    Proportioning Valve
    Jakers01
    Proportioning Valve
    Post  Jakers01 on Sun Aug 02, 2015 8:54 pm
    I am just finishing converting my 2 door 78 caprice to a 94 9c1 rear end with disk brakes. Also installed 94 front spindles to accomidate 12" rotors and 5x5 bolt pattern. I have installed 94 brake booster, master cylinder and proportioning valve. I have installed stealth bolt mod kit. My question is... how do I deal with the old proportioning valve that's mounted to the frame. Can I gut it exept for the pin that separates front and rear circuits? Any help would be appreciated.
    Thx
    Re: Proportioning Valve
    Post  Sweet Seventy9 on Sun Aug 02, 2015 9:32 pm
    The old one is no longer used. Remove it and throw it out. Install new fluid lines. Viola', all set!
    * Don't forget - The newer master cylinder and Combo valve use metric fittings and BUBBLE flares on the lines.
    Jakers01
    Post  Jakers01 on Tue Aug 04, 2015 8:15 pm
    Jeez.... I was afraid of that. Was thinking I could take old valve, drill and tap the thru hole for a 1/16 pipe plug on both sides. then it would be just a manifold with separate circuits.
    I will have to redo tubing from new valve to old valve.
    Thx
    Post  HeavyChevy77 on Wed Aug 05, 2015 1:14 am
    You should have used a 90 caprice master cylinder and booster only need two adapter fittings and an eBay combo valve (chrome $50 opens up the rear brakes I've tested/ask my four 10ft long skid on the road when someone cut me off)
    FYI primaries and secondarily swap locations on the master cylinder so just gently pull and bend /manipulate them to cross easy other and putting the fittings adapters (9/16x18 to 1/2"x20 &Vic versa)) and done. The combo valve is plus and play so is the booster.
    Z77impala
    Post  Z77impala on Mon Jan 16, 2017 5:00 pm
    I did the exact swap you did, and I just had to remove the old proportion valve down on the drivers side frame, and connected the rest of the lines together
      Current date/time is Mon Jul 16, 2018 7:48 pm
