    BUMPER FILLER!!!!!!!!!!
    BUMPER FILLER!!!!!!!!!! Empty BUMPER FILLER!!!!!!!!!!
    Post  GM B-Body Forum on Mon Jan 14, 2013 11:12 pm
    Ah yes a very hard part to find for our Caps and Imps but here is a great website that reproduces all the bumper filler for our cars (for the most part) they even have the rear center filler for my 79 caprice, because mine is split in many locations. Heres the link to this website.
    http://www.replica-plastics.com/editparts.aspx?make=chevrolet
    79treemaster
    BUMPER FILLER!!!!!!!!!! Empty Re: BUMPER FILLER!!!!!!!!!!
    Post  79treemaster on Mon Sep 02, 2013 10:53 pm
    Has anyone purchased that center bumper filler that you know of. What quality is it and does it mount the same way as the original one?
    Post  GM B-Body Forum on Tue Sep 03, 2013 10:13 am
    Ive been meaning to buy this part for my car, still have not done it yet, so i cant speak on the quality yet!
    BUMPER FILLER!!!!!!!!!! 20150410
    79treemaster
    Post  79treemaster on Sun Oct 06, 2013 10:32 am
    Has anyone thought of fabricating something back there to replace that part other than the one from Replica-Plastics?
    Post  solo79 on Tue Oct 29, 2013 8:32 pm
    79treemaster wrote:Has anyone thought of fabricating something back there to replace that part other than the one from Replica-Plastics?
    I did!!! If you go look at my blue caprice in my thread, you'll see it has rear center bumper filler. Of course, I couldn't find it back then and I happen to be in Lowe's one day and was staring at this vinyl base board trim which is very thick and flexible. I can't remember the exact thing, but I was planning on doing the same thing again. It was easy to trim, install and paint and looked perfect I thought. I'm planning on visiting Lowe's or Home Depot to see if they still have this. It was maybe 3 inches wide and it was white. It had a little beveled angle down one side which made it rise just right on the bumper. I already knew I'd be doing this again. The car I just bought doesn't even have the filler on the bumper.
    Post  solo79 on Tue Oct 29, 2013 8:43 pm
    I went and found a better picture of it on one of my many flash drives. I can't seem to find a real good picture of it as I apparently didn't take any close-ups of the rear bumper. At any rate, it's simply base board trim and it's just the right thickness:
    BUMPER FILLER!!!!!!!!!! Aqxu
    If you're interested, when I get to this point, I'll do a how-to on it.
    79treemaster
    Post  79treemaster on Tue Oct 29, 2013 9:27 pm
    That is pretty cool that you made that.
    Post  GM B-Body Forum on Wed Oct 30, 2013 11:54 am
    Yeah that actually is a great idea, but if i can get an original or remake ill definitely get one.
    Post  Sweet Seventy9 on Sun Nov 03, 2013 3:22 pm
    I bought one of those Replica Plastic ones. What a POS.......
    Post  GM B-Body Forum on Sat Feb 01, 2014 10:06 am
    sorry im late, i didnt even know you responded. So they really are a pos?
    Post  Sweet Seventy9 on Sat Feb 01, 2014 12:34 pm
    Yeah, it was nothing more than a cheap "Z" shaped piece of fiberglass.
    I had to measure and drill my own holes to mount it, and no matter how you mod it, it does not fill the gap properly.
    Instead of coming up at a slight angle like the factory one, like I said, it's "Z" shaped and is set back about an inch and a half or so from the rear fascia.
    People would be better off buying a couple tubes of silicon sealer and rebuilding the one they have.
    BUMPER FILLER!!!!!!!!!! Mvc-7810
    BUMPER FILLER!!!!!!!!!! Mvc-7811
    Post  solo79 on Wed Feb 19, 2014 9:17 pm
    Thanks for showing pictures of that aftermarket one. I was thinking about that until I saw your photos and now I know I don't want it. I think I'll do what I did last time, but instead of using 3M double-sided tape which wasn't the greatest idea, I'll use something a little stronger like panel bond adhesive maybe. OR...maybe I'll just suck the bumpers in like that one car in the other thread. I can't get over how good that looks.
    Post  Sweet Seventy9 on Wed Feb 19, 2014 9:58 pm
    solo79 wrote:Thanks for showing pictures of that aftermarket one.  I was thinking about that until I saw your photos and now I know I don't want it.  I think I'll do what I did last time, but instead of using 3M double-sided tape which wasn't the greatest idea, I'll use something a little stronger like panel bond adhesive maybe.  OR...maybe I'll just suck the bumpers in like that one car in the other thread.  I can't get over how good that looks.
