    Ideal backspacing for rear wheels
    TylerW
    Ideal backspacing for rear wheels Empty Ideal backspacing for rear wheels
    Post  TylerW on Fri Jan 01, 2016 8:43 pm
    Hey guys:
    I'm going to be upgrading wheels on my '77 Caprice coupe from an ancient set of Vectors to 8" Ralleys. I already have a nearly new pair of 255/60/15's I plan to use for the rear, so what amount of backspacing will get things out to near the fender lip without rubbing? Thanks.
    Ideal backspacing for rear wheels Empty Re: Ideal backspacing for rear wheels
    Post  Sweet Seventy9 on Fri Jan 01, 2016 10:52 pm
    Welcome to the forum!
    Using an 8" wide wheel, 3" backspacing will put them pretty close to the wheel lip without rubbing.  Using 255's, 2" might even work better.
    Here's a pic of 15x10 Rally wheels with 5" backspacing (295/50 tires).  When using an 8" wide wheel, 3" backspacing will put it in a similar position.
    Ideal backspacing for rear wheels Mvc-7910
    Post  Myloth on Sat Jan 02, 2016 10:26 am
    Here  is the same tire\wheels with a 1" spacer behind the wheels .
    Ideal backspacing for rear wheels Th_P9010002
    Although it is a different Rear end anyone know the width difference between a 7.5 79' rear and 95-96 Posi 8.5?
    Post  Sweet Seventy9 on Sat Jan 02, 2016 11:18 am
    Myloth wrote:<snip> Although it is a different Rear end anyone know the width difference between a 7.5 79' rear and 95-96 Posi 8.5?
    IIRC, one inch wider. (1/2 inch on each side)
    Post  Myloth on Sat Jan 02, 2016 7:35 pm
    I thought the tires stuck out a tad more so that's actually 1.5" out from the stock rear in the first pic .
      Current date/time is Tue May 26, 2020 3:33 am
