    Biggest fitting radiator?
    79treemaster
    Biggest fitting radiator? Empty Biggest fitting radiator?
    Post  79treemaster on Fri Nov 08, 2013 9:37 am
    I will be installing a 600 HP+ 489-496 ci motor in my 79 later next summer. Wanting to find out what and where is the biggest radiator I can fit in the car. Pretty sure I am looking at 32" wide and about 19" height wise.
    Biggest fitting radiator? Empty Re: Biggest fitting radiator?
    Post  GM B-Body Forum on Sun Nov 10, 2013 9:51 pm
    yeah im not sure, but these cars have alot of room, so id think you get one in there with min to no problems, i cant remember the stock size, i did however upgrade to a three core from the original single core, but the outside dimensions stayed the same
    Biggest fitting radiator? 20150410
    79treemaster
    Post  79treemaster on Sun Nov 10, 2013 9:53 pm
    Yeah, I am guessing they make a four core that size as well. Maybe even a big 2 core aluminum unit with big tubes.
    Post  GM B-Body Forum on Sun Nov 10, 2013 9:56 pm
    Yeah whatever you can find, youll need that bad boy running cool, im assuming your going to upgrade to electric fans too?
      Current date/time is Fri Jan 17, 2020 5:33 pm
