    Biggest tires that will fit.
    79treemaster
    Biggest tires that will fit. Empty Biggest tires that will fit.
    Post  79treemaster on Mon Sep 02, 2013 6:43 pm
    What is the biggest tire that will fit without the rear being raised up at all without cutting any of the body? I am wanting to use 15" rims only so some width size along with offset size would be helpful as well. Thinking a 15x10 rim with 295x60x15's might fit?
    Biggest tires that will fit. Empty Re: Biggest tires that will fit.
    Post  GM B-Body Forum on Mon Sep 02, 2013 7:50 pm
    For the most part, you can fit almost any tire size you want, as long as you have the backspacing correct, with a stock gm 10 bolt 7.5, you can get an offset of 4-4.5 inches, if you change rear ends, then it changes the offset. If your keeping the car stock height then id try not to go any bigger than a 30inch diameter tire. So your 295 60 15 should fit no problem with a 4 inch backspace. Im planning on getting either 17s or 18s in an 11inch wide rim, so id be looking at a 335 35 17 or 335 30 18. Ive done multiple measurements and a tire that size would fit.
    Biggest tires that will fit. 20150410
    Post  Sweet Seventy9 on Sun Nov 03, 2013 4:34 pm
    10" wide wheels with 5" backspacing and 295/50 tires fit with room to spare.
    Biggest tires that will fit. Mvc-7910
    Biggest tires that will fit. Mvc-7911
    phil.fen86
    phil.fen86
    Post  phil.fen86 on Thu Feb 05, 2015 12:01 am
    so if you have a 8.5 inch rear end will the 5. back spacing work? Or 4 3/4 back spacing to fit 15x10 rims with 295x50?
      Current date/time is Sun Apr 05, 2020 10:37 pm
