    bulb replacement
    reddtheLegend
    reddtheLegend
    bulb replacement  Empty bulb replacement
    Post  reddtheLegend on Wed Apr 01, 2015 12:53 am
    I'm currently on a quest to replace all lighting in/on my Cruiser with leds. So far I've changed the dome, footwell and volt meter bulbs so far. I've got some on order for the rest of the dash and instrument panel Aand map lights. Just got the cornering lamp bulbs and plan on popping them in tomorrow. Question is, I haven't seen any obvious way to get the cover off. I don't wanna pry on it, and scratch the paint or break the trim...
    reddtheLegend
    reddtheLegend
    bulb replacement  Empty Re: bulb replacement
    Post  reddtheLegend on Fri Apr 03, 2015 5:39 pm
    I figured it out. There are two 13mm (might be 11mm) nuts holding the chrome frame to the fender. They are accessed from under the car, was pretty easy.
    Some pics bulb replacement  IMG_20150401_094621803_HDR_zpsfpp7prr6
    My next project will be to remove the defuser from inside the light housing.
    bulb replacement  IMG_20150401_205752872_zps1jo6a9za
    bulb replacement  IMG_20150320_200433123_zpsdckw5badbulb replacement  IMG_20150320_201258274_zps5p3qfby3
      Current date/time is Fri May 29, 2020 4:43 pm
