    Doorseal caprice 77 Classic.
    Bwalfen
    Doorseal caprice 77 Classic. Empty Doorseal caprice 77 Classic.
    Post  Bwalfen on Tue Jul 28, 2020 12:16 pm
    Hello!
    Im so glad that I found this awesome forum.
    I'm from sweden and I have finally managed to buy my first "older" american car, Im so happy!
    Now, I'm going to replace the weatherstrip/ seal around the doors of my Caprice Classic-77.
    https://www.rockauto.com/en/catalog/chevrolet,1977,caprice,5.7l+350cid+v8,1036460,body,door+seal+/+weatherstrip,1430
    Can anyone confirm if I can use any of these seals and do I need any glue etc. to perform the work?
    I have seen some small white plastic T-shaped pins under the old seal, should I get new ones aswell and does anyone know where I can find them in that case?
    Thanks in advance! Very Happy
    slimwud
    slimwud
    Doorseal caprice 77 Classic. Empty Weather strip
    Post  slimwud on Sat Aug 01, 2020 9:24 pm
    Yes use glue the stuff you need is called weather strip adhesive. Typically the clips come along with the new rubbers. Good luck. Check my youtube channel cfmechanic. I check YouTube more often then here.
      Current date/time is Tue Aug 11, 2020 5:51 pm
