    Gen 1 SBC Weights - Aluminum vs Iron
    Gen 1 SBC Weights - Aluminum vs Iron Empty Gen 1 SBC Weights - Aluminum vs Iron
    Post  GM B-Body Forum on Mon Nov 03, 2014 9:46 pm
    I found this online somewhere, id give the credit but i dont remember where i found it, anyway:
    Gen-1 SBC Weights- Pounds(lbs)
    Block (Iron 4-bolt main)- 165
    Block (Aluminum 4-bolt main)- 95
    Crankshaft- 52
    Cylinder Head (Single Iron w/valves, springs, rockers, etc.)- 50
    Cylinder Head (Single Aluminum w/valves, springs, rockers, etc.)- 25
    Cylinder Head Bolts (All)- 3
    Connecting Rods (Stock 5.7 inches w/caps, studs, nuts)- 12
    Pistons Pins Rings (All)- 9
    Camshaft- 8
    Lifters (Solid All)- 4
    Pushrods (all)- 3
    Timing Set- 3
    Oil Pump- 4
    Distributor (Stock HEI w/cap, rotor, coil)- 6
    Intake Manifold (Stock 4-Barrell Aluminum)- 18
    Carburetor (Holley 4-Barrell) 12
    Carburetor (Holley 2-Barrell)- 7
    Fuel Pump (Stock Mechanical)- 2
    Headers- 10
    Flywheel (Iron 168 teeth)- 28
    Harmonic Damper- 8
    Water Pump (Iron Short)- 9
    Water Pump (Aluminum Short)- 5
    Valve Cover (1 Steel)- 2
    Timing Cover (Steel)- 1
    Oil Pan (Steel)- 7
    Alternator (Stock Delco 1977)- 10
    Starter (Stock)- 18
    Starter (Tilton)- 9
    Pulleys (Steel)- 6
    Brackets (Steel)- 4
    SBC Complete, Iron block, Aluminum Heads, 4-Barrell Holley,
    Lightest Parts, No Flywheel- 425
    Same as above with Aluminum Block- 355
    Gen 1 SBC Weights - Aluminum vs Iron 20150410
    Gen 1 SBC Weights - Aluminum vs Iron Empty Re: Gen 1 SBC Weights - Aluminum vs Iron
    Post  GM B-Body Forum on Fri Aug 28, 2015 11:49 am
    And this list is of what ive weighed myself in lbs:
    EQ vortec heads 64cc 55lbs
    starter 19.4
    iron water pump long 16
    har bal 8
    alt 12
    quadrajet 10.5
    smog heads 76cc on gm goodwrench 350 45.5
    radiator brass copper 3 core 25
    battery 78group 32.5
    intake eddy old 2101 14.7
    intake eddy vortec rpm 17.9
    header flowtech full length 11.5
    crank pulley steel 3 pulley4.4
    old style stamped steel valve cover 1.7
    bill alum valve cover 1.7
    billet distributor 5.5
    old iron exh man 16.5
    oldsbuickhybrid
    oldsbuickhybrid
    Post  oldsbuickhybrid on Sun Nov 01, 2015 10:29 pm
    Great post.  I found a link that I find pretty useful as well.  I do not know how accurate it is, but it has weights for many different engines, including Buick, Pontiac, and Oldsmobile.
    http://www.carnut.com/specs/engdim.html
    Last edited by oldsbuickhybrid on Mon Nov 02, 2015 12:33 am; edited 1 time in total (Reason for editing : Had posted wrong link)
    -Mike-
    1985 Delta 88 (Project)
      Current date/time is Sat Jan 18, 2020 10:01 pm
