    1965 Oldsmobile Dynamic 88 Speedometer error
    x75
    1965 Oldsmobile Dynamic 88 Speedometer error Empty 1965 Oldsmobile Dynamic 88 Speedometer error
    Post  x75 on Sat Dec 12, 2015 9:39 am
    My speedo reads about 20% fast, e.g. shows 60 MPH when doing about 45-50. My tires are not undersized, in fact we're running 17s with big rubber, replacing the little factory 14s that were on it.
    The speedo is driven off the LEFT FRONT WHEEL, with a cable that appears to go straight into the back of the dash. I cannot find any gears like you see on a speedo cable that connects to a transmission tail-shaft housing.
    How can I re-calibrate my speedometer?
    1965 Oldsmobile Dynamic 88 Speedometer error Empty Re: 1965 Oldsmobile Dynamic 88 Speedometer error
    Post  Myloth on Sat Dec 12, 2015 3:04 pm
    As you said those the ones with the wheel driven speedometer used in the 60s. I don't know too much about
    them but I do many people replace the transmission or the speedometer. I think if your cable is ok the wheel sensor is
    bad they are supposed to be accurate. Options are replace the wheel unit or go into the aftermarket if not for speedo
    or trans there is a digital sensor that can replace that but it's not cheap.
      Current date/time is Mon May 25, 2020 6:12 pm
