    85 Lesabre LS swap
    noaht4
    85 Lesabre LS swap Empty 85 Lesabre LS swap
    Post  noaht4 on Sun Feb 02, 2020 9:05 am
    Hey just wanted to share my 85 Lesabre that I put a 4.8 ls in. When I was looking into do this I couldn’t find a whole lot of information on what the b body needed for the swap, it’s actually very easy swap lots of room in the engine bay. All I really needed was the Gm performance muscle oil pan( it hangs a few inches below the crossmember but lots of clearance) and ICT motor mount plates. The motor mount plates use the stock sbc clamshell mounts and the stock location on the frame. I’ve got a th350c with a shift kit. The TH350 is just about the same length as the 200r4 that came out of the car originally but the trans mount is further ahead so you have to move the trans crossmember up a bit. The engine is just a stock gen 3 4.8 with a Holley single plane and carb, with the msd 6010 ignition box. The thing screams make real good power is like to get a cam for it in the future. It’s got the 7.5 with 2.73 gear right now but I had an 8.5 and 3.42s to swap in.
    noaht4
    85 Lesabre LS swap Empty Re: 85 Lesabre LS swap
    Post  noaht4 on Sun Feb 02, 2020 9:07 am
    85 Lesabre LS swap 77296c1085 Lesabre LS swap 77296c10
    noaht4
    Post  noaht4 on Sun Feb 02, 2020 9:09 am
    85 Lesabre LS swap 0e7f3110
    Post  Kit1078 on Thu Feb 06, 2020 9:12 pm
    That thing looks clean. I don't see many LeSabre's around my area, nobody really saved them like the caprices or olds 88's. It's nice to see someone out there rocking the buick.
    noaht4
    Post  noaht4 on Fri Feb 07, 2020 2:26 pm
    Thanks! Yeah it’s the same deal around here too caprices and 88s , not many parts around for the Buick’s either.
    350Rocket
    Post  350Rocket on Sun Feb 16, 2020 12:43 pm
    Beautiful car! I'm planning a 5.3 swap in my 83 Caprice soon too but I'm using the 4L60 from the donor truck, and already have the 8.5" 3.08 posi rear in my car. I'm also keeping the stock ECM and EFI just as it was in the truck. It'll be stock but. 285hp is better than 150.
    noaht4
    Post  noaht4 on Mon Feb 24, 2020 9:48 am
    Awesome yeah that’ll wake er up. The stock engines weren’t much of a powerhouse
    noaht4
    Post  noaht4 on Thu Mar 19, 2020 1:48 pm
    Got my 8.5 with 3.42s under the car. Had to shorten the driveshaft an inch,just did it with a grinder with cutoff disc no vibrations or anything I’m pleased with it
    noaht4
    Post  noaht4 on Thu Mar 19, 2020 1:49 pm
    85 Lesabre LS swap 8689b610
      Current date/time is Sun Mar 29, 2020 11:35 pm