    You're very welcome.  I'm glad they were a help.
    You should do a poll!
    I vote: suck in the bumpers! (and narrow them Wink )
    Post  GM B-Body Forum on Wed Feb 19, 2014 10:40 pm
    Yeah i was going to buy that also but im not now, i was either thinking of sucking the bumpers also, though im not sure how the rear would look, i know the front looks awesome tucked in. (Ive been diligently looking for the owner of that light blue impala with no luck yet because i want to see what the rear looks like.) Or do what you did Solo, you said you found a vinyl piece at lowes or home depot?
    Post  GM B-Body Forum on Sat Mar 01, 2014 10:10 pm
    hey solo, is this about the same thing you found at lowes? http://www.lowes.com/pd_310628-1487-07527_0__?Ntt=vinyl+base+board+trim&UserSearch=vinyl+baseboard+trim&productId=3340764&rpp=32
    Post  solo79 on Sun Mar 02, 2014 8:59 am
    GM B-Body Forum wrote:hey solo, is this about the same thing you found at lowes? http://www.lowes.com/pd_310628-1487-07527_0__?Ntt=vinyl+base+board+trim&UserSearch=vinyl+baseboard+trim&productId=3340764&rpp=32
    I'm about 80% sure it was this:
    http://www.lowes.com/pd_587940-33674-VC25C81P029_0__?productId=50139176&Ntt=vinyl+base&pl=1&currentURL=%3FNtt%3Dvinyl%2Bbase&facetInfo=
    It's hard to tell from the pic though. I just need to go down there and walk around and hopefully I'll recognize it. It's been about 12 years since I did that. I don't remember having to buy a 120ft roll of it though. I think it was just all one piece about 8-10 ft. long. I'll get down there one day this week and figure this out.
    dougc383
    dougc383
    Post  dougc383 on Fri Mar 14, 2014 2:37 pm
    Did you also make the covers for your tail lights
    Post  solo79 on Fri Mar 21, 2014 7:09 am
    dougc383 wrote:Did you also make the covers for your tail lights
    Actually I did. It's really not covers though. It's metal mesh painted white between the factory cover and the bezel. It created a neat effect since the brake lights still showed through red. Surprisingly, the lights were highly visible in the day time and you couldn't tell much difference at night.
    beastndastreet
    Post  beastndastreet on Thu Sep 25, 2014 8:00 pm
    Has anyone tried this on from classic industries?
    http://www.classicindustries.com/product/impala/parts/rp5020.html
    Post  solo79 on Thu Sep 25, 2014 8:17 pm
    beastndastreet wrote:Has anyone tried this on from classic industries?
    Hi and welcome to the forum!  I wish Classic has a better picture of it.  I'm looking at it on a 26" monitor and I can't tell much from the photo.  It does look different than that other one though and it does state "manufactured to factory specifics" so this may be the ticket here.  Good find. I didn't know they had that and I get their thick Impala book every once in awhile.
    Post  Sweet Seventy9 on Thu Sep 25, 2014 9:42 pm
    It looks like Replica Plastics might have changed their design from the POS one I bought. (The RP in the p/n is for replica plastics.) The shape actually does look slightly different, and they say it has the holes already drilled. I'd still be careful, but who knows... maybe somebody finally heard our requests and made a GOOD one now?
    Post  GM B-Body Forum on Thu Sep 25, 2014 9:56 pm
    It does look different than sweetseventy9's pic of it on his car, but its not worth no 93 bucks, its a piece of fiberglass
    beastndastreet
    Post  beastndastreet on Thu Sep 25, 2014 10:53 pm
    thanks guys it does look different I'm going to contact them in the am to see if its the crap from RP or not maybe try to get a discount for forum members.
    Post  Sweet Seventy9 on Thu Sep 25, 2014 11:29 pm
    beastndastreet wrote:thanks guys it does look different  I'm going to contact them in the am to see if its the crap from RP or not maybe try to get a discount for forum members.
    If CI is selling the RP one, RP sells direct to the public. $69.
    https://www.replica-plastics.com/EditParts.aspx?Make=Chevrolet
    79treemaster
    Post  79treemaster on Mon Nov 03, 2014 10:58 am
    Anyone hear if it is a revised part or a new part that is being offered?
      Current date/time is Mon Jan 27, 2020 5:10 pm
