from the parking brake switch and the combi valve
    16 Brown (you said: dark brown)- gen light, comes straight from the alternator
    17 Black w/white stripe- ground just for the seat belt light
    18 Yellow- seat belt light
    1 Tan(you said: brown) oil pressure switch
    2 Dk Green- Temp switch, up at the firewall at the junction block, one wire comes from the ignition to turn on when starting and the other comes straight from the temp switch, but you only see one wire at the connector (just an FYI)
    3 Light Green- Bright light indicator
    4 Black- there are two blacks one is for the ground for the ints lamps and the other is ground from the ignition switch to turn the fuel gauge on etc.
    5 Gray- Power for the instrument lights
    6 Same as number 4
    7 Pink w/black stripe- there are two of these and both are positive from the ign, also for the gauges
    8 Same as number 14
    9---
    Sorry this doesnt seem helpful but its what ive got, ive pretty much got these cars' wiring diagram down and know it by heart almost, if you need any more help let me know
    Cluster Connector 20150410
    Post  Myloth on Sat Oct 25, 2014 11:24 pm
    No that's much more helpful than anything I have read so far. All I really need is the basics of the cluster I can figure out
    anything else I just did not want to spend 3 hours testing leads . I am wiring in a new Cluster I made and need the
    signals, lights , fuel , etc . My original speedometer died so I said to heck with it and put together a 6 gauge cluster.
    That and I am ditching the Cruise since it didn't work, price was right the non cruise speedometer cable was only 8 dollars.
    Thank you I am much obliged for this information!
    Post  Sweet Seventy9 on Sun Oct 26, 2014 1:09 am
    Myloth wrote:No that's much more helpful than anything I have read so far.  All I really need is the basics of the cluster I can figure out
    Pics and write-up?  Smile
    I had something similar to this in my track car - Cluster Connector Gauges10
    Post  GM B-Body Forum on Sun Oct 26, 2014 9:47 am
    Yeah post a write up when you do it
    Thanks Sweet for posting that pic again, i was looking for it but couldnt find it, I too am going to do that, and I was going to use the Autometer cobalt gauges so im glad to see theres enough room to do it. Ive also priced out using Autometer gauges and its going to be around $1300 just for the gauges, the full electric sweep, the short sweeps are a little cheaper but not much, but it looks so good!
    Post  Myloth on Sun Oct 26, 2014 3:59 pm
    Sure I can post some pics I'm in the throws of getting it together now. I already pulled the old cluster and
    cruise\speedo cables. It looks similar yes, it's based on a metal template an ebay seller had. I took that and
    ran with it adding an aluminum plate behind it. It will all fit into the spot of the original cluster. (i hope rofl)
    Post  Myloth on Mon Oct 27, 2014 12:03 pm
    On those pink wires 7 has black stripe like 14 but 8 does not have a stripe are these all the same?
    Post  solo79 on Mon Oct 27, 2014 7:26 pm
    GM B-Body Forum wrote:Yeah post a write up when you do it
    That pic is in my build thread somewhere, I think page 6 or 7. $1,300? I think I'd opt for the Dakota Digital cluster for about 800.00 before I did that. I'm still thinking about that really for myself.
    Post  GM B-Body Forum on Mon Oct 27, 2014 9:41 pm
    Oh well maybe it was you who posted that oops lol, anyway, no they are not all the same, the solid pink wire is from the gas tank sender unit, and the two pink and black stripes are positive from the ignition
    Post  Myloth on Mon Oct 27, 2014 10:04 pm
    Thank for that I think I have what I need once I test it all out I'll post how I wired it in case it actually all works!
    Cluster Connector Empty fuel wire
    Post  Myloth on Fri Oct 31, 2014 4:00 pm
    I have everything functional except the gas gauge now I know it maynot read right with oem setup
    but I think the sending wire isn't right? I know it has power because the tach is running off same wire and works
    fine?My bad I literally had my wires crossed used the wrong pink. Now to get that fuel gauge to give the right
    level. Maybe not still not quite right on the fuel but I go straight to the tank when I pull the rearend tomorrow.
    Cluster Connector Empty Correct Wiring
    Post  Myloth on Tue Nov 25, 2014 7:50 pm
    I just wanted to point out your information was spot on. Aside from the Sunpro being incompatible with GM senders
    I bought the Equus Fuel gauge and the first one I received was a dud lol. Now I have the the replacement in and working
    correctly and yes that pink wire is the sender I even seen it coming from the tank in the back thanks again.
      Current date/time is Sun Apr 05, 2020 10:36 pm
