    Cooling Air lock
    Cooling Air lock Empty Cooling Air lock
    Post  Myloth on Thu Apr 09, 2015 4:12 pm
    I can't seem to get air out of the cooling system. I tried running with and without cap and elevating the front end with no luck anyone ever have this problem? And the thermostat is working fine.
    And there is no coolant reaching the heater core I also tried with and without heat on. If I leave the cap off the coolant eventually backs out of the radiator some rather than going down, temps go to about 210.
    Cooling Air lock Empty Re: Cooling Air lock
    Post  Sweet Seventy9 on Thu Apr 09, 2015 5:49 pm
    water pump
    Post  Myloth on Thu Apr 09, 2015 6:53 pm
    Well this the replacement (used it seemed to spin ok but ) for the prior one that made noise. Yeah could be if it is that
    sucks but I never had this problem before with a good pump so ........ Oh well I guess I'll have to use the new HD aluminum
    I was saving .
    Post  Myloth on Fri Apr 10, 2015 4:11 pm
    Sweet you were dead on except the pump wasn't bad I forgot to pull the plug out. Damn I guess I was a little
    too quick lol.
    The punchline I it ran for 3 min then the pump started making noise and weeping sigh. Should of just put in
    the new one and been done.
      Current date/time is Sat Apr 04, 2020 8:12 pm
