    D52 Brake Pad Upgrade
    D52 Brake Pad Upgrade Empty D52 Brake Pad Upgrade
    Post  GM B-Body Forum on Sun Jan 03, 2016 10:44 pm
    I was curious the other day so i decided to check it out. I wanted to see the difference between the 94-96 impala ss front brake pads vs the standard pretty much every gm truck and car from the 70's and 80's D52 brake pads. What i found is the 94-96 impala ss brake pads are much bigger, much more surface area, and the best part is, they fit in place of the D52 pads. As you can see below i took a caliper, and a standard 11 inch rotor and made sure they fit, and they do!
    So being that i work part time at a local auto parts store, i had some free time to compare them side by side.
    D52 Brake Pad Upgrade 20160110
    The pads on the left are the D52, and the right is the impala same goes for the next few pics
    D52 Brake Pad Upgrade 20160111
    D52 Brake Pad Upgrade 20160113
    D52 Brake Pad Upgrade 20160114
    D52 Brake Pad Upgrade 20160115
    D52 Brake Pad Upgrade 20160116
    D52 Brake Pad Upgrade 20160117
    If any of you want to try this, and im going to try it next, the part number from Orellly's is MKD614 those are semi metallic pads, usually the other parts stores have the same number but some may be different.
    Last edited by GM B-Body Forum on Mon Feb 06, 2017 7:38 pm; edited 1 time in total
    D52 Brake Pad Upgrade 20150410
    D52 Brake Pad Upgrade Empty Re: D52 Brake Pad Upgrade
    Post  solo79 on Mon Jan 04, 2016 7:10 pm
    Well, that's certainly good to know! Thanks for the comparisons! I kind of wondered about that myself. Looks like an easy upgrade!
    Post  Myloth on Mon Jan 04, 2016 8:08 pm
    Now I know what to do with that Xmas Auto Zone Gift Card!
    shnalla
    shnalla
    Post  shnalla on Fri Jan 08, 2016 9:43 am
    That looks cool.
    I have to replace the brake pads on my 84 wagon, I'll try it Cool
    I'm curious to know if any other part from 92-96 B-body fits our cars ...
    1972 Monte Carlo / 1984 Caprice Wagon / 1992 Buick Park Avenue
    Post  Myloth on Fri Jan 08, 2016 6:36 pm
    I have a set of 96 Impala SS Front Springs in my 79 Imp 2dr in the stock control arms with stock size shock ns about a
    wagon though.
    Post  GM B-Body Forum on Fri Jan 08, 2016 11:23 pm
    99% of every part from 77 to 96 is the same, as far as the chassis, steering and suspension goes.
    oldsbuickhybrid
    oldsbuickhybrid
    Post  oldsbuickhybrid on Sat Nov 05, 2016 12:41 pm
    This looks like a great, easy mod. Anyone try it yet?
    -Mike-
    1985 Delta 88 (Project)
    D52 Brake Pad Upgrade Empty Brake pads
    Post  terry cronk on Sun Nov 06, 2016 8:07 am
    That looks like a 20-25% increase in pad surface.
    Thanks for the info.
    D52 Brake Pad Upgrade Empty brake pads 94-96 for 77-79
    Post  terry cronk on Tue Feb 14, 2017 8:53 am
    Thanks for reposting that.
    Memory told me somewhere I saw that.
    So the larger pads installed in the pictures(caliper)are the 94-96 Impala correct?
    They look like my S10 pads.
    Post  GM B-Body Forum on Tue Feb 14, 2017 9:34 am
    Correct, they were listed for the 94 to 96 impala
    Post  terry cronk on Tue Feb 14, 2017 9:42 am
    Thanks for that information.
    I think I have a set lying around.
    Hopefully I can find them.
      Current date/time is Mon Mar 30, 2020 11:53 am
