    the dreaded Comfortron
    Marx3
    Marx3
    the dreaded Comfortron Empty the dreaded Comfortron
    Post  Marx3 on Fri Oct 02, 2015 4:37 am
    So, I learn that the Comfortron A/C system in my 79 Caprice can be a bit of a problem child.
    I want to know if the system seems to be defective ( as I am, kind of expeting from it ) or if it actually seems to work.
    The system is dry, car sat for 10 years up untill recently, so obviously it will not blow icecold.
    I can operate the function lever and make it defrost, go bi-level etc. The control unit seems to work, both vacuum and electrical. I can also change the temperature, but it will take some time before the temperature rises. I mean, when you slide the lever to heat on a car without A/C, it will blow warm air at once.
    I read somewhere, that the heat valve out in the enginebay is often defective and wil cause all kinds of problems with the rest of the system. ?
    the dreaded Comfortron Empty Re: the dreaded Comfortron
    Post  Sweet Seventy9 on Fri Oct 02, 2015 7:43 am
    I've only had one car with it and it worked without any troubles. Well, I'm assuming the heat worked as I never used it. The AC worked great though.
    Hopefully B body sees this thread. He seems to be the most knowledgeable about these types of things.
    Marx3
    Marx3
    Post  Marx3 on Fri Oct 02, 2015 1:45 pm
    Great, I will wait for him to see this thread then.
    Dont know if mine is broken in any way. That's what I want to find out :-)
    cruiser_dirk
    cruiser_dirk
    the dreaded Comfortron Empty Comfortron
    Post  cruiser_dirk on Sat May 21, 2016 3:13 am
    I do feel the same about my Comfortron Question
    At least I managed to get hold of an electrical wiring scheme....
    actual problem is, the Blower only runs in "Def"-position....  I can not find the location of the Temp Heater switch (should be on the front of the right cylinder head?!?!?!?)
      Similar topics
      Current date/time is Fri May 29, 2020 2:55 pm
